Discuss
washer
 in
Washer Repair
to count led blinks How do I know if motor is bad can i put unit in service mode? Related
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer
  #1 (permalink)
Old 04-08-2013, 07:15 PM
Junior Member
Elwyn is on a distinguished road
Default washer
Model Number: wpre6150k1wt   Brand: GE   Age: 1 - 5 years
to count led blinks
Related Models
General Electric WPRE6150K1WT WASHER
General Electric WPRE6150K2WT WASHER
General Electric WPRE6150K3WT WASHER
General Electric WPRE6280D1WW Washer
General Electric WPRE6280DCWW Washer
General Electric WPRE8100G0WT Washer
General Electric WPRE8100G1WT WASHER
General Electric WPRE8150H0WT WASHER
General Electric WPRE8150H1WT WASHER
General Electric WPRE8150H2WT WASHER
General Electric WPRE8150K0WT WASHER
General Electric WPRE8150K1WT WASHER
General Electric WPRE8150K2WT WASHER
General Electric WPRE8150K3WT WASHER
General Electric WPRE8320H2WT WASHER
General Electric WPRE8320H3WT WASHER
General Electric WPRE8350H0WT WASHER
General Electric WPRE8350H1WT WASHER
General Electric WPRE8350H2WT WASHER
General Electric WPSB8060B0CC Washer
General Electric WPSB8060B0WW Washer
General Electric WPSB8060B1CC Washer
General Electric WPSB8060B1WW Washer
General Electric WPSB8060B9CC Washer
General Electric WPSB8060B9WW Washer
General Electric WPSB9080B0CC Washer
General Electric WPSB9080B0WW Washer
General Electric WPSB9120B0CC Washer
General Electric WPSB9120B0WW Washer
General Electric WPSE3120Y1WW Washer
General Electric WPSE4200A0AA Washer
General Electric WPSE4200A0WW Washer
General Electric WPSE4270A0AA Washer
General Electric WPSE4270A0WW Washer
General Electric WPSE5290A0AA Washer
General Electric WPSE5290A0WW Washer
General Electric WPSE7001A0AA Washer
General Electric WPSE7001A0WW Washer
General Electric WPSE7002A0AA Washer
General Electric WPSE7002A0WW Washer
General Electric WPSE7003A0AA Washer
General Electric WPSE7003A0WW Washer
General Electric WPSE7003A1WW Washer
General Electric WPSE7003A9WW Washer
General Electric WPSE7003B9WW Washer
General Electric WPSF4170V0AA Washer
General Electric WPSF4170V0WW Washer
General Electric WPSF4170V1AA Washer
General Electric WPSF4170V1WW Washer
General Electric WPSF4170W0AA Washer
General Electric WPSF4170W0WW Washer
General Electric WPSF4170W1AA Washer
General Electric WPSF4170W1WW Washer
General Electric WPSF4170W2AA Washer
General Electric WPSF5170W0AA Washer
General Electric WPSF5170W0WW Washer
General Electric WPSF5170W1AA Washer
General Electric WPSF5170W1WW Washer
Whirlpool WPSHAW0 PURE DELIVERY WATER PUMP
General Electric WPSL3120W0WW Washer
General Electric WPSL3120W2WW Washer
General Electric WPSP4170W0WW Washer
General Electric WPSP4170W1WW Washer
General Electric WPSQ3120T2AA Washer
General Electric WPSQ3120T2WW Washer
General Electric WPSQ3120T5AA Washer
General Electric WPSQ3120T5WW Washer
General Electric WPSQ3120T6AA Washer
General Electric WPSQ3120T6WW Washer
General Electric WPSQ3120T8AA Washer
General Electric WPSQ3120T8WW Washer
General Electric WPSQ3120T9AA Washer
General Electric WPSQ3120T9WW Washer
General Electric WPSQ3120TAAA Washer
General Electric WPSQ3120TAWW Washer
General Electric WPSQ4160T2AA Washer
General Electric WPSQ4160T2WW Washer
General Electric WPSQ4160T5AA Washer
General Electric WPSQ4160T5WW Washer
General Electric WPSQ4160T6AA Washer
General Electric WPSQ4160T6WW Washer
General Electric WPSQ4160T7AA Washer
General Electric WPSQ4160T7WW Washer
General Electric WPSQ4160T8AA Washer
General Electric WPSQ4160T8WW Washer
General Electric WPSQ4160T9AA Washer
General Electric WPSQ4160T9WW Washer
General Electric WPSQ4160TAAA Washer
General Electric WPSQ4160TAWW Washer
General Electric WPSR3090V0AA Washer
General Electric WPSR3090V0WW Washer
General Electric WPSR3090V1AA Washer
General Electric WPSR3090V1WW Washer
General Electric WPSR3100W0AA Washer
General Electric WPSR3100W0WW Washer
General Electric WPSR3100W1AA Washer
General Electric WPSR3100W1WW Washer
General Electric WPSR3100W2AA Washer
General Electric WPSR3100W2WW Washer
General Electric WPSR3120W0AA Washer
General Electric WPSR3120W0WW Washer
General Electric WPSR3120W1AA Washer
General Electric WPSR3120W1WW Washer
General Electric WPSR3120W2AA Washer
General Electric WPSR3120W2WW Washer
General Electric WPSR4130W0AA Washer
General Electric WPSR4130W0WW Washer
General Electric WPSR4130W1AA Washer
General Electric WPSR4130W1WW Washer
General Electric WPXH214A0CC Washer
General Electric WPXH214A0WW Washer
General Electric WPXH214F0CC Washer
General Electric WPXH214F0WW Washer
General Electric WPXH214F1CC Washer
General Electric WPXH214F1WW Washer
General Electric WPXQ3090T2AA Washer
General Electric WPXQ3090T2WW Washer
General Electric WPXQ3090T5AA Washer
General Electric WPXQ3090T5WW Washer
General Electric WPXQ3090T6AA Washer
  #2 (permalink)
Old 04-09-2013, 07:05 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
There's no service mode for the motor/inverter. Check the LED on the top right side of the inverter board on top of the motor. In normal standby mode, it will flash on/off every second. With the washer running, it will flash on/off every half second. If there is an error code, it will flash at a 1/4 second rate with the number of flashes in a 6 second period depending on the error. If for example there is a mode shifter fault, it will flash 4 times quickly and then remain off until the end of the 6 second period. There is a service mode for the control board at the top of the washer behind the control panel. There should be a tech sheet tucked behind the control panel with instructions on using service mode. It will show any other error codes and allow you to go through the various functions of the washer directly.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
