Discuss
Washer won't spin after cluch replaced.
 in
Washer Repair
I bought, and installed a new clutch assy. in the washer. Now it won't spin or agitate. Had it apart
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't spin after cluch replaced.
  #1 (permalink)
Old 04-17-2013, 07:10 AM
Junior Member
rondes1 is on a distinguished road
Default Washer won't spin after cluch replaced.
Model Number: LSQ8543JQO   Brand: Whirlpool   Age: More than 10 years
I bought, and installed a new clutch assy. in the washer. Now it won't spin or agitate. Had it apart a couple of time to make sure it was assembled correctly. It will fill with water and pump out. Any idea what I did wrong?
Ron
Related Models
Whirlpool LSQ8543JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JT1 WASHER
Whirlpool LSQ8543JZ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ8543JZ1 WASHER
Whirlpool LSQ9010KQ0 WASHER
Whirlpool LSQ9010KT0 WASHER
Whirlpool LSQ9010LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LG1 AUTOMATIC WASHER
Whirlpool LSQ9010LG2 AUTOMATIC WASHER
Whirlpool LSQ9010LG3 AUTOMATIC WASHER
Whirlpool LSQ9010LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LQ1 AUTOMATIC WASHER
Whirlpool LSQ9010LQ2 AUTOMATIC WASHER
Whirlpool LSQ9010LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9010LW1 AUTOMATIC WASHER
Whirlpool LSQ9010LW2 AUTOMATIC WASHER
Whirlpool LSQ9010LW3 AUTOMATIC WASHER
Whirlpool LSQ9010PG0 AUTOMATIC WASHER
Whirlpool LSQ9010PG1 AUTOMATIC WASHER
Whirlpool LSQ9010PG2 AUTOMATIC WASHER
Whirlpool LSQ9010PG3 AUTOMATIC WASHER
Whirlpool LSQ9010PG5 AUTOMATIC WASHER
Whirlpool LSQ9010PG6 AUTOMATIC WASHER
Whirlpool LSQ9010PW0 AUTOMATIC WASHER
Whirlpool LSQ9010PW1 AUTOMATIC WASHER
Whirlpool LSQ9010PW2 AUTOMATIC WASHER
Whirlpool LSQ9010PW3 AUTOMATIC WASHER
Whirlpool LSQ9010PW5 AUTOMATIC WASHER
Whirlpool LSQ9010PW6 AUTOMATIC WASHER
Whirlpool LSQ9030PQ0 AUTOMATIC WASHER
Whirlpool LSQ9030PQ1 AUTOMATIC WASHER
Whirlpool LSQ9030PQ2 AUTOMATIC WASHER
Whirlpool LSQ9030PQ4 AUTOMATIC WASHER
Whirlpool LSQ9030PQ5 AUTOMATIC WASHER
Whirlpool LSQ9110KQ0 WASHER
Whirlpool LSQ9110KQ1 WASHER
Whirlpool LSQ9110LG0 WASHER
Whirlpool LSQ9110LG1 AUTOMATIC WASHER
Whirlpool LSQ9110LW0 WASHER
Whirlpool LSQ9110LW1 AUTOMATIC WASHER
Whirlpool LSQ9110PW0 AUTOMATIC WASHER
Whirlpool LSQ9110PW1 AUTOMATIC WASHER
Whirlpool LSQ9110PW2 AUTOMATIC WASHER
Whirlpool LSQ9110PW3 AUTOMATIC WASHER
Whirlpool LSQ9110PW4 AUTOMATIC WASHER
Whirlpool LSQ9200KQ0 WASHER
Whirlpool LSQ9200KT0 WASHER
Whirlpool LSQ9200LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LQ1 AUTOMATIC WASHER
Whirlpool LSQ9200LQ2 AUTOMATIC WASHER
Whirlpool LSQ9200LQ3 AUTOMATIC WASHER
Whirlpool LSQ9200LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9200LT1 AUTOMATIC WASHER
Whirlpool LSQ9200LT2 AUTOMATIC WASHER
Whirlpool LSQ9200LT3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ0 AUTOMATIC WASHER
Whirlpool LSQ9200PQ1 AUTOMATIC WASHER
Whirlpool LSQ9200PQ3 AUTOMATIC WASHER
Whirlpool LSQ9200PQ4 AUTOMATIC WASHER
Whirlpool LSQ9200PT0 AUTOMATIC WASHER
Whirlpool LSQ9200PT1 AUTOMATIC WASHER
Whirlpool LSQ9200PT3 AUTOMATIC WASHER
Whirlpool LSQ9200PT4 AUTOMATIC WASHER
Whirlpool LSQ9210HQ0 AUTOMATIC WASHER
Whirlpool LSQ9210HZ0 AUTOMATIC WASHER
Whirlpool LSQ9211KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9211KT1 WASHER - DIRECT DRIVE
Whirlpool LSQ9244EQ0 AUTOMATIC WASHER
Whirlpool LSQ9244EZ0 AUTOMATIC WASHER
Whirlpool LSQ9264HQ0 AUTOMATIC WASHER
Whirlpool LSQ9264HZ0 AUTOMATIC WASHER
Whirlpool LSQ9500LQ0 WASHER
Whirlpool LSQ9500LT0 WASHER
Whirlpool LSQ9510JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510JQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9510LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9510LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9520LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ9544KQ0 WASHER
Whirlpool LSQ9544KT0 WASHER
Whirlpool LSQ9549LG0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LG1 AUTOMATIC WASHER
Whirlpool LSQ9549LG2 AUTOMATIC WASHER
Whirlpool LSQ9549LG3 AUTOMATIC WASHER
Whirlpool LSQ9549LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LQ1 AUTOMATIC WASHER
Whirlpool LSQ9549LQ2 AUTOMATIC WASHER
Whirlpool LSQ9549LQ3 AUTOMATIC WASHER
Whirlpool LSQ9549LW0 WASHER - DIRECT DRIVE
Whirlpool LSQ9549LW1 AUTOMATIC WASHER
Whirlpool LSQ9549LW2 AUTOMATIC WASHER
Whirlpool LSQ9549LW3 AUTOMATIC WASHER
Whirlpool LSQ9549PG0 AUTOMATIC WASHER
Whirlpool LSQ9549PG1 AUTOMATIC WASHER
Whirlpool LSQ9549PG2 AUTOMATIC WASHER
Whirlpool LSQ9549PG3 AUTOMATIC WASHER
Whirlpool LSQ9549PG5 AUTOMATIC WASHER
Whirlpool LSQ9549PG6 AUTOMATIC WASHER
Whirlpool LSQ9549PW0 AUTOMATIC WASHER
Whirlpool LSQ9549PW1 AUTOMATIC WASHER
Whirlpool LSQ9549PW2 AUTOMATIC WASHER
Whirlpool LSQ9549PW3 AUTOMATIC WASHER
Whirlpool LSQ9549PW5 AUTOMATIC WASHER
Whirlpool LSQ9549PW6 AUTOMATIC WASHER
Whirlpool LSQ9550PW0 AUTOMATIC WASHER
Whirlpool LSQ9550PW1 AUTOMATIC WASHER
Whirlpool LSQ9550PW2 AUTOMATIC WASHER
Whirlpool LSQ9550PW3 AUTOMATIC WASHER
Whirlpool LSQ9550PW4 AUTOMATIC WASHER
Whirlpool LSQ9560PW0 AUTOMATIC WASHER
Whirlpool LSQ9560PW1 AUTOMATIC WASHER
Whirlpool LSQ9560PW2 Residential Washer
Whirlpool LSQ9560PW3 AUTOMATIC WASHER
Whirlpool LSQ9560PW4 AUTOMATIC WASHER
Whirlpool LSQ9564JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ9564JQ1 WASHER - DIRECT DRIVE
Whirlpool LSQ9564JT0 AUTOMATIC WASHER, COMPACT A/W
  #2 (permalink)
Old 04-17-2013, 07:29 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Check the coupler between motor and gearcase.
Eric
  #3 (permalink)
Old 04-17-2013, 02:24 PM
Junior Member
Default
Quote:
Eric
It looks to me like a direct drive for both the pump and the trans.. Would I be able to see the coupler if there was one?
Ron
  #4 (permalink)
Old 04-17-2013, 03:58 PM
Expert
APP Volunteer
Default
There is a coupler between the motor shaft and gearcase input shaft. You must remove the motor to be able to check it's condition. If the coupler fails, it won't agitate or spin but will still pump the water out which is the condition you describe. Coupler is #13 in the diagram.
Eric
  #5 (permalink)
Old 04-18-2013, 01:54 PM
Junior Member
Default
Thanks Eric, that was it, a broken coupling.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
I replaced lid switch, still washer will not drain or spin dnschrstn Washer Repair 5 11-12-2012 05:18 PM
Whirlpool Washer won't spin/agitate. Replaced Direct Drive Motor Coupling. millmoss Washer Repair 10 09-17-2012 01:45 PM
whirlpool top load washer won't spin. replaced coupler and clutch kodiakmook Washer Repair 2 01-23-2012 06:11 AM
Replaced agitator coupling, now washer won't spin johnt7225 Washer Repair 10 09-04-2010 07:00 AM
Washer won't spin at full speed, replaced thrust assy WasherGuy Washer Repair 4 05-27-2008 02:23 PM
