Discuss
No agitation
 in
Washer Repair
I have a5000 that will not agitate. It will fill and drain . The agitator is not stuck and the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No agitation
  #1 (permalink)
Old 04-17-2013, 03:59 AM
Junior Member
brookie is on a distinguished road
Default No agitation
Model Number: a5000   Brand: Maytag   Age: More than 10 years
I have a5000 that will not agitate. It will fill and drain . The agitator is not stuck and the belts are in good shape. I get no humming or any other sound out of it when it is supposed to agitate. This makes me think the motor is not getting a command to to run...I have made several assumptions that may be incorrect.
I assume the lid switch is good because it spins...
I assume the motor is good because it spins...
The transmission turns freely clockwise and the belts show no sign of wear or smoking so I assume the transmission is good.
Please help.
P.S. If all you have to say is I had the same problem and I bought a new washer...no need for you to respond.
Related Models
Maytag A5000 WASHER-TOP LOADING
Maytag A500S WASHER-TOP LOADING
Jenn-Air A501 MISC / ACCESSORY
Jenn-Air A501BT MISC / ACCESSORY
Jenn-Air A501S MISC / ACCESSORY
Jenn-Air A501WT MISC / ACCESSORY
Maytag A502 WASHER-TOP LOADING
Maytag A502S WASHER-TOP LOADING
Maytag A503 WASHER-TOP LOADING
Maytag A506 WASHER-TOP LOADING
Jenn-Air A507 MISC / ACCESSORY
Jenn-Air A507B MISC / ACCESSORY
Jenn-Air A507W MISC / ACCESSORY
Jenn-Air A509 MISC / ACCESSORY
Jenn-Air A509S MISC / ACCESSORY
Maytag A510 WASHER-TOP LOADING
Maytag A510S WASHER-TOP LOADING
Maytag A511 WASHER-TOP LOADING
Maytag A511S WASHER-TOP LOADING
Maytag A512 WASHER-TOP LOADING
Maytag A512S WASHER-TOP LOADING
Jenn-Air A516 MISC / ACCESSORY
Jenn-Air A518S MISC / ACCESSORY
Jenn-Air A519 MISC / ACCESSORY
Jenn-Air A519W MISC / ACCESSORY
Jenn-Air A521B MISC / ACCESSORY
Jenn-Air A521W MISC / ACCESSORY
Jenn-Air A526 MISC / ACCESSORY
Jenn-Air A526W MISC / ACCESSORY
Jenn-Air A527B MISC / ACCESSORY
Jenn-Air A530 MISC / ACCESSORY
Jenn-Air A530W MISC / ACCESSORY
Admiral A54F-5TKXW-R WALLOVEN- S/C GAS
Admiral A54F-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FK-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FN-5TKVW-R WALLOVEN- S/C GAS
Admiral A54FN-5TKVWM-R WALLOVEN- S/C MWAVE GAS
Admiral A5651XRS RANGE- D/I CONT CLEAN ELE
Admiral A5892XRS RANGE- S/C D/I ELE
Admiral A5898VRV RANGE- S/C D/I ELE
Admiral A5898XRB RANGE- S/C D/I ELE
Admiral A59-5EXW-R WALLOVEN- S/C ELE
Maytag A590 WASHER-TOP LOADING
Maytag A5910 WASHER-TOP LOADING
Admiral A59E-5EXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59FN-5TVW-R WALLOVEN- S/C ELE
Admiral A59FN-5TVWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59G-5TXW-R RANGE- F/S STD ELE
Admiral A59GN-5TVW-R RANGE- F/S STD ELE
Frigidaire A5LECC2 Frg(v3) / Room Air Conditioner
Frigidaire A5LECDC2 Frg(v4) / Room Air Conditioner
Frigidaire A5LECDD2 Frg(v13) / Room Air Conditioner
Frigidaire A5LECDSD2 Frg(v14) / Room Air Conditioner
Frigidaire A5LECUC2 Frg(v12) / Room Air Conditioner
Maytag A606 WASHER-TOP LOADING
Maytag A606S WASHER-TOP LOADING
Maytag A608 WASHER-TOP LOADING
Maytag A608S WASHER-TOP LOADING
Maytag A610 WASHER-TOP LOADING
Maytag A612 WASHER-TOP LOADING
Maytag A612S WASHER-TOP LOADING
Maytag A613 WASHER-TOP LOADING
Admiral A6257XRS RANGE- S/I CONT CLEAN GAS
Jenn-Air A626B MISC / ACCESSORY
Jenn-Air A627W MISC / ACCESSORY
Admiral A6498VRV RANGE- S/C S/I GAS
Admiral A6498XRS RANGE- S/C S/I GAS
Admiral A64HN-4TKVW-R RANGE- S/C S/I GAS
Admiral A6892XRS RANGE- S/C S/I ELE
Admiral A6898VRV RANGE- S/C S/I ELE
Admiral A6898XRB RANGE- S/C S/I ELE
Admiral A68HK-6TXW-R RANGE- S/C S/I ELE
Maytag A6910 WASHER-TOP LOADING
Frigidaire A6LECC2 Frg(v5) / Room Air Conditioner
Frigidaire A6LECC3 Frg(v1) / Room Air Conditioner
Frigidaire A6LECD2 Frg(v15) / Room Air Conditioner
Frigidaire A6LECDC2 Frg(v13) / Room Air Conditioner
Frigidaire A6LECDC3 Frg(v14) / Room Air Conditioner
Frigidaire A6LECDD2 Frg(v16) / Room Air Conditioner
Frigidaire A6LECUD2 Frg(v17) / Room Air Conditioner
Frigidaire A6LECUSD2 Frg(v18) / Room Air Conditioner
Maytag A700 WASHER-TOP LOADING
Maytag A700S WASHER-TOP LOADING
Maytag A702 WASHER-TOP LOADING
Maytag A702S WASHER-TOP LOADING
Maytag A710 WASHER-TOP LOADING
Maytag A710S WASHER-TOP LOADING
Maytag A712 WASHER-TOP LOADING
Maytag A7300 WASHER-TOP LOADING
Maytag A7400 WASHER-TOP LOADING
Maytag A7500 WASHER-TOP LOADING
Maytag A7500S WASHER-TOP LOADING
Maytag A7500W WASHER-TOP LOADING
Maytag A7800 WASHER-TOP LOADING
Admiral A79E-5CXW WALLOVEN- S/C ELE
Admiral A79F-5EXW-R WALLOVEN- S/C ELE
Admiral A79FN-5EVW-R WALLOVEN- S/C ELE
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 WASHER-TOP LOADING
Maytag A806S WASHER-TOP LOADING
Maytag A810 WASHER-TOP LOADING
Maytag A8100 WASHER-TOP LOADING
Maytag A8120 WASHER-TOP LOADING
Maytag A8140 WASHER-TOP LOADING
Maytag A8200 WASHER-TOP LOADING
Maytag A8210 WASHER-TOP LOADING
Admiral A8210PA SURFACE UNIT- GAS
Admiral A8210PA-L SURFACE UNIT- GAS
Admiral A8210PT-L SURFACE UNIT- GAS
Admiral A8210PW SURFACE UNIT- GAS
Admiral A8210PW-L SURFACE UNIT- GAS
Admiral A8211PA SURFACE UNIT- GAS
Admiral A8211PS SURFACE UNIT- GAS
Admiral A8211PW SURFACE UNIT- GAS
Maytag A8240 WASHER-TOP LOADING
Admiral A8241RA SURFACE UNIT- GAS
Admiral A8241RA-L SURFACE UNIT- GAS
Admiral A8241RS SURFACE UNIT- GAS
  #2 (permalink)
Old 04-17-2013, 05:30 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Yes, lid switch is ok and motor is likely ok. You may have a problem in the water level system. There is an air dome on the side of the outer tub that has a tube that goes from it to a pressure switch behind the control panel. As the water level rises in the tub, air pressure will activate the switch which turns off the water inlet valves and turns on agitation. Since your water is shutting off, the switch is activating but the contacts may be faulty. You can jump out the switch but I do not have a wiring diagram for that washer, I can help further if you provide a clear photo of the diagram. Standard color code for later models are white (or gray), yellow and brown. Jump the white (or gray) to yellow to bypass contacts for agitation.
Eric
  #3 (permalink)
Old 04-17-2013, 07:55 AM
Junior Member
Default
OK thanks. I will check it next week and get back to you. If I can't figure the switch out I will post a clear photo of the control panel.
  #4 (permalink)
Old 04-23-2013, 05:30 AM
Junior Member
Default
Thanks Fairbanks !
The yellow wire to the agitation switch was broken off at the connector. Replaced connector and washer works good. I didn't even have to buy anything !
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no agitation Kathryn Kemp Washer Repair 1 05-04-2011 02:36 PM
no agitation winder68 Washer Repair 0 03-12-2011 09:21 AM
No agitation rayhorne Washer Repair 0 08-16-2010 04:50 PM
no agitation johnnohu Washer Repair 1 02-28-2010 05:17 PM
Agitation! fjrbob Washer Repair 0 01-05-2009 11:33 AM
