Discuss
No agitation with large load
 in
Washer Repair
The washer works properly when set for a small or medium load. With a large load, it doesn't agitate but
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No agitation with large load
  #1 (permalink)
Old 03-25-2013, 11:07 AM
Junior Member
bkbk is on a distinguished road
Default No agitation with large load
Model Number: VBXR1060V1WW   Brand: Hotpoint   Age: More than 10 years
The washer works properly when set for a small or medium load. With a large load, it doesn't agitate but it fills and drains OK (not sure about the spin cycle). The transmission was replaced several years ago. Thanks for any advice you can give for DIY.
Related Models
General Electric VBXR1060V1WW Washer
General Electric VBXR1070W0AA Washer
General Electric VBXR1070W0WW Washer
General Electric VBXR1070W1AA Washer
General Electric VBXR1070W1WW Washer
General Electric VBXR1070W2AA Washer
General Electric VBXR1070W2WW Washer
General Electric VBXR1090B0CC Washer
General Electric VBXR1090B0WW Washer
General Electric VBXR1090B2CC Washer
General Electric VBXR1090B2WW Washer
General Electric VBXR1090B3CC Washer
General Electric VBXR1090B3WW Washer
General Electric VBXR1090B4CC Washer
General Electric VBXR1090B4WW Washer
General Electric VBXR1090D0CC Washer
General Electric VBXR1090D0WW Washer
General Electric VBXR1090D1WW Washer
General Electric VBXR1090D2CC Washer
General Electric VBXR1090D2WW Washer
General Electric VBXR1090D3WW Washer
General Electric VBXR1090D4WW Washer
General Electric VBXR1090D5CC Washer
General Electric VBXR1090D5WW Washer
General Electric VBXR1090D6WW Washer
General Electric VBXR1090D7WW Washer
General Electric VBXR1090D8CC Washer
General Electric VBXR1090D8WW Washer
General Electric VBXR1090D9WW Washer
General Electric VBXR1090DACC Washer
General Electric VBXR1090DAWW Washer
General Electric VBXR1090DBCC Washer
General Electric VBXR1090DBWW Washer
General Electric VBXR1090DDCC Washer
General Electric VBXR1090DDWW Washer
General Electric VBXR2070T2AB Washer
General Electric VBXR2070T2WB Washer
General Electric VBXR2070T3AB Washer
General Electric VBXR2070T3WB Washer
General Electric VBXR2070T5AB Washer
General Electric VBXR2070T5WB Washer
General Electric VBXR2070T6AB Washer
General Electric VBXR2070T6WB Washer
General Electric VBXR2070T8AB Washer
General Electric VBXR2070T8WB Washer
General Electric VBXR2070TAAB Washer
General Electric VBXR2070TAWB Washer
General Electric VBXR2070V0AA Washer
General Electric VBXR2070V0WW Washer
General Electric VBXR2070V1AA Washer
General Electric VBXR2070V1WW Washer
Thermador VC-500
Gaggenau VC112-602
Gaggenau VC113-602
Gaggenau VC114-602
Gaggenau VC116-602
Gaggenau VC230-612
Gaggenau VC343-602
Gaggenau VC345-602
Gaggenau VC355-602
Thermador VCH-2 CONTROL HOUSING
Thermador VCH-3 RANGE HOOD
Thermador VCH-6 CONTROL HOUSING
Thermador VCH-6A CONTROL HOUSING
Thermador VCH-7 CONTROL HOUSING
Thermador VCH-7A CONTROL HOUSING
Thermador VCH-8 CONTROL HOUSING
Thermador VCH-9 CONTROL HOUSING
Amana VCH3 ELE CARTRIDGE
Thermador VCH36
Amana VCH4 ELE CARTRIDGE
Thermador VCH54
Thermador VCK-1 VENTILATOR
Thermador VCK-1A RANGE HOOD
Thermador VCK-300
Bosch VD030-000
Bosch VD030-010
Bosch VD030-099
Bosch VD040-000
Bosch VD040-010
Bosch VD040-099
Bosch VD050-010
Gaggenau VE112-612
Frigidaire VE21AW5 Tap(v1) / Electric Range
Amana VE3013 WASHER-TOP LOADING
Frigidaire VE30AW5 Tap(v1) / Electric Range
Frigidaire VE30BW4 Tap(v1) / Electric Range
Frigidaire VE30CW4 Tap(v1) / Electric Range
Gaggenau VE313-613
Amana VE5013 WASHER-TOP LOADING
Amana VEND-10.000 COMMERCIAL MICROWAVES
Amana VEND-10.A COMMERCIAL MICROWAVES
Amana VEND-10.B COMMERCIAL MICROWAVES
Amana VEND-10.C COMMERCIAL MICROWAVES
Amana VEND-10.F COMMERCIAL MICROWAVES
Amana VEND-10.G COMMERCIAL MICROWAVES
Amana VEND-10.H COMMERCIAL MICROWAVES
Amana VEND-10.J COMMERCIAL MICROWAVES
Amana VEND-7.003 COMMERCIAL MICROWAVES
Amana VEND-7.004 COMMERCIAL MICROWAVES
Amana VEND-7.005 COMMERCIAL MICROWAVES
Amana VEND-7.A COMMERCIAL MICROWAVES
Amana VEND-7.B COMMERCIAL MICROWAVES
Amana VEND-7D.001 COMMERCIAL MICROWAVES
Amana VEND-7D.A COMMERCIAL MICROWAVES
Amana VEND10 COMMERCIAL MICROWAVES
Amana VEND11 COMMERCIAL MICROWAVES
Amana VEND11B COMMERCIAL MICROWAVES
Hoover VER1360AGH RANGE- F/S STD ELE
Gaggenau VF112-610
Gaggenau VF230-610
Gaggenau VF332-610
Frigidaire VG21AW3 Tap(v1) / Gas Range
Frigidaire VG21AW3-23 Tap(v2) / Gas Range
Gaggenau VG223-812
Gaggenau VG230-811
Gaggenau VG231-211CA
Gaggenau VG232-212CA
Amana VG3019 WASHER-TOP LOADING
  #2 (permalink)
Old 03-25-2013, 11:48 AM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Open the front panel and check if the clutch turning, motor running in both agitate and the spin.
Post the results.
Here are the breakdown diagrams and 04-Suspension Pump & Drive Components parts for GE VBXR1060V1WW - AppliancePartsPros.com
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-26-2013, 10:29 AM
Junior Member
Default
Simon,
I opened the front panel, set the load size to large, and started the washer with no clothing in it. The washer filled, agitated, drained, and spun, then I turned it off. So I guess the motor and clutch are OK (assuming the clutch is the part between the motor and drive belt). Was the agitation problem from overfilling and putting too much weight in the tub?
The only problem I noticed was that when water was in the tub, there was a constant drip coming from where the transmission shaft enters the tub through what looks like a rubber ring. Is there is a simple solution to that? If not, we could live with it.
Thx.
  #4 (permalink)
Old 03-26-2013, 12:49 PM
Expert
Default
Hi.
There is a chance that the clutch is slipping with the heavier load.
Replacing the tub seal should stop the dripping. It's a time consuming job.
Simon.
__________________
  #5 (permalink)
Old 04-08-2013, 08:58 AM
Junior Member
Default
Hi, I'm back after doing a large load of laundry and making sure the washer was not overloaded. There were problems. Wash cycle: the center agitator moved back and forth slowly, the tub as a whole didn't agitate, and the fan belt varied in speed. Spin cycle: the fan belt moved slowly even though the disk above it (between the belt and the motor -- is that the clutch?) was spinning quickly.
Can you suggest a fix? The washer seems to work OK with a small or medium load and when there was no clothing in the large load.
Thanks.
  #6 (permalink)
Old 04-08-2013, 11:40 AM
Expert
Default
Hi.
Sounds like you have a bad clutch there.
Part number: AP2045377
Post the results.
Simon.
__________________
  #7 (permalink)
Old 04-08-2013, 12:26 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Quote:
The "disk" that the belt goes around is the pulley. The clutch is inside the pulley. If the pulley is spinning quickly but the belt is not, then the belt is slipping, not the clutch. You may just need a new belt, that's an older washer. As for the agitator, I would pull it and remove the agitator coupler to inspect the internal splines that mate with the agitator shaft splines. They may be stripping out in which case, you would need a new agitator coupler. The agitator just pops off. Place a strap under it and yank straight up on it. Remove the bolt to remove the coupler.
Although it's a big job, I would replace the tub seal. Water leaking there can follow down the transmission housing into the lower transmission spin bearing and ruin it.
Eric
  #8 (permalink)
Old 05-20-2013, 08:31 AM
Junior Member
Default
We've been making do with the washer by just using it with medium loads, but that's starting to have problems with agitating and spinning too. The drive belt does have a lot of give. Is there a way to tighten the belt (for example by moving the motor a bit) or does it have to be replaced?
I also plan to replace the tub seal. Do you carry the wrench for removing the tub nut?
Thanks for all the help. -bk
  #9 (permalink)
Old 05-20-2013, 09:58 AM
Junior Member
aggiesfanatic03 is on a distinguished road
Default Hotpoint Washer does not aggitate
I have a Hotpoint washer (model # VBXR1090DBWW) that does not aggitate regardless of load size.
It has been in storage for a year and a half and worked perfectly before. I am assuming by other posts that it could be the clutch (the belt looks brand new)
Can you explain how to replace the clutch and offer any other troubleshooting possibilities?
  #10 (permalink)
Old 05-20-2013, 01:49 PM
Expert
APP Volunteer
Default
I would suggest replacing the belt. You can tighten the one you have by loosening the four motor nuts and pull the motor forward and re-tighten the nuts. Don't overtighten, bad for motor bearings. Here is the spanner wrench for the tub nut.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Top loader only spins with large load WakeMC Washer Repair 3 09-05-2012 03:09 PM
washer leaking on large load only jojosdad Washer Repair 1 02-02-2011 02:41 PM
Washer overflows when set at large load Victor Scott Washer Repair 3 06-08-2010 03:02 PM
Overflowing on Ex-Large Load TheGrinch Washer Repair 8 03-01-2010 10:05 AM
under filling when large load is selected joebaby Washer Repair 1 08-05-2009 08:25 AM
