Discuss
Roper washer not draining
 in
Washer Repair
I washed some blankets in a Roper RAB4132HQ topload and afterwards the washer didn't drain completely and spin cycle seemed
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper washer not draining
  #1 (permalink)
Old 04-04-2013, 04:53 PM
Junior Member
stevevit is on a distinguished road
Default Roper washer not draining
Model Number: RAB4132HQ   Brand: Roper   Age: 5 - 10 years
I washed some blankets in a Roper RAB4132HQ topload and afterwards the washer didn't drain completely and spin cycle seemed slower than normal. I checked for faulty pump, coupler and clogs and put it together and ran a very small load and it seemed to work. Then next load filled, agitated and would not drain, it does start to spin cycle even when completely filled.
so
The pump is fairly new and spins.
Took motor off and coupler looks good,
Pretty sure there is no clogs.
Lid switch is jumped.
Washer will start spinning when filled with water.
I'm not sure if spin cycle is reaching top speed.
When spin cycle is at top speed to seems to be off balance.
Separated inner tub from plastic tub and checked for debris.
Seems to come to a quick jerky stop (not always).
I'm guessing it's the gearbox, clutch or brake but not sure where to start
Sorry if this question has been asked before, I spent a considerable amount of time trying to find answers without posting.
Related Models
Whirlpool RAB4132HQ0 AUTOMATIC WASHER
Roper RAB4232DL0 AUTOMATIC WASHER
Roper RAB4232DW0 AUTOMATIC WASHER
Roper RAB4232EN0 DIRECT-DRIVE WASHER
Roper RAB4232EN1 WASHER
Roper RAB4232EW0 DIRECT-DRIVE WASHER
Roper RAB4232EW1 WASHER
Roper RAB5133DL0 AUTOMATIC WASHER
Roper RAB5133DW0 AUTOMATIC WASHER
Roper RAB5232EN0 AUTOMATIC WASHER
Roper RAB5232EN1 WASHER
Roper RAB5232EQ1 WASHER
Roper RAB5232EW0 AUTOMATIC WASHER
Roper RAB5232EW1 WASHER
Whirlpool RAC4244AL0
Whirlpool RAC4244AL1
Whirlpool RAC4244AW0
Whirlpool RAC4244AW1
 RAD-123A Air Conditioner
Maytag RAE10 MISC / ACCESSORY
Maytag RAE20 MISC / ACCESSORY
Maytag RAE30 MISC / ACCESSORY
Maytag RAE3100AAX MISC / ACCESSORY
Whirlpool RAE3968P 30" ELECTRIC FREE STANDING RANGE
Maytag RAEA300AAX MISC / ACCESSORY
Roper RAK2751KQ0 WASHER
Whirlpool RAL5144AG0
Whirlpool RAL5144AL0
Whirlpool RAL5144AW0
Whirlpool RAL5144BG0
Whirlpool RAL5144BG1
Whirlpool RAL5144BL0
Whirlpool RAL5144BL1
Whirlpool RAL5144BQ0
Whirlpool RAL5144BQ1
Whirlpool RAL5144BW0
Whirlpool RAL5144BW1
Whirlpool RAL6245AG0
Whirlpool RAL6245AL0
Whirlpool RAL6245AW0
Whirlpool RAL6245BL0
Whirlpool RAL6245BL1
Whirlpool RAL6245BW0
Whirlpool RAL6245BW1
Whirlpool RAM4131AL0
Whirlpool RAM4131AW0
Whirlpool RAM4132BW0
Whirlpool RAM4143AL0
Whirlpool RAM4143AL2
Whirlpool RAM4143AW0
Whirlpool RAM4143AW2
Whirlpool RAM5243AL0
Whirlpool RAM5243AL2
Whirlpool RAM5243AW0
Whirlpool RAM5243AW2
Whirlpool RAP5244AL0
Whirlpool RAP5244AW0
Whirlpool RAP7244DW0
Whirlpool RAR81K0 AIR CONDITIONER
Roper RAS1121EW0 AUTOMATIC WASHER DIRECT-DRIVE
Roper RAS5133EQ0 WASHER
Roper RAS6233JQ0 WASHER
Roper RAS6233KQ0 WASHER
Roper RAS6233KQ1 AUTOMATIC WASHER
Roper RAS6233KQ2 AUTOMATIC WASHER
Roper RAS6233PQ0 AUTOMATIC WASHER
Roper RAS6233PQ1 AUTOMATIC WASHER
Roper RAS6233PQ3 AUTOMATIC WASHER
Roper RAS6233RQ0 AUTOMATIC WASHER
Roper RAS7133KQ0 WASHER
Roper RAS7133KQ1 AUTOMATIC WASHER
Roper RAS7133PQ0 AUTOMATIC WASHER
Roper RAS7133PQ1 AUTOMATIC WASHER
Roper RAS7133RQ0 AUTOMATIC WASHER
Roper RAS7133RQ1 AUTOMATIC WASHER
Roper RAS7133RQ3 AUTOMATIC WASHER
Roper RAS7133RQ4 AUTOMATIC WASHER
Roper RAS7233JQ0 WASHER
Roper RAS7233KQ0 WASHER
Roper RAS8244KQ0 WASHER
Roper RAS8244KQ1 AUTOMATIC WASHER
Roper RAS8244KQ2 AUTOMATIC WASHER
Roper RAS8244LQ0 AUTOMATIC WASHER
Roper RAS8244LQ1 AUTOMATIC WASHER
Roper RAS8245EN0 DIRECT DRIVE WASHER
Roper RAS8245EN1 DIRECT-DRIVE WASHER
Roper RAS8245EQ0 DIRECT DRIVE WASHER
Roper RAS8245EQ1 DIRECT-DRIVE WASHER
Roper RAS8245EW0 DIRECT DRIVE WASHER
Roper RAS8245EW1 DIRECT-DRIVE WASHER
Roper RAS8333PQ0 AUTOMATIC WASHER
Roper RAS8333PQ1 AUTOMATIC WASHER
Roper RAS8333RQ0 AUTOMATIC WASHER
Roper RAS8333RQ1 AUTOMATIC WASHER
Roper RAS8333RQ3 AUTOMATIC WASHER
Roper RAS8333RQ4 AUTOMATIC WASHER
Roper RAS8445JQ0 WASHER
Roper RAS8445KQ0 WASHER
Maytag RAX1000AXW MISC / ACCESSORY
Maytag RAX1000CXB MISC / ACCESSORY
Maytag RAX2000AXW MISC / ACCESSORY
Maytag RAX2000CXB MISC / ACCESSORY
Maytag RAX3000DXX MISC / ACCESSORY
Maytag RAX33 MISC / ACCESSORY
Maytag RAX3300CXX MISC / ACCESSORY
Maytag RAX34 MISC / ACCESSORY
Maytag RAX36 MISC / ACCESSORY
Maytag RAX3600CXX MISC / ACCESSORY
Roper RAX4232JQ0 WASHER
Roper RAX4232KQ0 WASHER
Roper RAX4232KQ1 AUTOMATIC WASHER
Roper RAX4232PQ0 AUTOMATIC WASHER
Roper RAX4232PQ1 AUTOMATIC WASHER
Roper RAX4232RQ0 AUTOMATIC WASHER
Roper RAX4232RQ1 AUTOMATIC WASHER
Roper RAX4232RQ3 AUTOMATIC WASHER
Roper RAX4232RQ4 AUTOMATIC WASHER
Roper RAX4233PQ0 AUTOMATIC WASHER
Maytag RAX5000AXB MISC / ACCESSORY
Maytag RAX5000CXB MISC / ACCESSORY
  #2 (permalink)
Old 04-04-2013, 05:33 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Well, there is a gearcase problem because directly after agitation, it's supposed to drain without spinning. The neutral drain mechanism in the gearcase isn't working. Regardless, even if it goes into drain/spin at the same time, it should still drain. If the motor is running at full speed during drain mode and it isn't draining, either the pump is faulty or there is an obstruction in the drain somewhere. To determine if something is bogging the motor down during drain, remove the motor, remove the motor coupler and replace the motor without it. If it doesn't drain with just the pump attached to the motor, there is definitely a problem with the pump or drain hoses.
Eric
  #3 (permalink)
Old 04-04-2013, 05:41 PM
Junior Member
Default
Thanks for the info! After agitation it does go into a drain mode and doesn't spin, i think it's when I manually turn the know in the middle of a spin cycle. I'll take the coupler out and see what happens - thanks again!
Steve
  #4 (permalink)
Old 04-04-2013, 05:57 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Inadvertant post.
__________________
  #5 (permalink)
Old 04-04-2013, 06:46 PM
Junior Member
Default
I removed the motor and coupler and put it back together and it doesn't drain. I double checked for a clog but all is clear so i guess the pump is not working properly. It seems to spin fine when it's off the washer but maybe it gets cocked and siezes up? I tried to see if the blades would spin while keeping the center locked but it seemed pretty solid. Are some pumps faulty even though they spin free?? The old pump I replaced had a sock in it and wouldn't budge.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper machine not spinning, draining or agitating. p.c. Washer Repair 3 01-06-2013 10:33 AM
Roper Washing Machine, No cycles work, Not draining 13steps Washer Repair 0 05-05-2012 02:27 PM
Roper Washer Not Draining mdfeller Oven Repair (including Ranges and Cooktops) 3 03-24-2009 07:36 PM
Roper Washer Not Draining julieann Oven Repair (including Ranges and Cooktops) 2 11-26-2008 06:21 AM
Roper Dishwasher Not Draining kennyl Dishwasher Repair 1 10-12-2007 06:38 PM
