Discuss
Maytag washer not agitating in the wash or rinse cycle
 in
Washer Repair
My Maytag Bravos MCT washing machine (toploading but with the same technology as the frontloaders) is not working how it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer not agitating in the wash or rinse cycle
  #1 (permalink)
Old 04-07-2013, 12:29 PM
Junior Member
kstev is on a distinguished road
Default Maytag washer not agitating in the wash or rinse cycle
Brand: Maytag   Age: 1 - 5 years
My Maytag Bravos MCT washing machine (toploading but with the same technology as the frontloaders) is not working how it should.
When it gets to the wash cycle, after filling with water it just sits until the time completes and then moves to the rinse cycle. It also does not agitate in the rinse cycle.
I have found that if I push pause, and then restart it while in the wash cycle, then it will agitate. Same in the rinse cycle......but it won't do it unless I pause and restart.
It is also not draining spinning when it should. I usually have to turn it to the drain/spin cycle separate when the washing is complete, otherwise the clothes are so wet they would never dry.
What do you think this is?
  #2 (permalink)
Old 04-08-2013, 05:27 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Sounds like a control unit issue. I would try replacing it and see if that fixes things. If you buy from this site and the part does not fix the problem you can return it.
If you need more information please post a full model number so we can see exactly what model you have.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Not Agitating Properly in Wash Cycle bdamia Washer Repair 1 08-11-2011 07:08 PM
Whirlpool washer won't automatically switch from wash cycle to rinse cycle WEED Washer Repair 2 07-21-2010 08:49 AM
Maytag stopped agitating during wash cycle zetlan Washer Repair 1 01-19-2010 05:37 PM
Washer not agitating in wash cycle mybrokenwasher Washer Repair 1 10-05-2009 06:38 PM
Washer fills on wash cycle and rinse cycle and won't stop filling! riphinney Washer Repair 15 03-12-2008 05:30 PM
