Already cleaned filter, checked drain hose, Tub to pump hose. How is the pump removed from the back or is there a way to remove the front.
Thanks for your time, Bob
Groups: APP Team
Hi. The pump should be removed from the front. -open dispenser lid,remove 4 screws, take the lid off, pull down the dispenser. -use a putty knife to release two clips, holding the top (approx.2.5in at each corner). -push back and lift the top. -unscrew the 2 screws from top corners. -remove the screw from the filter cover. -use a flat screwdriver to unhook filter cover, pull it out. -remove 2 screws behind the filter cover. -open the door and remove the clamp using the flat screwdriver. -separate the clamp assembly from the front cover. -tilt the front cover, disconnect the door switch and, lift and separate the front cover. -remove the hoses and the pump. Here are the breakdown diagrams and parts for LG WM2010CW - AppliancePartsPros.comSimon.
