Discuss
Agitator issues
 in
Washer Repair
I have a whirlpool washer LA8800xsw2 with an agitator problem. I replaced the dogs and it worked for a while
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Agitator issues
  #1 (permalink)
Old 04-11-2013, 07:21 PM
Junior Member
rushhour70 is on a distinguished road
Default Agitator issues
Model Number: LA8800xsw2   Brand: Whirlpool   Age: More than 10 years
I have a whirlpool washer LA8800xsw2 with an agitator problem. I replaced the dogs and it worked for a while but wore them out again. I noticed the center flat portion in the upper section (sits on the thrust spacer and holds the cam and dogs centered) is wearing thin and the top portion has a lot of play wiggling side to side. I am replacing the top mover agitator part to take care of the wore out portion, new dogs and cam, thrust spacer, etc. But my main question is, how big should the plastic ring be on the lower agitator base where the upper portion fits around (lip about 1/3 the way down the column on part#9 of the agitator parts diagram) ? should that fit the upper portion fairly close so there isn't much play to wiggle? My ring only sticks maybe 1/16" or so more than the rest of the tube of the lower portion. If that is supposed to be a closer fit, then my ring may be wore down and the upper agitator will be able to rock around and side to side which would wear it out again. The lower agitator spline is good and it fits on the shaft snuggly so I don't want to buy another lower portion if I don't need to but don't want the upper parts wearing out pre-maturely if the lower portion is actually wore out and does need replacing.
Related Models
Whirlpool LA8800XSW2
Whirlpool LA8800XTF0
Whirlpool LA8800XTF1
Whirlpool LA8800XTG0
Whirlpool LA8800XTG1
Whirlpool LA8800XTM0
Whirlpool LA8800XTM1
Whirlpool LA8800XTN0
Whirlpool LA8800XTN1
Whirlpool LA8800XTW0
Whirlpool LA8800XTW1
Maytag LA882 WASHER-TOP LOADING
Maytag LA8820 WASHER-TOP LOADING
Maytag LA883 WASHER-TOP LOADING
Maytag LA884 WASHER-TOP LOADING
Maytag LA8840 WASHER-TOP LOADING
Whirlpool LA8860XWQ0
Whirlpool LA9100XTF0
Whirlpool LA9100XTF1
Whirlpool LA9100XTG0
Whirlpool LA9100XTG1
Whirlpool LA9100XTM0
Whirlpool LA9100XTM1
Whirlpool LA9100XTN0
Whirlpool LA9100XTN1
Whirlpool LA9100XTW0
Whirlpool LA9100XTW1
Maytag LA9200 WASHER-TOP LOADING
Whirlpool LA9200XWF0
Whirlpool LA9200XWF1
Whirlpool LA9200XWG0
Whirlpool LA9200XWG1
Whirlpool LA9200XWM0
Whirlpool LA9200XWM1
Whirlpool LA9200XWN0
Whirlpool LA9200XWN1
Whirlpool LA9200XWW0
Whirlpool LA9200XWW1
Maytag LA9300 WASHER-TOP LOADING
Whirlpool LA9300XTF0
Whirlpool LA9300XTF1
Whirlpool LA9300XTG0
Whirlpool LA9300XTG1
Whirlpool LA9300XTM0
Whirlpool LA9300XTM1
Whirlpool LA9300XTN0
Whirlpool LA9300XTN1
Whirlpool LA9300XTW0
Whirlpool LA9300XTW1
Whirlpool LA9300XYG0
Whirlpool LA9300XYN0
Whirlpool LA9300XYW0
Whirlpool LA9320XTW0
Whirlpool LA9320XTW1
Whirlpool LA9320XYW0
Maytag LA9400 WASHER-TOP LOADING
Maytag LA9400S WASHER-TOP LOADING
Maytag LA9400W WASHER-TOP LOADING
Whirlpool LA9480XWF0
Whirlpool LA9480XWF1
Whirlpool LA9480XWF2
Whirlpool LA9480XWG0
Whirlpool LA9480XWG1
Whirlpool LA9480XWG2
Whirlpool LA9480XWM0
Whirlpool LA9480XWM1
Whirlpool LA9480XWM2
Whirlpool LA9480XWN0
Whirlpool LA9480XWN1
Whirlpool LA9480XWN2
Whirlpool LA9480XWW0
Whirlpool LA9480XWW1 Washers*
Whirlpool LA9480XWW2
Whirlpool LA9500XTF0 AUTOMATIC WASHER
Whirlpool LA9500XTF1 AUTOMATIC WASHER
Whirlpool LA9500XTG0 AUTOMATIC WASHER
Whirlpool LA9500XTG1 AUTOMATIC WASHER
Whirlpool LA9500XTM0 AUTOMATIC WASHER
Whirlpool LA9500XTM1 AUTOMATIC WASHER
Whirlpool LA9500XTN0 AUTOMATIC WASHER
Whirlpool LA9500XTN1 AUTOMATIC WASHER
Whirlpool LA9500XTW0
Whirlpool LA9500XTW1
Whirlpool LA9580XWF0
Whirlpool LA9580XWF1
Whirlpool LA9580XWG0
Whirlpool LA9580XWG1
Whirlpool LA9580XWM0
Whirlpool LA9580XWM1
Whirlpool LA9580XWN0
Whirlpool LA9580XWN1
Whirlpool LA9580XWW0
Whirlpool LA9580XWW1
Maytag LA9600 WASHER-TOP LOADING
Whirlpool LA9680XWF0
Whirlpool LA9680XWF1
Whirlpool LA9680XWG0
Whirlpool LA9680XWG1
Whirlpool LA9680XWM0
Whirlpool LA9680XWM1
Whirlpool LA9680XWN0
Whirlpool LA9680XWN1
Whirlpool LA9680XWW0
Whirlpool LA9680XWW1
Maytag LA9700 WASHER-TOP LOADING
Maytag LA9700S WASHER-TOP LOADING
Maytag LA9700W WASHER-TOP LOADING
Maytag LA9800 WASHER-TOP LOADING
Whirlpool LA9800XKW1
Whirlpool LA9800XKW2
Whirlpool LA9800XMW0
Whirlpool LA9800XPW0
Whirlpool LA9800XPW1
Whirlpool LA9800XSN1 AUTOMATIC WASHER
Whirlpool LA9800XSN2 AUTOMATIC WASHER
Whirlpool LA9800XSW1
Whirlpool LA9800XSW2
Whirlpool LA9800XTF0 AUTOMATIC WASHER
Whirlpool LA9800XTF1 AUTOMATIC WASHER
Whirlpool LA9800XTG0 AUTOMATIC WASHER
  #2 (permalink)
Old 04-12-2013, 02:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by rushhour70 View Post
...I replaced the dogs and it worked for a while but wore them out again...
Hello,
Have you replaced just the agitator dogs or you used the agitator repair kit?
Have you tighten the agitator bolt (#8 at the diagram)?
gene.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 04-15-2013, 10:58 AM
Junior Member
Default
I only replaced the dogs originally but did tighten the bolt. The "platform" that the bolt goes through to tighten the upper agitator to the shaft coming through the lower base agitator is what was wore through on some of the edges and I'm assuming partly due to wear and play in the fit of the agitator on top over the lower portion. I have replaced the complete top agitator, the thrust spacer sleeve, dogs and cam (complete repair kit). That's when putting it back together noticed there is still a lot of room for the top agitator to "wobble" on the lower portion - which to me could result in wearing out that "platform" I mentioned above that happened to the old one. I really just wanted to know if its normal to have quite a bit of wobble (if you push the top agitator to the side) or should it fit more snugly over the lower base portion? Or is it likely the plastic ring that sticks out on the column of the lower base (all one piece) is wore down some allowing the sloppy fit? If I knew how much that ring should protrude from the column (how much it sticks out?, or diameter of the "ring" vs the column, etc) I would be able to determine if mine is OK or if I need to replace the lower base agitator - Don't want to buy another base just to find out mine is OK and the loose fit is normal.
  #4 (permalink)
Old 04-15-2013, 02:05 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If you installed all parts included in the agitator repair kit correctly, I don't think it will be any problems.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cannot Separate the Upper Agitator (mover) from the Lower Agitator Celodea Washer Repair 3 11-20-2013 11:31 AM
maytag agitator issues Rob 2 Washer Repair 1 04-16-2012 11:05 AM
Agitator issues deb1809 Washer Repair 1 05-23-2011 07:56 AM
issues with agitator and drum maytagh8r Washer Repair 1 04-21-2011 06:47 PM
Agitator issues...HELP Mr.Maintenance Washer Repair 5 10-19-2009 05:36 AM
