My GE front load washer times are not those on the control panel. Wash cycles are off by 15 minutes to a half hour or more. Before I consider replacing the control board, is there anything I should check first? I've already pulled the hot and cold water lines off and assure the screens were clear of debris, and removed the lower front panel and cleaned out the filter.
Any ideas would be helpful.
Thanks, Paul2319
