Discuss
Spin out of control very noisy
 in
Washer Repair
The spin starts before water is pumped out so it causes the water to overflow the tub, and once the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Spin out of control very noisy
  #1 (permalink)
Old 04-04-2013, 04:10 PM
Junior Member
dwoodall is on a distinguished road
Default Spin out of control very noisy
Model Number: CW7500W   Brand: Crosley   Age: 5 - 10 years
The spin starts before water is pumped out so it causes the water to overflow the tub, and once the water is pumped out the spin sounds like its way to fast and very loud. Not like a bearing problem but like a jet out of control!!?
Related Models
Crosley CW7500W WASHER-TOP LOADING
Amana CW76T MWAVE- CNTRTP / STAND ALONE
Crosley CW8000A WASHER-TOP LOADING
Crosley CW8000W WASHER-TOP LOADING
Amana CW8202W2 WASHER-TOP LOADING
Amana CW8203W WASHER-TOP LOADING
Amana CW8203W2 WASHER-TOP LOADING
Amana CW8403W WASHER-TOP LOADING
Amana CW8413W2 WASHER-TOP LOADING
Crosley CW8500W WASHER-TOP LOADING
Amana CW9003 WASHER-TOP LOADING
Amana CW9003W WASHER-TOP LOADING
Amana CW9203W WASHER-TOP LOADING
Amana CW9203W2 WASHER-TOP LOADING
Amana CW9203W3 WASHER-TOP LOADING
Crosley CW9500W WASHER-TOP LOADING
Crosley CW9505W WASHER-TOP LOADING
Maytag CWE1000 WALLOVEN- S/C ELE
Maytag CWE400 WALLOVEN- STD ELE
Maytag CWE401 WALLOVEN- STD ELE
Maytag CWE402 WALLOVEN- STD ELE
Maytag CWE4020ACB WALLOVEN- STD ELE
Maytag CWE4020BCB WALLOVEN- STD ELE
Maytag CWE4100ACB10 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4100ACE10 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4200ACB WALLOVEN- STD ELE
Maytag CWE450 WALLOVEN- STD ELE
Maytag CWE451 WALLOVEN- STD ELE
Maytag CWE470 WALLOVEN- S/C ELE
Maytag CWE4700ACB WALLOVEN- S/C ELE
Maytag CWE4700ACE WALLOVEN- S/C ELE
Maytag CWE4700BCB WALLOVEN- S/C ELE
Maytag CWE4700BCE WALLOVEN- S/C ELE
Maytag CWE4800ACB WALLOVEN- S/C ELE
Maytag CWE4800ACB25 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACE WALLOVEN- S/C ELE
Maytag CWE4800ACE27 24" BUILT-IN ELECTRIC OVEN
Maytag CWE4800ACS WALLOVEN- S/C ELE
Maytag CWE4800ACS14 24" BUILT-IN ELECTRIC OVEN
Maytag CWE500 WALLOVEN- STD ELE
Maytag CWE501 WALLOVEN- STD ELE
Maytag CWE502 WALLOVEN- STD ELE
Maytag CWE5020ACB WALLOVEN- STD ELE
Maytag CWE5020BCB WALLOVEN- STD ELE
Maytag CWE5100ACB10 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5200ACB WALLOVEN- S/C ELE
Maytag CWE550 WALLOVEN- S/C ELE
Maytag CWE5500ACB WALLOVEN- S/C ELE
Maytag CWE5500ACE WALLOVEN- S/C ELE
Maytag CWE5500BCB WALLOVEN- S/C ELE
Maytag CWE5500BCE WALLOVEN- S/C ELE
Maytag CWE5800ACB WALLOVEN- S/C ELE
Maytag CWE5800ACB25 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACE WALLOVEN- S/C ELE
Maytag CWE5800ACE28 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE5800ACS WALLOVEN- S/C ELE
Maytag CWE5800ACS14 24" BUILT-IN ELECTRIC DOUBLE WALL OVEN
Maytag CWE600 WALLOVEN- S/C ELE
Maytag CWE601 WALLOVEN- S/C ELE
Maytag CWE602 WALLOVEN- S/C ELE
Maytag CWE6020ACB WALLOVEN- S/C ELE
Maytag CWE6200ACB WALLOVEN- S/C ELE
Maytag CWE6200ACE WALLOVEN- S/C ELE
Maytag CWE6200ADB WALLOVEN- S/C ELE
Maytag CWE6200ADE WALLOVEN- S/C ELE
Maytag CWE6230ACB WALLOVEN- S/C ELE
Maytag CWE6230ACE WALLOVEN- S/C ELE
Maytag CWE6230ADB WALLOVEN- S/C ELE
Maytag CWE6230ADE WALLOVEN- S/C ELE
Maytag CWE6800ACB WALLOVEN- S/C ELE
Maytag CWE6800ACE WALLOVEN- S/C ELE
Maytag CWE6830ACB WALLOVEN- S/C ELE
Maytag CWE6830ACE WALLOVEN- S/C ELE
Maytag CWE700 WALLOVEN- S/C ELE
Maytag CWE7000ACB WALLOVEN- S/C ELE
Maytag CWE7000ACE WALLOVEN- S/C ELE
Maytag CWE701 WALLOVEN- S/C ELE
Maytag CWE7800ACB WALLOVEN- S/C ELE
Maytag CWE7800ACE WALLOVEN- S/C ELE
Maytag CWE7830ACB WALLOVEN- S/C ELE
Maytag CWE7830ACE WALLOVEN- S/C ELE
Maytag CWE900 WALLOVEN- S/C ELE
Maytag CWE9000ACB WALLOVEN- S/C ELE
Maytag CWE9000ACE WALLOVEN- S/C ELE
Maytag CWE9000BCB WALLOVEN- S/C ELE
Maytag CWE9000BCE WALLOVEN- S/C ELE
Maytag CWE9000BCM WALLOVEN- S/C ELE
Maytag CWE9000BDB WALLOVEN- S/C ELE
Maytag CWE9000BDE WALLOVEN- S/C ELE
Maytag CWE9000CDB WALLOVEN- S/C ELE
Maytag CWE9000CDE WALLOVEN- S/C ELE
Maytag CWE9000DDB WALLOVEN- S/C ELE
Maytag CWE9000DDE WALLOVEN- S/C ELE
Maytag CWE9030BCB WALLOVEN- S/C ELE
Maytag CWE9030BCE WALLOVEN- S/C ELE
Maytag CWE9030BDB WALLOVEN- S/C ELE
Maytag CWE9030BDE WALLOVEN- S/C ELE
Maytag CWE9030DDB WALLOVEN- S/C ELE
Maytag CWE9030DDE WALLOVEN- S/C ELE
Maytag CWE9900 WALLOVEN- S/C ELE
Admiral CWEA100ACB WALLOVEN- STD ELE
White Westinghouse CWEF309ES1 White Westinghouse/electric Range
White Westinghouse CWEF310ES1 White Westinghouse Canada/electric Range
White Westinghouse CWEF310FSA Ww Canada/electric Range
White Westinghouse CWEF310GSA ELECTRIC RANGE
White Westinghouse CWEF310GSB ELECTRIC RANGE
White Westinghouse CWEF310GSC ELECTRIC RANGE
White Westinghouse CWEF310GSD ELECTRIC RANGE
White Westinghouse CWEF310GSE ELECTRIC RANGE
White Westinghouse CWEF310GSF ELECTRIC RANGE
  #2 (permalink)
Old 04-05-2013, 11:35 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
DWoodall, This style washer is designed to spin and drain, simultaneously. You'll want to check the drain pump
Part number: AP4373022
and drain hoses for obstructions,kinks and debris. You'll also need to check the motor pulley
Part number: AP4024152
transmission pulley
Part number: AP4009132
and drive belt
Part number: AP4024823
for melted spots and shrinkage, causing the belt to not "slip" and ramping the spin basket up to speed prematurely, causing water to centrifuge up and over the tub cover.
As for the noise level, yo gave the perfect description of a worn bearing, your washer has two(2) the tub bearing
Part number: AP4373103
is located in the center of the outer tub. and the "spin" bearing
Part number: AP4373431
is actually mounted to the lower portion of the transmission, and is bolted to the suspension housing and will require a complete transmission replacement, if noisy. With the front panel removed and the washer in a spin cycle, you should be able to isolate the location of the noise, just be careful of the moving parts.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG noisy spin robertciem Washer Repair 0 07-29-2011 03:19 PM
Very noisy spin Downhome9 Washer Repair 4 03-30-2011 06:26 AM
noisy at end of last spin gmills Dishwasher Repair 1 07-05-2010 08:45 AM
Noisy Spin on H2 wyertown Washer Repair 0 12-20-2008 07:28 AM
noisy spin cycle eddieb Washer Repair 1 11-23-2007 06:43 PM
