Discuss
Is it just a worn belt
 in
Washer Repair
I had been having problems with the washer spinning slowly or for short times, leaving water in the tub. Finally
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Is it just a worn belt
  #1 (permalink)
Old 04-06-2013, 01:22 PM
Junior Member
larrylorenz is on a distinguished road
Default Is it just a worn belt
Model Number: MAH4000AWW   Brand: Maytag   Age: More than 10 years
I had been having problems with the washer spinning slowly or for short times, leaving water in the tub. Finally the belt came off. I noticed the edge of the belt worn and it had apparently been riding the drive pulley toward the drum to the point that it had cut a groove in the drum ribs. I can spin the drive pulley by hand - it seems a bit tight but I have nothing to guage what too tight might be. Is this problem with the belt riding off the pulley likely just the belt (original) or would the drum bearing be a likely cause?
(2 days later) After some more troubleshooting I noticed that there were rubbing sounds and an occasional grinding rattle sound. The motor seemed to be laboring a lot for an empty tub. I found that I could lift the spin basket which shows about a half inch play in the drive pulley. With the pulley tipped this much it makes perfect sense to me why it rode toward the tub. At this point it appears that the problem is the bearing. At a price of $550 or more for the parts and descriptions of the effort required to replace the tub I think it is probably time to give up and hunt for a new washer.
Related Models
Maytag MAH4000AWW WASHER- HORIZONTAL AXIS
Maytag MAH4000BWQ WASHER- HORIZONTAL AXIS
Maytag MAH4000BWW WASHER- HORIZONTAL AXIS
Maytag MAH5500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH5500AWW WASHER- HORIZONTAL AXIS
Maytag MAH5500BWQ WASHER- HORIZONTAL AXIS
Maytag MAH5500BWW WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWQ WASHER- HORIZONTAL AXIS
Maytag MAH55FLBWW WASHER- HORIZONTAL AXIS
Maytag MAH6500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH6500AWW WASHER- HORIZONTAL AXIS
Maytag MAH6700AWM WASHER- HORIZONTAL AXIS
Maytag MAH6700AWW WASHER- HORIZONTAL AXIS
Maytag MAH7500AWQ WASHER- HORIZONTAL AXIS
Maytag MAH7500AWW WASHER- HORIZONTAL AXIS
Admiral MAH7550AAW WASHER- HORIZONTAL AXIS
Admiral MAH7550AGW WASHER- HORIZONTAL AXIS
Maytag MAH8700AWM WASHER- HORIZONTAL AXIS
Maytag MAH8700AWW WASHER- HORIZONTAL AXIS
Maytag MAH9700AWM WASHER- HORIZONTAL AXIS
Maytag MAH9700AWQ WASHER- HORIZONTAL AXIS
Maytag MAH9700AWW WASHER- HORIZONTAL AXIS
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM MISC / ACCESSORY
Maytag MAL1800AXQ MISC / ACCESSORY
Maytag MAL1800AXW MISC / ACCESSORY
Maytag MAL2000AXQ MISC / ACCESSORY
Maytag MAL2000AXW MISC / ACCESSORY
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL MANUAL, PARTS (WASHER)
Maytag MAT10CSAAW MANUAL, PARTS (WASHER)
Maytag MAT10CSAGL MANUAL, PARTS (WASHER)
Maytag MAT10CSAGW MANUAL, PARTS (WASHER)
Maytag MAT10CSEGL MANUAL, PARTS (WASHER)
Maytag MAT10CSEGW MANUAL, PARTS (WASHER)
Maytag MAT10DAAAL MANUAL, PARTS (WASHER)
Maytag MAT10DAAAW MANUAL, PARTS (WASHER)
Maytag MAT10DAABL MANUAL, PARTS (WASHER)
Maytag MAT10DAABW MANUAL, PARTS (WASHER)
Maytag MAT10PDAAL MANUAL, PARTS (WASHER)
Maytag MAT10PDAAW MANUAL, PARTS (WASHER)
Maytag MAT10PDABL MANUAL, PARTS (WASHER)
Maytag MAT10PDABW MANUAL, PARTS (WASHER)
Maytag MAT10PDEGW MAYTAG LAUNDRY (COMM.EXPORT) (WASHER)
Maytag MAT10PSAAL MANUAL, PARTS (WASHER)
Maytag MAT10PSAAW MANUAL, PARTS (WASHER)
Maytag MAT10PSAGL MANUAL, PARTS (WASHER)
Maytag MAT10PSAGW MANUAL, PARTS (WASHER)
Maytag MAT11CSBKL MANUAL, PARTS (WASHER)
Maytag MAT11MNAAW MANUAL, PARTS (WASHER)
Maytag MAT11MNAGW MANUAL, PARTS (WASHER)
Maytag MAT11MNEGW MANUAL, PARTS (WASHER)
Maytag MAT11PDAAL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDAAW MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABL MAYTAG LAUNDRY (WASHER)
Maytag MAT11PDABW MAYTAG LAUNDRY (WASHER)
Maytag MAT12CSAAL MANUAL, PARTS (WASHER)
Maytag MAT12CSAAQ MANUAL, PARTS (WASHER)
Maytag MAT12CSAAW MANUAL, PARTS (WASHER)
Maytag MAT12CSAGW MANUAL, PARTS (WASHER)
Maytag MAT12CSAKL MANUAL, PARTS (WASHER)
Maytag MAT12CSAKQ MANUAL, PARTS (WASHER)
Maytag MAT12CSDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12CSEGW MANUAL, PARTS (WASHER)
Maytag MAT12CSFWQ COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSFWW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLGW MAYTAG COMMERCIAL WASHER (WASHER)
Maytag MAT12CSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12CSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDAAL MANUAL, PARTS (WASHER)
Maytag MAT12PDAAW MANUAL, PARTS (WASHER)
Maytag MAT12PDABL MANUAL, PARTS (WASHER)
Maytag MAT12PDABW MANUAL, PARTS (WASHER)
Maytag MAT12PDAGW MANUAL, PARTS (WASHER)
Maytag MAT12PDBAL MANUAL, PARTS (WASHER)
Maytag MAT12PDBAQ MANUAL, PARTS (WASHER)
Maytag MAT12PDBAW MANUAL, PARTS (WASHER)
Maytag MAT12PDBBL MANUAL, PARTS (WASHER)
Maytag MAT12PDBBQ WASHER-TOP LOADING
Maytag MAT12PDBBW MANUAL, PARTS (WASHER)
Maytag MAT12PDCBL MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDCBW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDDAQ MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDBW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PDEGW MANUAL, PARTS (WASHER)
Maytag MAT12PDLAQ MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLAW MAYTAG LAUNDRY (WASHER)
Maytag MAT12PDLGW COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PDSAW MANUAL,PARTS (WASHER)
Maytag MAT12PRAAW MANUAL, PARTS (WASHER)
Maytag MAT12PRAEW MANUAL, PARTS (WASHER)
Maytag MAT12PRBAW MANUAL, PARTS (WASHER)
Maytag MAT12PRDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PRSAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAAW MANUAL, PARTS (WASHER)
Maytag MAT12PSAGW MANUAL, PARTS (WASHER)
Maytag MAT12PSBAW MANUAL, PARTS (WASHER)
Maytag MAT12PSDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT12PSLWQ MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT12PSLWW MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAT13MNAAW MANUAL, PARTS (WASHER)
Maytag MAT13MNAGW MANUAL, PARTS (WASHER)
Maytag MAT13MNDAW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNDGW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13MNEGW MANUAL, PARTS (WASHER)
Maytag MAT13PDAAW MANUAL, PARTS (WASHER)
Maytag MAT13PDBAW MANUAL, PARTS (WASHER)
Maytag MAT13PNAEW MAYTAG LAUNDRY (WASHER)
Maytag MAT13PNDEW MANUAL, PARTS LAUNDRY (WASHER)
Maytag MAT13PRBWW MAYTAG LAUNDRY (WASHER)
Maytag MAT14CSAGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSAWW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14CSBGW0 COMMERCIAL AUTOMATIC WASHER
Maytag MAT14PDAWW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool MAT14PDAXW0 COMMERCIAL AUTOMATIC WASHER
  #2 (permalink)
Old 04-08-2013, 05:26 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Good decision
If you got 10 plus years out of this very troubled model you have done very well.
Good luck with your new machine.
__________________
  #3 (permalink)
Old 04-08-2013, 08:28 PM
Junior Member
Default Thanks
Quote:
Originally Posted by sidfink43 View Post
Good decision
It feels good to get some encouragement that I made the right decision.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
grove worn in tub turq66 Washer Repair 7 07-09-2011 01:29 AM
Motor Worn Out? Brainiac Washer Repair 3 05-06-2011 05:42 AM
Touch Pad Worn Out? PeterE Microwave Repair 0 11-06-2010 03:23 PM
Worn out belt or something else? tybeegb Washer Repair 5 04-25-2009 06:22 PM
