Discuss
Agitator catches during spin
 in
Washer Repair
When the tub spins, the agitator spins slowly with it for a few seconds and then there is a grinding
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Agitator catches during spin
  #1 (permalink)
Old 04-16-2013, 09:45 AM
Junior Member
skimor7 is on a distinguished road
Default Agitator catches during spin
Model Number: KAWS700GQ0   Brand: Kitchen Aid   Age: More than 10 years
When the tub spins, the agitator spins slowly with it for a few seconds and then there is a grinding noise, the agitator stops for a second and then it starts moving again and the process repeats itself. Any ideas? Thanks!
Related Models
Whirlpool KAWS700GQ0 AUTOMATIC WASHER
Whirlpool KAWS700GT0 AUTOMATIC WASHER
Whirlpool KAWS700GZ0 AUTOMATIC WASHER
Whirlpool KAWS700JQ0 RESIDENTIAL WASHER
Whirlpool KAWS700JQ1 RESIDENTIAL WASHERS
Whirlpool KAWS700JQ2 RESIDENTIAL WASHERS
Whirlpool KAWS700JQ3 RESIDENTIAL WASHER
Whirlpool KAWS700JQ4 RESIDENTIAL WASHERS
Whirlpool KAWS700JT0 RESIDENTIAL WASHER
Whirlpool KAWS700JT1 RESIDENTIAL WASHERS
Whirlpool KAWS700JT2 RESIDENTIAL WASHERS
Whirlpool KAWS700JT3 RESIDENTIAL WASHER
Whirlpool KAWS700JT4 RESIDENTIAL WASHERS
Whirlpool KAWS700LQ0 RESIDENTIAL WASHERS
Whirlpool KAWS700LT0 RESIDENTIAL WASHERS
Whirlpool KAWS750GQ0 AUTOMATIC WASHER
Whirlpool KAWS750GQ1 AUTOMATIC WASHER
Whirlpool KAWS750GT1 AUTOMATIC WASHER
Whirlpool KAWS750GZ0 AUTOMATIC WASHER
Whirlpool KAWS750GZ1 AUTOMATIC WASHER
Whirlpool KAWS750JQ0 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ1 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ2 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ3 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ4 RESIDENTIAL WASHERS
Whirlpool KAWS750JT0 RESIDENTIAL WASHERS
Whirlpool KAWS750JT1 RESIDENTIAL WASHERS
Whirlpool KAWS750JT2 RESIDENTIAL WASHERS
Whirlpool KAWS750JT3 RESIDENTIAL WASHERS
Whirlpool KAWS750JT4 RESIDENTIAL WASHERS
Whirlpool KAWS750LQ0 AUTOMATIC WASHER
Whirlpool KAWS750LQ1 AUTOMATIC WASHER
Whirlpool KAWS750LQ2 AUTOMATIC WASHER
Whirlpool KAWS750LQ3 AUTOMATIC WASHER
Whirlpool KAWS750LQ4 AUTOMATIC WASHER
Whirlpool KAWS750LT0 AUTOMATIC WASHER
Whirlpool KAWS750LT1 AUTOMATIC WASHER
Whirlpool KAWS750LT2 AUTOMATIC WASHER
Whirlpool KAWS750LT3 AUTOMATIC WASHER
Whirlpool KAWS750LT4 AUTOMATIC WASHER
Whirlpool KAWS777EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS777EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS800GQ0 AUTOMATIC WASHER
Whirlpool KAWS800GQ1 AUTOMATIC WASHER
Whirlpool KAWS800GZ0 AUTOMATIC WASHER
Whirlpool KAWS800GZ1 AUTOMATIC WASHER
Whirlpool KAWS850GQ0 AUTOMATIC WASHER
Whirlpool KAWS850GQ1 AUTOMATIC WASHER
Whirlpool KAWS850GT0 AUTOMATIC WASHER
Whirlpool KAWS850GT1 AUTOMATIC WASHER
Whirlpool KAWS850GZ0 AUTOMATIC WASHER
Whirlpool KAWS850GZ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ0 AUTOMATIC WASHER
Whirlpool KAWS850JQ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ2 AUTOMATIC WASHER
Whirlpool KAWS850JQ3 AUTOMATIC WASHER
Whirlpool KAWS850JQ4 AUTOMATIC WASHER
Whirlpool KAWS850JT0 AUTOMATIC WASHER
Whirlpool KAWS850JT1 AUTOMATIC WASHER
Whirlpool KAWS850JT2 AUTOMATIC WASHER
Whirlpool KAWS850JT3 AUTOMATIC WASHER
Whirlpool KAWS850JT4 AUTOMATIC WASHER
Whirlpool KAWS850LE0 AUTOMATIC WASHER
Whirlpool KAWS850LE1 AUTOMATIC WASHER
Whirlpool KAWS850LE2 AUTOMATIC WASHER
Whirlpool KAWS850LQ0 AUTOMATIC WASHER
Whirlpool KAWS850LQ1 AUTOMATIC WASHER
Whirlpool KAWS850LQ2 AUTOMATIC WASHER
Whirlpool KAWS850LT0 AUTOMATIC WASHER
Whirlpool KAWS850LT1 AUTOMATIC WASHER
Whirlpool KAWS850LT2 AUTOMATIC WASHER
Whirlpool KAWS855JE0 WASHER
Whirlpool KAWS855JE1 WASHER
Whirlpool KAWS855JE2 WASHER
Whirlpool KAWS855JE3 WASHER
Whirlpool KAWS855JE4 WASHER
Whirlpool KAWS977EQ0
Whirlpool KAWS977EZ0
Bosch KB030-062
Bosch KB032-062
Bosch KB035-062
Bosch KB036-062
Bosch KB090-054
Bosch KB091-054
Bosch KB100-046
Frigidaire KB122G0 Wwh(v1) / Built - in Oven
Frigidaire KB122G1 Wwh(v2) / Built - in Oven
Frigidaire KB122G2 Wwh(v3) / Built - in Oven
Frigidaire KB122G3 Wwh(v4) / Built - in Oven
Frigidaire KB122G4 Wwh(v5) / Built - in Oven
Frigidaire KB122LM0 Wwh(v1) / Wall Oven
Frigidaire KB122LM1 Wwh(v2) / Wall Oven
Frigidaire KB122LM2 Wwh(v1) / Wall Oven
Frigidaire KB122LMO Wwh(v1) / Wall Oven
Frigidaire KB152LM0 Wwh(v1) / Electric Range
Frigidaire KB152LM1 Wwh(v1) / Electric Range
Frigidaire KB152LM2 Wwh(v1) / Electric Range
Whirlpool KB26G1X-3 6 QT. STAND MIXER
Whirlpool KB26G1XAC3 6 QT. STAND MIXER
Whirlpool KB26G1XAC5 6 QT. STAND MIXER
Whirlpool KB26G1XBU3 6 QT. STAND MIXER
Whirlpool KB26G1XBU5 6 QT. STAND MIXER
Whirlpool KB26G1XER3 6 QT. STAND MIXER
Whirlpool KB26G1XER5 6 QT. STAND MIXER
Whirlpool KB26G1XGN3 6 QT. STAND MIXER
Whirlpool KB26G1XGR3 6 QT. STAND MIXER
Whirlpool KB26G1XGR5 6 QT. STAND MIXER
Whirlpool KB26G1XMC3 6 QT. STAND MIXER
Whirlpool KB26G1XMC5 6 QT. STAND MIXER
Whirlpool KB26G1XMY3 6 QT. STAND MIXER
Whirlpool KB26G1XMY5 6 QT. STAND MIXER
Whirlpool KB26G1XOB3 6 QT. STAND MIXER
Whirlpool KB26G1XOB5 6 QT. STAND MIXER
Whirlpool KB26G1XPT3 6 QT. STAND MIXER
Whirlpool KB26G1XPT5 6 QT. STAND MIXER
Whirlpool KB26G1XTG3 6 QT. STAND MIXER
Whirlpool KB26G1XTG5 6 QT. STAND MIXER
Whirlpool KB26G1XWW3 6 QT. STAND MIXER
Whirlpool KB26G1XWW5 6 QT. STAND MIXER
Frigidaire KB443GDM0 Wwh(v1) / Electric Continuous Clean Oven
  #2 (permalink)
Old 04-16-2013, 12:40 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Faulty cam in the gearcase allowing the agitator gear to partially engage during spin. If you have good mechanical skills and experience, parts are available to repair it, otherwise, replace the gearcase.
Eric
  #3 (permalink)
Old 04-16-2013, 04:16 PM
Junior Member
Default
Thanks for your reply. I've removed and opened the gearcase. When the driveshaft (that the coupler is on) spins counterclockwise, the agitator shaft turns back and forth. When the driveshaft spins clockwise (to turn the tub), the agitator shaft goes into a cycle of turning clockwise about a half turn and pausing. What is the agitator shaft supposed to be doing at this time? How can I tell which is the faulty cam? Is there only one cam in the gearcase? thanks
  #4 (permalink)
Old 04-16-2013, 05:28 PM
Expert
APP Volunteer
Default
When in spin direction, movement of the agitator shaft is only due to incidental friction between the spin pinion gear and the shaft that the pinion fits over as well as friction between the agitator gear and agitator shaft. The agitate gear is moved back and forth by the rack even during spin mode but the splines on the inside of the agitator gear are not engaged with the splines on the agitator shaft. The cam consists of two parts, the cam and cam follower. See photo below. The cam follower remains stationary while the cam is rotated a few degrees in one direction or the other by the shifter depending if your in spin or agitate. There are three ramps on the cam and three on the cam follower. When in spin mode the cam is turned such that the ramps cause the cam follower to push up on the agitate gear against spring pressure of the spring above it. In this position, the internal splines of the gear are not engaged with the splines of the shaft. In agitate, the cam is turned such that the ramps allow the spring to push down on the agitate gear engaging it with the splines on the shaft. The ramps on the cam parts can wear down causing the gear to not fully release from the splines.
Eric
  #5 (permalink)
Old 04-17-2013, 07:18 AM
Junior Member
Default
Thank you very much for the very detailed explanation of the inner workings and what might be causing the problem. I've taken out the shaft with the cam and cam follower on it. When they are close together, the agitate gear is fully engaged as it should be. When i rotate them so they are in the spread position, the shaft rotates smoothly for a bit but then it seems to catch a little on the splines on the shaft as it vibrates slightly and you can hear some faint clicks. Then it rotates smoothly again for a bit, catches slightly a bit and so on. This seems that your diagnosis is correct and i need to replace the cam and follower?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Squeaky, clothing catches in drum charleswilt Dryer Repair 7 07-05-2012 07:52 PM
Another Kenmore Dishwasher Catches Fire! keithb7 Dishwasher Repair 22 11-07-2011 04:15 PM
ge double oven catches fire!! cfgoldbe Oven Repair (including Ranges and Cooktops) 1 10-27-2010 02:11 PM
Element Catches Fire Karma Oven Repair (including Ranges and Cooktops) 0 08-17-2009 01:06 PM
Drum catches clothes tracksmak Dryer Repair 2 11-24-2008 06:18 AM
