Discuss
Inner tub rubs against the tub lid
 in
Washer Repair
I bought and replaced the stem and seal on this washer because it was leaking. That problem is solved. But,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Inner tub rubs against the tub lid
  #1 (permalink)
Old 03-25-2013, 07:23 AM
Junior Member
johnjmcnaughton is on a distinguished road
Default Inner tub rubs against the tub lid
Model Number: A419   Brand: Maytag   Age: More than 10 years
I bought and replaced the stem and seal on this washer because it was leaking. That problem is solved. But, after putting the washer back together the inner tub is rubbing against the tub lid. This is stopping and/or slowing the inner tub from spinning. It almost seems as if though the inner tub is sitting up too high but I can't figure out why or how to get it to sit correctly. I would have thought that I put it back together exactly the way it was before I took it apart. So.....need help!!!!
Related Models
General Electric A4425GDTABB Refrigerator
General Electric A4425GDTAWW Refrigerator
Maytag A482 WASHER-TOP LOADING
Maytag A484 WASHER-TOP LOADING
Maytag A490 WASHER-TOP LOADING
Maytag A4910 WASHER-TOP LOADING
General Electric A4B561DAALQ1 Zoneline
General Electric A4B568CKALQ1 Zoneline
General Electric A4B568CKASQ1 Zoneline
General Electric A4B568DAAL2Q Zoneline
General Electric A4B568DAAL3Q Zoneline
General Electric A4B568DAALQ1 Zoneline
General Electric A4B568DAASQ1 Zoneline
General Electric A4B568DACNQ1 Zoneline
General Electric A4B568DACSQ1 Zoneline
General Electric A4B568DAFSQ1 Zoneline
General Electric A4B568DCALQ1 Zoneline
General Electric A4B568DCAS1L Zoneline
General Electric A4B568DCASQ1 Zoneline
General Electric A4B568DCCSQ2 Zoneline
General Electric A4B568DEALQ1 Zoneline
General Electric A4B568DEAS1L Zoneline
General Electric A4B568DEAS1Y Zoneline
General Electric A4B568DEASQ1 Zoneline
General Electric A4B568DECNQ1 Zoneline
General Electric A4B568DGALQ1 Zoneline
General Electric A4B568DGASQ1 Zoneline
General Electric A4B568DGCSQ1 Zoneline
General Electric A4B568DGELQ1 Zoneline
General Electric A4B568DGFSQ1 Zoneline
General Electric A4B568DJALQ1 Zoneline
General Electric A4B568DJANQ1 Zoneline
General Electric A4B568DJASQ1 Zoneline
General Electric A4B568DJCNQ1 Zoneline
General Electric A4B568DJCSQ1 Zoneline
General Electric A4B568DJELQ1 Zoneline
General Electric A4B569DAALQ1 Zoneline
General Electric A4B569DAASQ1 Zoneline
General Electric A4B569DACNQ1 Zoneline
General Electric A4B569DCALQ1 GE OVER-THE-RANGE MICROW
General Electric A4B569DEALQ1 Zoneline
General Electric A4B569DEASQ1 Zoneline
General Electric A4B569DGALQ1 Zoneline
General Electric A4B569DGASQ1 Zoneline
General Electric A4B569DJALQ1 Zoneline
General Electric A4B569DJASQ1 Zoneline
Frigidaire A4LCC2 Frg(v2) / Room Air Conditioner
Frigidaire A4LCD2 Frg(v12) / Room Air Conditioner
Maytag A4TXNWFWW00 REFRIGERATOR
Maytag A4TXNWFWW01 REFRIGERATOR
Maytag A4TXNWFWW02 REFRIGERATOR
Maytag A50 WASHER-TOP LOADING
Maytag A500 WASHER-TOP LOADING
Maytag A5000 WASHER-TOP LOADING
Maytag A500S WASHER-TOP LOADING
Jenn-Air A501 MISC / ACCESSORY
Jenn-Air A501BT MISC / ACCESSORY
Jenn-Air A501S MISC / ACCESSORY
Jenn-Air A501WT MISC / ACCESSORY
Maytag A502 WASHER-TOP LOADING
Maytag A502S WASHER-TOP LOADING
Maytag A503 WASHER-TOP LOADING
Maytag A506 WASHER-TOP LOADING
Jenn-Air A507 MISC / ACCESSORY
Jenn-Air A507B MISC / ACCESSORY
Jenn-Air A507W MISC / ACCESSORY
Jenn-Air A509 MISC / ACCESSORY
Jenn-Air A509S MISC / ACCESSORY
Maytag A510 WASHER-TOP LOADING
Maytag A510S WASHER-TOP LOADING
Maytag A511 WASHER-TOP LOADING
Maytag A511S WASHER-TOP LOADING
Maytag A512 WASHER-TOP LOADING
Maytag A512S WASHER-TOP LOADING
Jenn-Air A516 MISC / ACCESSORY
Jenn-Air A518S MISC / ACCESSORY
Jenn-Air A519 MISC / ACCESSORY
Jenn-Air A519W MISC / ACCESSORY
Jenn-Air A521B MISC / ACCESSORY
Jenn-Air A521W MISC / ACCESSORY
Jenn-Air A526 MISC / ACCESSORY
Jenn-Air A526W MISC / ACCESSORY
Jenn-Air A527B MISC / ACCESSORY
Jenn-Air A530 MISC / ACCESSORY
Jenn-Air A530W MISC / ACCESSORY
Admiral A54F-5TKXW-R WALLOVEN- S/C GAS
Admiral A54F-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FK-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FN-5TKVW-R WALLOVEN- S/C GAS
Admiral A54FN-5TKVWM-R WALLOVEN- S/C MWAVE GAS
Admiral A5651XRS RANGE- D/I CONT CLEAN ELE
Admiral A5892XRS RANGE- S/C D/I ELE
Admiral A5898VRV RANGE- S/C D/I ELE
Admiral A5898XRB RANGE- S/C D/I ELE
Admiral A59-5EXW-R WALLOVEN- S/C ELE
Maytag A590 WASHER-TOP LOADING
Maytag A5910 WASHER-TOP LOADING
Admiral A59E-5EXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59FN-5TVW-R WALLOVEN- S/C ELE
Admiral A59FN-5TVWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59G-5TXW-R RANGE- F/S STD ELE
Admiral A59GN-5TVW-R RANGE- F/S STD ELE
Frigidaire A5LECC2 Frg(v3) / Room Air Conditioner
Frigidaire A5LECDC2 Frg(v4) / Room Air Conditioner
Frigidaire A5LECDD2 Frg(v13) / Room Air Conditioner
Frigidaire A5LECDSD2 Frg(v14) / Room Air Conditioner
Frigidaire A5LECUC2 Frg(v12) / Room Air Conditioner
Maytag A606 WASHER-TOP LOADING
Maytag A606S WASHER-TOP LOADING
Maytag A608 WASHER-TOP LOADING
Maytag A608S WASHER-TOP LOADING
Maytag A610 WASHER-TOP LOADING
Maytag A612 WASHER-TOP LOADING
Maytag A612S WASHER-TOP LOADING
Maytag A613 WASHER-TOP LOADING
Admiral A6257XRS RANGE- S/I CONT CLEAN GAS
Jenn-Air A626B MISC / ACCESSORY
Jenn-Air A627W MISC / ACCESSORY
  #2 (permalink)
Old 03-25-2013, 09:16 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Did you make sure the tub cover seal was in place before re-installing it? Did you remove the set screw from the stem before screwing it down and tightening with spanner wrench? Was there any problem with screwing on the stem? Hope you didn't get it cross-threaded.
Eric
  #3 (permalink)
Old 03-25-2013, 12:51 PM
Junior Member
Default
Quote:
Eric
Hey Eric, thanks for responding!
The tub cover seal was in place and I made sure it wasn't twisted. I did remove the set screw and everything went into place without any problems. In fact, when it didn't work correctly I took it all back apart then put it back together again. Both times I had no problems.
After reading some of the other posts, I noticed some suggestions on how to center the tub. Is it possible that is my problem? I watched a few videos on how to do this job and none of them said anything about centering the tub.
  #4 (permalink)
Old 03-25-2013, 01:57 PM
Expert
APP Volunteer
Default
Did you install a new tub bearing in the outer tub when you did the stem and seal? You do have to make sure the basket is centered before tightening down the spanner nut. This may be the problem.
Eric
  #5 (permalink)
Old 03-27-2013, 11:08 AM
Junior Member
Default
Well.....unfortunately I did not change the tub bearing. I take it I was supposed to change that as well. If so, I am quite frustrated. I bought the replacement parts from Maytag. If it is well known that the tub bearing has to be replaced with the stem and seal.... they should know that and should have told me that when I ordered the parts.
I took the stem and seal and inner tub back out of the washer. I let the washer run the spin cycle and it had quite a wobble without anything attached.
So, does that mean if I replace the tub bearing that would solve that problem?
  #6 (permalink)
Old 03-27-2013, 12:15 PM
Expert
APP Volunteer
Default
What is the exact model number of your washer. The A419 is not coming up in my searches. Need serial number as well.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Basket rubs on whirlpool tub mdross Washer Repair 0 06-02-2010 05:09 PM
frigidaire condenser fan rubs gmp1993 Refrigerator & Freezer Repair 0 02-12-2010 10:29 AM
Lower Blade Rubs richierich2580 Dishwasher Repair 0 11-29-2008 04:59 PM
Drum feels loose and rubs krg Dryer Repair 1 10-24-2007 04:12 AM
