Register | FAQ's | New Posts | Today's Posts | Extras |
» Amana Washer leaking from center |
![]() Model Number: ALW895SAW Brand: Amana Age: More than 10 years
![]() Hello, My washer is leaking from the very center of the machine. I have parts for replacing the R9900457, & R9900189. I am having trouble getting the bolts holding the inner tub out and I also notice the agitator dogs are broken and will not move. All the videos show a different type of agitator dog setup. So far mine in this order: agitator(one piece) then the bell drive. Next I see the top of the seal the agitator dogs then the inner tub hub. I believe the bolts for the inner tub need to go counter clockwise to remove. I have sprayed with WD-40 and left overnight no budging. Any suggestions? As I said before the videos are for a different type of agitator dogs. Do you know the part number for the dogs and the ring that they are connected too? Because from what I can see it is some sort of ring. Do I remove the agitator dogs/ring before removing the inner tub or after? I am getting frustrated because everything I look at doesn't seem to match with what my machine looks like. I need to get this fixed my washing is piling up and I have other things need fixing. ![]() Any help would be greatly appreciated. Glenda Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Quote:
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Amana 33541R2 washer leaking | rubee | Washer Repair | 1 | 01-27-2011 06:30 PM |
Amana Washer leaking from bottom | gricodrywall | Washer Repair | 1 | 01-20-2010 09:57 AM |
Leaking Amana Washer | cthurston | Washer Repair | 1 | 08-21-2008 02:47 PM |
amana washer leaking at tub seal | transam | Washer Repair | 0 | 08-13-2008 08:12 PM |
Leaking Amana Washer | Mikee | Washer Repair | 3 | 12-31-2007 12:50 PM |
