WinterGreen
#1 Posted : Tuesday, March 26, 2013 6:57:54 AM(UTC)
WinterGreen
I have an Amana NAV2330AWW. On the wash cycle it will fill, wash, rinse, spin like normal, no issue. Then it when it gets to the Rinse cycle, it will fill and just sit there full of water. It never drains and ticks through the timer, still full of water when it is done.
If you advance it to the Extra Rinse cycle it will work normal (fill, rinse, spin, drain), just not the regular Rinse cycle. This happens on all the settings (hand wash, regular, quick wash, etc..)
Any suggestion on why it does that?
#2 Posted : Tuesday, March 26, 2013 7:24:02 PM(UTC)
Hello,
Sounds like the problem is a bad timer.
- The timer Part number: 27001088
Here are the breakdown diagrams and Parts for Amana NAV2330AWW Washer - AppliancePartsPros.com
WinterGreen
#3 Posted : Tuesday, March 26, 2013 8:54:10 PM(UTC)
WinterGreen
It started working after a thud on the head. I expect it will go out again soon, so I will save this. That would make sense though, it doesn't look to hard to change out, or is that a little to optimistic? Otherwise, thank you. :)
