Discuss
roper washer wont spin
 in
Washer Repair
Hi, my washer not working in the spin cycle. it washes and agitates, it even drains most of the water.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » roper washer wont spin
  #1 (permalink)
Old 03-31-2013, 07:02 PM
Junior Member
nicvoi is on a distinguished road
Default roper washer wont spin
Brand: Roper   Age: 1 - 5 years
Hi, my washer not working in the spin cycle. it washes and agitates, it even drains most of the water. but it doesnt spin the water out of the clothes. I did some research and thought it was the clutch, so i replaced that. Not the problem. help!!
  #2 (permalink)
Old 04-01-2013, 09:11 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
What is the model number? Assuming it is a Whirlpool direct drive, run it in spin mode with the cabinet off and lid switch bypassed. Observe the clutch hub while in spin mode. After it drains, the motor should pause for a few seconds and then start again. When it starts again, is the clutch hub spinning? If so, either the clutch is slipping, there's a problem with the brake cam driver, basket drive or tub drive block. Where did you buy the clutch from?
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
roper washer wont spin nicvoi Washer Repair 1 04-02-2013 06:06 PM
roper washer wont agitate or spin!!!! mrbreezio Washer Repair 1 04-28-2012 06:36 AM
roper washer wont spin or drain water michalek Washer Repair 1 03-30-2011 01:38 PM
Roper washer wont spin and wont empty jgirl14572 Washer Repair 2 10-11-2009 07:54 AM
roper washer wont work on spin cycle bugdude007 Washer Repair 1 05-31-2009 11:10 AM
