Discuss
GE Washer won't fill or spin
 in
Washer Repair
The washer will not fill. I filled it with water and it agitates . I put it on spin and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Washer won't fill or spin
  #1 (permalink)
Old 04-02-2013, 09:19 AM
Junior Member
Hock is on a distinguished road
Default GE Washer won't fill or spin
Model Number: wjre5550k2ww   Brand: GE   Age: Less than 1 year
The washer will not fill. I filled it with water and it agitates . I put it on spin and it drained the water but it didn't spin.
I replaced the water inlet valve didn't help at all. Help
When you initiate a cycle it make three loud clicking noises and then starts to agitate.
When you lift the lid the agitation stops and when you close the lid it resumes.
Related Models
General Electric WJRE5550K2WW WASHER
General Electric WJRE5550K3WW WASHER
General Electric WJRR4170E0CC Washer
General Electric WJRR4170E0WW Washer
General Electric WJRR4170E1CC Washer
General Electric WJRR4170E1WW Washer
General Electric WJRR4170E3CC Washer
General Electric WJRR4170E3WW Washer
General Electric WJRR4170E4CC Washer
General Electric WJRR4170E4WW Washer
General Electric WJRR4170E5CC Washer
General Electric WJRR4170E5WW Washer
General Electric WJRR4170E6CC Washer
General Electric WJRR4170E6WW Washer
General Electric WJRR4170G0WW Washer
General Electric WJRR4170G1WW WASHER
General Electric WJRR4170G2WW WASHER
General Electric WJRR4170G3WW WASHER
General Electric WJRR4170G4WW WASHER
General Electric WJRR4170G5WW WASHER
General Electric WJRR4170G6WW WASHER
General Electric WJSE3110A0AA Washer
General Electric WJSE3110A0CC Washer
General Electric WJSE3110A0WW Washer
General Electric WJSE3110A2CC Washer
General Electric WJSE3110A2WW Washer
General Electric WJSE4150B0CC Washer
General Electric WJSE4150B0WW Washer
General Electric WJSE4150B1CC Washer
General Electric WJSE4150B1WW Washer
General Electric WJSE4150B2CC Washer
General Electric WJSE4150B2WW Washer
General Electric WJSE4150B3CC Washer
General Electric WJSE4150B3WW Washer
General Electric WJSR1070A1AA Washer
General Electric WJSR1070A1CC Washer
General Electric WJSR1070A1WW Washer
General Electric WJSR1070A2AA Washer
General Electric WJSR1070A2WW Washer
General Electric WJSR2070B0CC Washer
General Electric WJSR2070B0WW Washer
General Electric WJSR2070B2CC Washer
General Electric WJSR2070B2WW Washer
General Electric WJSR2070B3CC Washer
General Electric WJSR2070B3WW Washer
General Electric WJSR2070B4CC Washer
General Electric WJSR2070B4WW Washer
General Electric WJSR2070B9WW WASHER
General Electric WJSR2070D0WW Washer
General Electric WJSR2070D1WW Washer
General Electric WJSR2070D2WW Washer
General Electric WJSR2070D3WW Washer
General Electric WJSR2070D5WW Washer
General Electric WJSR2070D6WW Washer
General Electric WJSR2080T2AA Washer
General Electric WJSR2080T2WB Washer
General Electric WJSR2080T2WW Washer
General Electric WJSR2080T3AA Washer
General Electric WJSR2080T3WB Washer
General Electric WJSR2080T3WW Washer
General Electric WJSR2080T5AA Washer
General Electric WJSR2080T5WB Washer
General Electric WJSR2080T5WW Washer
General Electric WJSR2080T6AA Washer
General Electric WJSR2080T6WB Washer
General Electric WJSR2080T6WW Washer
General Electric WJSR2080T8AA Washer
General Electric WJSR2080T8WB Washer
General Electric WJSR2080T8WW Washer
General Electric WJSR2080TAAA Washer
General Electric WJSR2080TAWB Washer
General Electric WJSR2080TAWW Washer
General Electric WJSR2080V1AA Washer
General Electric WJSR2080V1WW Washer
General Electric WJSR2080V2AA Washer
General Electric WJSR2080V2WW Washer
General Electric WJSR2080V3AA Washer
General Electric WJSR2080V3WW Washer
General Electric WJSR4160D0CC Washer
General Electric WJSR4160D0WW Washer
General Electric WJSR4160D2CC Washer
General Electric WJSR4160D2WW Washer
General Electric WJSR4160D5CC Washer
General Electric WJSR4160D5WW Washer
General Electric WJSR4160D6CC Washer
General Electric WJSR4160D6WW Washer
General Electric WJSR4160DACC Washer
General Electric WJSR4160DAWW Washer
General Electric WJSR4160DCCC Washer
General Electric WJSR4160DCWW Washer
General Electric WJSR4160G0WW Washer
General Electric WJSR4160G1WW WASHER
General Electric WJSR4160G2WW WASHER
General Electric WJSR4160G3WW WASHER
General Electric WJSR4160G4WW WASHER
General Electric WJSR4160G5WW WASHER
General Electric WJSR4160G6WW WASHER
General Electric WJXR2080T2AA Washer
General Electric WJXR2080T2WW Washer
General Electric WJXR2080T3AA Washer
General Electric WJXR2080T3WW Washer
General Electric WJXR2080T5AA Washer
General Electric WJXR2080T5WW Washer
General Electric WJXR2080T6AA Washer
General Electric WJXR2080T6WW Washer
General Electric WJXR2080T8AA Washer
General Electric WJXR2080T8WW Washer
General Electric WJXR2080TAAA Washer
General Electric WJXR2080TAWW Washer
General Electric WJXR2080V0AA Washer
General Electric WJXR2080V0WW Washer
Whirlpool WKP85800 30" ELECTRIC RANGE CERAN COOKTOP
General Electric WKRE5500K0WW WASHER
General Electric WKRE5550K0WW WASHER
General Electric WKRE6280D0WW Washer
General Electric WKRE6280D1WW Washer
General Electric WKRE6280DCWW Washer
General Electric WKSE5260E0WW Washer
General Electric WKSE5260E1WW Washer
General Electric WKSE5260E6WW Washer
  #2 (permalink)
Old 04-02-2013, 09:59 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Check the water level pressure switch. Should be closed with tub empty and open when full. There may be gunk in the air dome and hose on the lower left side of the outer tub hindering operation of the pressure switch. If the pressure switch is operating properly, check continuity from power cord neutral (large blade) and the wht/red wires on the water valve solenoid plugs and continuity from water valve plugs to control board. If pressure switch and continuity checks are good, it's likely a bad control board.
Eric
  #3 (permalink)
Old 04-02-2013, 10:04 AM
Junior Member
Default
I disconnected the pressure switch and put the ohm meter on it and it read 0. does this mean it is faulty?????
  #4 (permalink)
Old 04-02-2013, 11:30 AM
Expert
APP Volunteer
Default
It means that it is closed which is good for fill. It should open when the water level reaches the low level mark.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer would fill up but not spin lvnpink1976 Washer Repair 0 04-13-2012 12:02 AM
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 11:13 AM
Washer drains and fill but won't spin maguinness14 Washer Repair 5 08-31-2010 07:53 AM
GE Washer won't fill won't spin poostiles@yahoo.com Washer Repair 5 12-02-2009 05:05 PM
washer wont spin after fill- buck24 Washer Repair 3 09-14-2009 06:54 PM
