Discuss
Timer issues on older KitchenAid (Whirlpool direct drive)
 in
Washer Repair
This is really starting to irritate me. worked fine up until a week ago. Then, decided to stop agitating. fiddling
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Timer issues on older KitchenAid (Whirlpool direct drive)
  #1 (permalink)
Old 04-01-2013, 05:10 PM
Junior Member
jz78817 is on a distinguished road
Default Timer issues on older KitchenAid (Whirlpool direct drive)
Model Number: KAWS750GQ1   Brand: Kitchen Aid   Age: More than 10 years
This is really starting to irritate me. worked fine up until a week ago. Then, decided to stop agitating. fiddling with the timer knob, if we found the right spot we could at least get it to drain and maybe spin. since this machine had been through a couple of timers in its life, we replaced it and the machine worked for about a week. Then it started doing the same thing. It'll fill with water to the correct level then just sit there doing nothing while the timer advances normally. I checked the terminals at the motor, the motor start switch, and the capacitor, and when it's supposed to be agitating or spinning, there's no voltage. When we can get the motor to run in drain/spin, voltages are normal. this evening, I did some probing around. as of right now:
1) I have the lid switch jumpered
2) I have the water level switch jumpered from Violet to Tan so the timer runs
3) machine will not agitate or spin if I try to start it in those regions of the dial
4) The machine WILL run if I find the right spot to set the timer knob for draining after the rinse cycle (basket spins too.)
5) when it's spinning, it draws about 550 watts from the outlet (checked with a Kill-a-watt meter) which sounds about normal, so it doesn't seem to be dragging or binding.
6) I've visually inspected the wiring and connectors, I don't see any wiring breaks. The terminal pins in the connectors going to the timer don't seem to be corroded nor do they look like they're spreading and losing contact. Also "wiggling" the connectors while the machine was supposed to be agitating didn't do anything.
I could accept that the new timer might be defective, but it seems strange that it would fail in the same manner as the one it replaced. I don't want to keep throwing parts at a machine as old as this, nor do I want to just throw another timer on it if it'll only last a week. is there anything that might be able to "kill" one of these timers? It's one of the older-style ones with the plastic cam wheel and a bunch of brass leaf switches (like this one.
thank you
Related Models
Whirlpool KAWS750GQ1 AUTOMATIC WASHER
Whirlpool KAWS750GT1 AUTOMATIC WASHER
Whirlpool KAWS750GZ0 AUTOMATIC WASHER
Whirlpool KAWS750GZ1 AUTOMATIC WASHER
Whirlpool KAWS750JQ0 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ1 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ2 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ3 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ4 RESIDENTIAL WASHERS
Whirlpool KAWS750JT0 RESIDENTIAL WASHERS
Whirlpool KAWS750JT1 RESIDENTIAL WASHERS
Whirlpool KAWS750JT2 RESIDENTIAL WASHERS
Whirlpool KAWS750JT3 RESIDENTIAL WASHERS
Whirlpool KAWS750JT4 RESIDENTIAL WASHERS
Whirlpool KAWS750LQ0 AUTOMATIC WASHER
Whirlpool KAWS750LQ1 AUTOMATIC WASHER
Whirlpool KAWS750LQ2 AUTOMATIC WASHER
Whirlpool KAWS750LQ3 AUTOMATIC WASHER
Whirlpool KAWS750LQ4 AUTOMATIC WASHER
Whirlpool KAWS750LT0 AUTOMATIC WASHER
Whirlpool KAWS750LT1 AUTOMATIC WASHER
Whirlpool KAWS750LT2 AUTOMATIC WASHER
Whirlpool KAWS750LT3 AUTOMATIC WASHER
Whirlpool KAWS750LT4 AUTOMATIC WASHER
Whirlpool KAWS777EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS777EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS800GQ0 AUTOMATIC WASHER
Whirlpool KAWS800GQ1 AUTOMATIC WASHER
Whirlpool KAWS800GZ0 AUTOMATIC WASHER
Whirlpool KAWS800GZ1 AUTOMATIC WASHER
Whirlpool KAWS850GQ0 AUTOMATIC WASHER
Whirlpool KAWS850GQ1 AUTOMATIC WASHER
Whirlpool KAWS850GT0 AUTOMATIC WASHER
Whirlpool KAWS850GT1 AUTOMATIC WASHER
Whirlpool KAWS850GZ0 AUTOMATIC WASHER
Whirlpool KAWS850GZ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ0 AUTOMATIC WASHER
Whirlpool KAWS850JQ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ2 AUTOMATIC WASHER
Whirlpool KAWS850JQ3 AUTOMATIC WASHER
Whirlpool KAWS850JQ4 AUTOMATIC WASHER
Whirlpool KAWS850JT0 AUTOMATIC WASHER
Whirlpool KAWS850JT1 AUTOMATIC WASHER
Whirlpool KAWS850JT2 AUTOMATIC WASHER
Whirlpool KAWS850JT3 AUTOMATIC WASHER
Whirlpool KAWS850JT4 AUTOMATIC WASHER
Whirlpool KAWS850LE0 AUTOMATIC WASHER
Whirlpool KAWS850LE1 AUTOMATIC WASHER
Whirlpool KAWS850LE2 AUTOMATIC WASHER
Whirlpool KAWS850LQ0 AUTOMATIC WASHER
Whirlpool KAWS850LQ1 AUTOMATIC WASHER
Whirlpool KAWS850LQ2 AUTOMATIC WASHER
Whirlpool KAWS850LT0 AUTOMATIC WASHER
Whirlpool KAWS850LT1 AUTOMATIC WASHER
Whirlpool KAWS850LT2 AUTOMATIC WASHER
Whirlpool KAWS855JE0 WASHER
Whirlpool KAWS855JE1 WASHER
Whirlpool KAWS855JE2 WASHER
Whirlpool KAWS855JE3 WASHER
Whirlpool KAWS855JE4 WASHER
Whirlpool KAWS977EQ0
Whirlpool KAWS977EZ0
Bosch KB030-062
Bosch KB032-062
Bosch KB035-062
Bosch KB036-062
Bosch KB090-054
Bosch KB091-054
Bosch KB100-046
Frigidaire KB122G0 Wwh(v1) / Built - in Oven
Frigidaire KB122G1 Wwh(v2) / Built - in Oven
Frigidaire KB122G2 Wwh(v3) / Built - in Oven
Frigidaire KB122G3 Wwh(v4) / Built - in Oven
Frigidaire KB122G4 Wwh(v5) / Built - in Oven
Frigidaire KB122LM0 Wwh(v1) / Wall Oven
Frigidaire KB122LM1 Wwh(v2) / Wall Oven
Frigidaire KB122LM2 Wwh(v1) / Wall Oven
Frigidaire KB122LMO Wwh(v1) / Wall Oven
Frigidaire KB152LM0 Wwh(v1) / Electric Range
Frigidaire KB152LM1 Wwh(v1) / Electric Range
Frigidaire KB152LM2 Wwh(v1) / Electric Range
Whirlpool KB26G1X-3 6 QT. STAND MIXER
Whirlpool KB26G1XAC3 6 QT. STAND MIXER
Whirlpool KB26G1XAC5 6 QT. STAND MIXER
Whirlpool KB26G1XBU3 6 QT. STAND MIXER
Whirlpool KB26G1XBU5 6 QT. STAND MIXER
Whirlpool KB26G1XER3 6 QT. STAND MIXER
Whirlpool KB26G1XER5 6 QT. STAND MIXER
Whirlpool KB26G1XGN3 6 QT. STAND MIXER
Whirlpool KB26G1XGR3 6 QT. STAND MIXER
Whirlpool KB26G1XGR5 6 QT. STAND MIXER
Whirlpool KB26G1XMC3 6 QT. STAND MIXER
Whirlpool KB26G1XMC5 6 QT. STAND MIXER
Whirlpool KB26G1XMY3 6 QT. STAND MIXER
Whirlpool KB26G1XMY5 6 QT. STAND MIXER
Whirlpool KB26G1XOB3 6 QT. STAND MIXER
Whirlpool KB26G1XOB5 6 QT. STAND MIXER
Whirlpool KB26G1XPT3 6 QT. STAND MIXER
Whirlpool KB26G1XPT5 6 QT. STAND MIXER
Whirlpool KB26G1XTG3 6 QT. STAND MIXER
Whirlpool KB26G1XTG5 6 QT. STAND MIXER
Whirlpool KB26G1XWW3 6 QT. STAND MIXER
Whirlpool KB26G1XWW5 6 QT. STAND MIXER
Frigidaire KB443GDM0 Wwh(v1) / Electric Continuous Clean Oven
Frigidaire KB443GDM1 Wwh(v2) / Electric Continuous Clean Oven
Frigidaire KB443GDM2 Wwh(v1) / Electric Range
Frigidaire KB443LM1 Wwh(v1) / Electric Range
Frigidaire KB563LM0 Wwh(v1) / Wall Oven
Frigidaire KB663GDM0 Wwh(v1) / Electric Self - Clean Oven
Frigidaire KB663GDM1 Wwh(v2) / Electric Self - Clean Oven
Frigidaire KB663GDM2 Wwh(v1) / Wall Oven
Frigidaire KB663LM0 Wwh(v1) / Electric Range
Frigidaire KB663LM1 Wwh(v1) / Electric Range
Frigidaire KB663LM2 Wwh(v1) / Electric Range
Frigidaire KB663LMO Wwh(v0) / Electric Range
Frigidaire KB883GDM1 Wwh(v1) / Electric Double Oven W/self Clean Upper
Frigidaire KB883GDM2 Wwh(v1) / Electric Range
Frigidaire KB883GDM3 Wwh(v2) / Electric Range
Frigidaire KB883GDMO Wwh(v2) / Electric Double Oven W/self Clean Upper
Frigidaire KB883LM0 Wwh(v1) / Electric Range
  #2 (permalink)
Old 04-01-2013, 06:10 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
You may have a faulty speed switch (fabric select). Have you tried different speeds? On some of these washers, drain mode bypasses this switch. I don't have the diagram and timing chart for your model. If you could post a clear readable photo of each, it would help. You can try bypassing the speed switch. For spin mode, disconnect the red/blu wire and the blu wire and jump them together. For agitate, jump yel/blu to blu.
BTW, the newer timers also use the plastic cam drum and brass contact leaf springs but now have a plastic housing instead of metal.
Eric
  #3 (permalink)
Old 04-01-2013, 06:46 PM
Junior Member
Default
Quote:
yes, sort of. when I say "sort of," I mean I flipped that switch between its settings while the timer was running. Now I'm questioning whether the timer would respect any changes to the speed switch settings while it was already running.
I'll try that. if it doesn't work, I'll get the best pics I can of the diagrams and post.
Eric
*shrug* I have an "Estate by Whirlpool" washer which is pretty much the same except the timer housing looks nothing like the one I linked. guilty of assuming too much, I guess
  #4 (permalink)
Old 04-01-2013, 06:57 PM
Expert
APP Volunteer
Default
Doesn't matter if the timer is already running when changing speeds. When jumping the wires, the timer must be set to spin mode for spin and agitate mode for agitate. Power to the motor is still through the timer, we are just bypassing the speed select switch. Obviously, unplug the washer before jumping the wires.
Eric
  #5 (permalink)
Old 04-02-2013, 04:42 PM
Junior Member
Default
thank you for your help so far. the wire colors seem different than what you mentioned, so here are the diagrams you asked about. They're big.
http://home.comcast.net/~jz78817/stuff/diagram.jpg
http://home.comcast.net/~jz78817/stuff/timing.jpg
  #6 (permalink)
Old 04-02-2013, 05:31 PM
Expert
APP Volunteer
Default
Yes, much different than the diagram I was using. That's why we need the specific diagram. They are all "similar" but different nonetheless. The speed switch is bypassed in drain mode and in spin mode it is initially bypassed through the motor switch which means the motor would continuously switch on/off when attempting to spin if the speed switch was bad and I assume that's not happening. With the washer in spin mode and the lid switch properly bypassed, you should have 120vac between the orange and white wires at the motor. If you do and the motor isn't trying to run, the motor switch is faulty. If you don't , then either the timer is faulty or there is a wiring/connection problem. Are you able to read and interpret the timer chart and wiring diagram or is that over your head? I can try to assist if it doesn't make sense to you.
Eric
  #7 (permalink)
Old 04-02-2013, 05:57 PM
Expert
APP Volunteer
Default
The washer should run in first part of spin mode (cotton cycle) which is medium speed which bypasses the speed select switch, so I don't think it's the speed select switch. The diagram below shows you the current path in the first part of spin mode. Yellow is the path when it first starts. After the motor gets going the centrifugal switch changes the path to pink and then when it switches to high speed spin the path is green which is through the speed select switch. This will give you an idea what to look for. You can just set it to spin mode with the timer switch on and washer unplugged if you want to make continuity checks versus checking live line voltages.
Eric
  #8 (permalink)
Old 04-02-2013, 06:51 PM
Junior Member
Default
it's way over my head. I'm a mechanical engineer, I have some basic understanding of circuit diagrams but at this point I'm totally lost. I don't understand why this would stop working, then after replacing the timer it would work for maybe four loads, and then fail in the exact same way. and thanks to my ham-fisted-ness, I broke the fabric selector switch; so after replacing the broken parts and calling someone out to fix the damn thing, those costs would probably be more than half of buying a new washer.
  #9 (permalink)
Old 04-02-2013, 07:33 PM
Expert
APP Volunteer
Default
Well, you really need to make some voltage checks or continuity checks to find the problem or your just blindly replacing parts. If it's really way over your head, you need somebody with some experience at it to help you troubleshoot the problem. It's not unheard of to get another bad timer but it could be the motor switch or a wiring/connection problem. Electrical troubleshooting is a piece of cake for me but even many experienced appliance tech's are not very good at it. It's worth fixing this washer though, you don't want one of the new pieces of junk they are selling nowadays.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirpool direct drive washer issues wadetrane Washer Repair 6 02-12-2013 12:24 PM
Direct Drive Whirlpool question ponderosan Washer Repair 1 11-01-2011 07:42 PM
replacing drive coupleing on Whirlpool direct drive washer bbuck222 Washer Repair 2 08-06-2009 08:34 AM
Whirlpool Direct Drive Squeeking hihihi Washer Repair 1 03-10-2008 12:32 PM
Whirlpool Direct Drive - reasons for drive coupling failing FriarTuck Washer Repair 1 11-12-2007 02:34 PM
