Discuss
Spins but clothes remain quite wet if 2nd rinse used
 in
Washer Repair
Two years ago I replaced the transmission and just recently replaced the agitator. The washer agitates just fine and seems
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Spins but clothes remain quite wet if 2nd rinse used
  #1 (permalink)
Old 04-03-2013, 05:24 PM
Junior Member
RandyK0615 is on a distinguished road
Default Spins but clothes remain quite wet if 2nd rinse used
Model Number: 23032100   Brand: Kenmore   Age: 5 - 10 years
Two years ago I replaced the transmission and just recently replaced the agitator. The washer agitates just fine and seems to spin at good speed but if I use the heavy duty cycle with 2nd rinse selected I have to set it to spin a second time for the clothes not to be dripping. Not overloading it so I am wondering if there is a filter not letting the water out or maybe the timer is stopping the spin too quick. Really like the machine so suggestions will be very appreciated!
Randy
Related Models
Jenn-Air 2320ERS SURFACE UNIT- DDRAFT ELE
Roper 2323*0A Ranges, Electric*
Roper 2323W0A Ranges, Electric*
Roper 2324W0A Ranges, Electric*
Jenn-Air 2325ERS SURFACE UNIT- DDRAFT ELE
Roper 2326*0A Ranges, Electric*
Roper 2326W0A Ranges, Electric*
Kenmore 23310428 RANGE HOOD
Kenmore 23310442 RANGE HOOD
Kenmore 23334201 RANGE HOOD
Kenmore 23334202 RANGE HOOD
Kenmore 23334203 RANGE HOOD
Kenmore 23334204 RANGE HOOD
Kenmore 23334311 RANGE HOOD
Kenmore 23334319 RANGE HOOD
Kenmore 23350303200 RANGE HOOD
Kenmore 23350363200 RANGE HOOD
Kenmore 23350941590 RANGE HOOD
Kenmore 23350944590 RANGE HOOD
Kenmore 23350949590 RANGE HOOD
Kenmore 23351003600 RANGE HOOD
Kenmore 23351040590 RANGE HOOD
Kenmore 23351041590 RANGE HOOD
Kenmore 23351044590 RANGE HOOD
Kenmore 23351049590 RANGE HOOD
Kenmore 23351063600 RANGE HOOD
Kenmore 2335108010 KENMORE RANGE HOOD
Kenmore 2335108011 KENMORE RANGE HOOD
Kenmore 2335108012 KENMORE RANGE HOOD
Kenmore 2335108910 RANGE HOOD
Kenmore 2335108911 RANGE HOOD
Kenmore 23351141590 RANGE HOOD
Kenmore 23351144590 RANGE HOOD
Kenmore 23351200 RANGE HOOD
Kenmore 23351303200 RANGE HOOD
Kenmore 23351344590 RANGE HOOD
Kenmore 23351345590 RANGE HOOD
Kenmore 23351348590 RANGE HOOD
Kenmore 23351363200 RANGE HOOD
Kenmore 2335137810 KENMORE RANGE HOODS
Kenmore 2335137812 KENMORE RANGE HOOD
Kenmore 2335137813 KENMORE RANGE HOOD
Kenmore 2335138910 KENMORE RANGE HOOD
Kenmore 2335138911 RANGE HOOD
Kenmore 2335138912 RANGE HOOD
Kenmore 23351423200 RANGE HOOD
Kenmore 23351483 RANGE HOOD
Kenmore 23351540590 RANGE HOOD
Kenmore 23351544590 RANGE HOOD
Kenmore 23351545590 RANGE HOOD
Kenmore 23351600 RANGE HOOD
Kenmore 23351603 RANGE HOOD
Kenmore 23351640590 RANGE HOOD
Kenmore 23351644590 RANGE HOOD
Kenmore 23351645590 RANGE HOOD
Kenmore 23351648590 RANGE HOOD
Kenmore 23351649590 RANGE HOOD
Kenmore 2335167810 KENMORE RANGE HOOD
Kenmore 2335167811 KENMORE RANGE HOOD
Kenmore 2335167812 KENMORE RANGE HOOD
Kenmore 2335168910 KENMORE RANGE HOOD
Kenmore 2335168911 RANGE HOOD
Kenmore 2335168912 KENMORE RANGE HOOD
Kenmore 2335168913 RANGE HOOD
Kenmore 23351740590 RANGE HOOD
Kenmore 23351744590 RANGE HOOD
Kenmore 23351745590 RANGE HOOD
Kenmore 23351749590 RANGE HOOD
Kenmore 23351840590 RANGE HOOD
Kenmore 23351840591 RANGE HOOD
Kenmore 23351841590 RANGE HOOD
Kenmore 23351841591 RANGE HOOD
Kenmore 23351844100 RANGE HOOD
Kenmore 23351844591 RANGE HOOD
Kenmore 23351848590 RANGE HOOD
Kenmore 23351848591 RANGE HOOD
Kenmore 2335188410 KENMORE RANGE HOOD
Kenmore 2335188411 KENMORE RANGE HOOD
Kenmore 2335188610 KENMORE RANGE HOOD
Kenmore 2335188910 KENMORE RANGE HOOD
Kenmore 2335188911 RANGE HOOD
Kenmore 233518910 RANGE HOOD
Kenmore 23351898 RANGE HOOD
Kenmore 23351899 RANGE HOOD
Kenmore 23352045590 RANGE HOOD
Kenmore 23352052000 RANGE HOOD
Kenmore 23352052002 RANGE HOOD
Kenmore 23352053000 RANGE HOOD
Kenmore 23352053002 RANGE HOOD
Kenmore 23352054002 RANGE HOOD
Kenmore 23352057000 RANGE HOOD
Kenmore 23352059000 RANGE HOOD
Kenmore 23352059002 RANGE HOOD
Kenmore 2335207810 KENMORE RANGE HOOD
Kenmore 2335207811 KENMORE RANGE HOOD
Kenmore 2335208390 KENMORE RANGE HOOD
Kenmore 2335208510 KENMORE RANGE HOOD
Kenmore 2335208610 KENMORE RANGE HOOD
Kenmore 2335208910 RANGE HOOD
Kenmore 2335209690 RANGE HOOD
Kenmore 2335209950 RANGE HOOD
Kenmore 23352145590 RANGE HOOD
Kenmore 23352152000 RANGE HOOD
Kenmore 23352152002 RANGE HOOD
Kenmore 23352153000 RANGE HOOD
Kenmore 23352153002 RANGE HOOD
Kenmore 23352154002 RANGE HOOD
Kenmore 23352157000 RANGE HOOD
Kenmore 23352159000 RANGE HOOD
Kenmore 23352159002 RANGE HOOD
Kenmore 2335217810 KENMORE RANGE HOOD
Kenmore 2335217811 KENMORE RANGE HOOD
Kenmore 2335218510 KENMORE RANGE HOOD
Kenmore 2335218610 KENMORE RANGE HOOD
Kenmore 2335218910 RANGE HOOD
Kenmore 2335219690 RANGE HOOD
Kenmore 2335219950 RANGE HOOD
Kenmore 23352303200 RANGE HOOD
Kenmore 23352340590 RANGE HOOD
Kenmore 23352344590 RANGE HOOD
  #2 (permalink)
Old 04-05-2013, 01:25 PM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Randy
Randy, We presume this is a Kenmore washer (110.23032100) built by Whirlpool(most Kenmore products have an eleven digit model number). If that is the case, you most likely have a "slipping" clutch assembly
Part number: AP3094537
and or "dragging" brake shoes
Part number: AP3094432
Either component could create a poor spin situation, once the pads get heated
and don't engage correctly.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer does not go into spin cycle therefore clothes remain wet GeorgeValdes Washer Repair 1 08-18-2011 06:25 PM
Doesn't rinse but spins curtiscmitchell Washer Repair 2 05-11-2011 06:45 PM
spins but clothes are still very damp myrna Washer Repair 1 09-04-2009 03:26 AM
Washer spins but clothes are still too wet dmopandglo Washer Repair 2 08-22-2009 08:18 AM
Washer Works, but Clothes Remain Somewhat Wet. UCGR Washer Repair 4 03-20-2009 01:44 PM
