Discuss
doesn't spin inpermanent press
 in
Washer Repair
I have a Sears laundry center (stack) that drains fine, you can hear the pump but it only spins in
Appliance Repair Forum > Appliance Repair Help > Washer Repair » doesn't spin inpermanent press
  #1 (permalink)
Old 04-11-2013, 01:43 PM
Junior Member
mgfish is on a distinguished road
Default doesn't spin inpermanent press
Model Number: 41798702891   Brand: -brand-   Age: 1 - 5 years
I have a Sears laundry center (stack) that drains fine, you can hear the pump but it only spins in delicate, not in regular or permanent press, washes fine.
Help, the wife needs it fixed
Bob
Related Models
Kenmore 41798702891 LAUNDRY CENTER
Kenmore 41798702892 LAUNDRY CENTER
Kenmore 41798802890 LAUNDRY CENTER
Kenmore 41798802891 LAUNDRY CENTER
Kenmore 41798804890 LAUNDRY CENTER
Kenmore 41798804891 LAUNDRY CENTER
Kenmore 41798862890 LAUNDRY CENTER
Kenmore 41798862891 LAUNDRY CENTER
Kenmore 41798864890 LAUNDRY CENTER
Kenmore 41798864891 LAUNDRY CENTER
Kenmore 41798988100 ELECTRIC DRYER
Kenmore 41798988110 ELECTRIC DRYER
Kenmore 41798988120 ELECTRIC DRYER
Kenmore 41798988130 ELECTRIC DRYER
Kenmore 41798988140 ELECTRIC DRYER
Kenmore 41798988150 ELECTRIC DRYER
Kenmore 41798988800 ELECTRIC DRYER
Kenmore 41798988810 ELECTRIC DRYER
Kenmore 41798988820 ELECTRIC DRYER
Kenmore 41798988830 ELECTRIC DRYER
Kenmore 41798988840 ELECTRIC DRYER
Kenmore 41798988850 ELECTRIC DRYER
Kenmore 41798989100 GAS DRYER
Kenmore 41798989110 GAS DRYER
Kenmore 41798989120 GAS DRYER
Kenmore 41798989130 GAS DRYER
Kenmore 41798989140 GAS DRYER
Kenmore 41798989150 GAS DRYER
Kenmore 41798989800 GAS DRYER
Kenmore 41798989810 GAS DRYER
Kenmore 41798989820 GAS DRYER
Kenmore 41798989830 GAS DRYER
Kenmore 41798989840 GAS DRYER
Kenmore 41798989850 GAS DRYER
Kenmore 41799160100 LAUNDRY CENTER
Kenmore 41799160110 LAUNDRY CENTER
Kenmore 41799160120 LAUNDRY CENTER
Kenmore 41799160130 LAUNDRY CENTER
Kenmore 41799160800 LAUNDRY CENTER
Kenmore 41799160810 LAUNDRY CENTER
Kenmore 41799160820 LAUNDRY CENTER
Kenmore 41799160830 LAUNDRY CENTER
Kenmore 41799165100 LAUNDRY CENTER
Kenmore 41799165110 LAUNDRY CENTER
Kenmore 41799165120 LAUNDRY CENTER
Kenmore 41799165130 LAUNDRY CENTER
Kenmore 41799165800 LAUNDRY CENTER
Kenmore 41799165810 LAUNDRY CENTER
Kenmore 41799165820 LAUNDRY CENTER
Kenmore 41799165830 LAUNDRY CENTER
Kenmore 41799170100 LAUNDRY CENTER
Kenmore 41799170110 LAUNDRY CENTER
Kenmore 41799170120 LAUNDRY CENTER
Kenmore 41799170800 LAUNDRY CENTER
Kenmore 41799170810 LAUNDRY CENTER
Kenmore 41799170820 LAUNDRY CENTER
Kenmore 41799175100 LAUNDRY CENTER
Kenmore 41799175110 LAUNDRY CENTER
Kenmore 41799175120 LAUNDRY CENTER
Kenmore 41799175800 LAUNDRY CENTER
Kenmore 41799175810 LAUNDRY CENTER
Kenmore 41799175820 LAUNDRY CENTER
Kenmore 41799180100 GAS AND ELECTRIC LAUNDRY CENTER
Kenmore 41799180110 LAUNDRY CENTER
Kenmore 41799180120 LAUNDRY CENTER
Kenmore 41799180800 GAS AND ELECTRIC LAUNDRY CENTER
Kenmore 41799180810 LAUNDRY CENTER
Kenmore 41799180820 LAUNDRY CENTER
Kenmore 41799185100 LAUNDRY CENTER
Kenmore 41799185110 27" LAUNDRY CENTER
Kenmore 41799185120 LAUNDRY CENTER
Kenmore 41799185800 LAUNDRY CENTER
Kenmore 41799185810 27" LAUNDRY CENTER
Kenmore 41799185820 LAUNDRY CENTER
Kenmore 41799190100 LAUNDRY CENTER
Kenmore 41799190110 27" LAUNDRY CENTER
Kenmore 41799190120 LAUNDRY CENTER
Kenmore 41799190800 LAUNDRY CENTER
Kenmore 41799190810 27" LAUNDRY CENTER
Kenmore 41799190820 LAUNDRY CENTER
Kenmore 41799195100 LAUNDRY CENTER
Kenmore 41799195110 LAUNDRY CENTER
Kenmore 41799195120 LAUNDRY CENTER
Kenmore 41799195800 LAUNDRY CENTER
Kenmore 41799195810 LAUNDRY CENTER
Kenmore 41799195820 LAUNDRY CENTER
Kenmore 41799370100 LAUNDRY CENTER
Kenmore 41799370110 LAUNDRY CENTER
Kenmore 41799370120 LAUNDRY CENTER
Kenmore 41799370130 LAUNDRY CENTER
Kenmore 41799370800 LAUNDRY CENTER
Kenmore 41799370810 LAUNDRY CENTER
Kenmore 41799370820 LAUNDRY CENTER
Kenmore 41799370830 LAUNDRY CENTER
Kenmore 41799375100 LAUNDRY CENTER
Kenmore 41799375110 27" LAUNDRY CENTER
Kenmore 41799375120 LAUNDRY CENTER
Kenmore 41799375800 LAUNDRY CENTER
Kenmore 41799375810 27" LAUNDRY CENTER
Kenmore 41799375820 LAUNDRY CENTER
Kenmore 41799390100 LAUNDRY CENTER
Kenmore 41799390110 LAUNDRY CENTER
Kenmore 41799390120 27" LAUNDRY CENTER
Kenmore 41799390130 LAUNDRY CENTER
Kenmore 41799390800 LAUNDRY CENTER
Kenmore 41799390810 LAUNDRY CENTER
Kenmore 41799390820 27" LAUNDRY CENTER
Kenmore 41799390830 LAUNDRY CENTER
Kenmore 41799395100 LAUNDRY CENTER
Kenmore 41799395110 LAUNDRY CENTER
Kenmore 41799395120 LAUNDRY CENTER
Kenmore 41799395800 LAUNDRY CENTER
Kenmore 41799395810 LAUNDRY CENTER
Kenmore 41799395820 LAUNDRY CENTER
Kenmore 41799463100 LAUNDRY CENTER
Kenmore 41799463110 LAUNDRY CENTER
Kenmore 41799463120 LAUNDRY CENTER
Kenmore 41799463800 LAUNDRY CENTER
Kenmore 41799463810 LAUNDRY CENTER
Kenmore 41799463820 LAUNDRY CENTER
  #2 (permalink)
Old 04-11-2013, 05:46 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Based on your description it's most likely the timer or the motor.
You can check the motor if you have a multimeter and feel comfortable to do the life test.
Remove the front panel, get to the motor contacts.
With the washer set to Drain check between RED (M6) and BLUE/WH (M3) for 120VAC.
If the correct voltage is present - replace the motor
Part number: AP3219511
If not - replace the timer
Part number: AP2106881
If you will get the parts from APP then according to our policy you can return any parts thart you don't need back.No question asked.
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore series 90 washer won't spin in Perm Press cycle ozbirn Washer Repair 6 02-10-2013 06:11 PM
Washing Machine doesn't advance to spin in Ultra Clean mode but does OK in Perm Press ashlynhall Washer Repair 0 03-01-2012 03:22 PM
Permanent Press Cycle pmoyer Washer Repair 1 07-20-2011 07:03 PM
dryer will not spin, makes loud pop when you press start usafbuckeye67 Dryer Repair 0 05-03-2010 09:04 AM
panel says press any key, nothing happens megan@behmke.net Dishwasher Repair 0 12-03-2009 04:58 AM
