Discuss
Clunks on stop
 in
Washer Repair
About 3 months ago, the coupling between motor & tranny broke, so I replaced that and the clutch assembly. Everything
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Clunks on stop
  #1 (permalink)
Old 04-14-2013, 12:41 PM
Junior Member
snotrag12 is on a distinguished road
Default Clunks on stop
Model Number: lsn1000lwo   Brand: Whirlpool   Age: 5 - 10 years
About 3 months ago, the coupling between motor & tranny broke, so I replaced that and the clutch assembly. Everything was great, washer worked fine and was quiet. Then about 2 weeks ago it started to make a clunk when it stopped. I also noticed some light water stains underneath. The water seems to be coming from around the top where the bleach dispenser is. I'm pretty sure the leak and noise are not related. So, I took out the motor and tranny again and there seems to be some oil leaking from the tranny seal. Some of the oil was inside the clutch. Not a whole lot of oil, but some. I can't take the brake shoes out because I don't have the special wrench, but I turned the cam and they seem to apply & release. The inside of the clutch drum seems to be worn a little & I can see some copper in spots. The clutch pads seem to be worn funny. Most of the pad is white, but a triangular patch on the edge seems to be worn. I don't know if this is normal breakin or not. Could definitely use a second opinion.
Related Models
Whirlpool LSN1000PQ0 AUTOMATIC WASHER
Whirlpool LSN1000PQ1 AUTOMATIC WASHER
Whirlpool LSN1000PQ2 AUTOMATIC WASHER
Whirlpool LSN1000PQ3 AUTOMATIC WASHER
 LSN120HE Air Conditioner
 LSN122CE Air Conditioner
 LSN122HE Air Conditioner
 LSN180HE Air Conditioner
 LSN182CE Air Conditioner
 LSN182HE Air Conditioner
Whirlpool LSN2000JQ0 WASHER
Whirlpool LSN2000JQ1 WASHER
Whirlpool LSN2000JQ2 WASHER
Whirlpool LSN2000JT0 WASHER
Whirlpool LSN2000JT1 WASHER
Whirlpool LSN2000JT2 WASHER
Whirlpool LSN2000LG0 WASHER - DIRECT DRIVE
Whirlpool LSN2000LG1 AUTOMATIC WASHER
Whirlpool LSN2000LW0 WASHER - DIRECT DRIVE
Whirlpool LSN2000LW1 AUTOMATIC WASHER
Whirlpool LSN2000PG0 AUTOMATIC WASHER
Whirlpool LSN2000PG1 AUTOMATIC WASHER
Whirlpool LSN2000PG2 AUTOMATIC WASHER
Whirlpool LSN2000PG3 AUTOMATIC WASHER
Whirlpool LSN2000PG4 AUTOMATIC WASHER
Whirlpool LSN2000PW0 AUTOMATIC WASHER
Whirlpool LSN2000PW1 AUTOMATIC WASHER
Whirlpool LSN2000PW2 AUTOMATIC WASHER
Whirlpool LSN2000PW3 AUTOMATIC WASHER
Whirlpool LSN2000PW4 AUTOMATIC WASHER
 LSN240HE Air Conditioner
 LSN242CE Air Conditioner
 LSN242HE Air Conditioner
Whirlpool LSN3000PG0 AUTOMATIC WASHER
Whirlpool LSN3000PG1 AUTOMATIC WASHER
Whirlpool LSN3000PG2 AUTOMATIC WASHER
Whirlpool LSN3000PG3 AUTOMATIC WASHER
Whirlpool LSN3000PG4 AUTOMATIC WASHER
Whirlpool LSN3000PW0 AUTOMATIC WASHER
Whirlpool LSN3000PW1 AUTOMATIC WASHER
Whirlpool LSN3000PW2 AUTOMATIC WASHER
Whirlpool LSN3000PW3 AUTOMATIC WASHER
Whirlpool LSN3000PW4 AUTOMATIC WASHER
 LSN301HE Air Conditioner
Whirlpool LSN7233BN0
Whirlpool LSN7233BN1
Whirlpool LSN7233BQ0
Whirlpool LSN7233BQ1
Whirlpool LSN7233BW0
Whirlpool LSN7233BW1
Whirlpool LSN7233DQ0
Whirlpool LSN7233DW0
Whirlpool LSN8244AN0
Whirlpool LSN8244AQ0
Whirlpool LSN8244AW0
Whirlpool LSN8244BN0
Whirlpool LSN8244BQ0
Whirlpool LSN8244BW0
 LSNC183VMA Air Conditioner
 LSNJ0910CL Air Conditioner
Whirlpool LSP6244AG0
Whirlpool LSP6244AN0
Whirlpool LSP6244AW0
Whirlpool LSP6244BG0
Whirlpool LSP6244BN0
Whirlpool LSP6244BW0
Whirlpool LSP8244BG0
Whirlpool LSP8244BG1
Whirlpool LSP8244BN0
Whirlpool LSP8244BN1
Whirlpool LSP8244BW0
Whirlpool LSP8244BW1
Whirlpool LSP8245AN0
Whirlpool LSP8245AW0
Whirlpool LSP8245BN0
Whirlpool LSP8245BW0
Whirlpool LSP9245BN0
Whirlpool LSP9245BN1
Whirlpool LSP9245BW0
Whirlpool LSP9245BW1
Whirlpool LSP9355AG0
Whirlpool LSP9355AN0
Whirlpool LSP9355AW0
Whirlpool LSP9355BN0 AUTOMATIC WASHER
Whirlpool LSP9355BN1
Whirlpool LSP9355BW0 AUTOMATIC WASHER
Whirlpool LSP9355BW1
Whirlpool LSQ7030KQ0 WASHER
Whirlpool LSQ7030LQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ7030LT0 WASHER - DIRECT DRIVE
Whirlpool LSQ7030MQ0 AUTOMATIC WASHER
Whirlpool LSQ7533JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ7533JQ1 WASHER
Whirlpool LSQ7533JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSQ7533JT1 WASHER
Whirlpool LSQ8000HQ0 WASHER
Whirlpool LSQ8000JQ0 WASHER
Whirlpool LSQ8000JQ1 WASHER
Whirlpool LSQ8000LQ0 WASHER
Whirlpool LSQ8000LQ1 AUTOMATIC WASHER
Whirlpool LSQ8000LQ2 AUTOMATIC WASHER
Whirlpool LSQ8000LQ3 AUTOMATIC WASHER
Whirlpool LSQ8200HQ0 AUTOMATIC WASHER
Whirlpool LSQ8200HZ0 AUTOMATIC WASHER
Whirlpool LSQ8220HQ0 AUTOMATIC WASHER
Whirlpool LSQ8243HQ0 AUTOMATIC WASHER
Whirlpool LSQ8243HZ0 AUTOMATIC WASHER
Whirlpool LSQ8500JQ0 AUTOMATIC WASHER
Whirlpool LSQ8500JQ1 WASHER
Whirlpool LSQ8500JQ2 WASHER
Whirlpool LSQ8500JT0 AUTOMATIC WASHER
Whirlpool LSQ8500JT1 WASHER
Whirlpool LSQ8500JT2 WASHER
Whirlpool LSQ8500LQ0 AUTOMATIC WASHER
Whirlpool LSQ8510LQ0 AUTOMATIC WASHER
Whirlpool LSQ8511KQ0 WASHER - DIRECT DRIVE
Whirlpool LSQ8511KT0 WASHER - DIRECT DRIVE
Whirlpool LSQ8512KQ0 WASHER
Whirlpool LSQ8512KT0 WASHER
Whirlpool LSQ8520JQ0 AUTOMATIC WASHER
  #2 (permalink)
Old 04-14-2013, 01:03 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Where did you buy the clutch from? How much was the cost?
Eric
  #3 (permalink)
Old 04-14-2013, 01:11 PM
Junior Member
Default
From e bay, I think it may have been around $20
  #4 (permalink)
Old 04-14-2013, 03:20 PM
Expert
APP Volunteer
Default
Ok, hard to say. Many people get these clutches from amazon for $8 and they are not genuine Whirlpool parts and only last for a few loads. They are cheap junk parts. If it came in a sealed plastic package with the Whirlpool FSP logo, it may be genuine but these clutches generally go for around $35. Oil in the clutch is not good and needs to be fixed. You would need to replace the seals unless the oil is coming from the spin tube but the question is, is where is the clunk noise coming from? Could be the brakes grabbing, something in the gearcase or bearings in the spin tube or centerpost.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore refrigerator clunks tempojjj Refrigerator & Freezer Repair 0 04-05-2013 06:53 AM
Catalyst Elite Washer Clunks proton32176 Washer Repair 11 02-24-2012 10:23 PM
compressor clunks from inside unit jimr0026 Refrigerator & Freezer Repair 0 01-04-2012 11:50 PM
Maytag Dryer clunks then stops slalomskie Dryer Repair 1 11-09-2009 03:35 AM
Whirlpool LSR5233AWO clunks while agitating 9k2164s Washer Repair 2 07-20-2009 09:19 AM
