washer power button, comes on when pushed,lets me select cycle but it will not start up, only beeps ones, nothing happens wash light blinks ones, for a few seconds, then it turns off.:rolleyes:
Originally Posted by: jose cornejo washer power button, comes on when pushed,lets me select cycle but it will not start up, only beeps ones, nothing happens wash light blinks ones, for a few seconds, then it turns off.:rolleyes: Jose', You'll need to remove the lower front access panel (two screws) You should find the Tech Data sheet attached to the inside of the panel. You will be able to conduct the diagnostic error codes and test modes. At this point, the CCU Part number: AP4538443
is not seeing the inputs from the UIC Part number: AP4514840
You'll have it diagnosed in no time once you conduct the tests.
