Discuss
washer repair help/no agitate or spin
 in
Washer Repair
original problem was no spin with wet clothes. agitates well and pumps well both directions. installed new belts and brake
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer repair help/no agitate or spin
  #1 (permalink)
Old 03-24-2013, 08:58 PM
Junior Member
Don Walker is on a distinguished road
Default washer repair help/no agitate or spin
Model Number: LAT2500AAE   Brand: Maytag   Age: More than 10 years
original problem was no spin with wet clothes. agitates well and pumps well both directions. installed new belts and brake assembly. failed to tell appliancepartspros about not being able to turn drive pulley and spin tub by hand. email back said to check tub bearing. seized! replaced tub bearing and seal kit. successfully ran spin cycle dry with no clothes or water. Now comes a new problem. will not agitate or spin with 1/2 load of clothes and water. pumps out water. Did i wreck new drive belt by testing and pumping out water several times before noticing the tub bearing was seized. do not remember if i touched brake assembly after the dry spin cycle test.
Related Models
Maytag LAT2500AAE WASHER-TOP LOADING
Maytag LAT2600AAE WASHER-TOP LOADING
Maytag LAT2910AAL WASHER-TOP LOADING
Maytag LAT2910AAW WASHER-TOP LOADING
Maytag LAT2914AAE WASHER-TOP LOADING
Maytag LAT2914AAL WASHER-TOP LOADING
Maytag LAT2914AAM WASHER-TOP LOADING
Maytag LAT2915AAE WASHER-TOP LOADING
Maytag LAT2915AAM WASHER-TOP LOADING
Maytag LAT2916AAE WASHER-TOP LOADING
Maytag LAT2916AAM WASHER-TOP LOADING
Maytag LAT2916ABE WASHER-TOP LOADING
Maytag LAT3500AAE WASHER-TOP LOADING
Maytag LAT3500AAQ WASHER-TOP LOADING
Maytag LAT3600AAE WASHER-TOP LOADING
Maytag LAT3600AAQ WASHER-TOP LOADING
Maytag LAT3910AAL WASHER-TOP LOADING
Maytag LAT3910AAW WASHER-TOP LOADING
Maytag LAT3914AAE WASHER-TOP LOADING
Maytag LAT3914AAL WASHER-TOP LOADING
Maytag LAT3914AAM WASHER-TOP LOADING
Maytag LAT4000AAW WASHER-TOP LOADING
Maytag LAT4910AAL WASHER-TOP LOADING
Maytag LAT4910AAW WASHER-TOP LOADING
Maytag LAT4914AAE WASHER-TOP LOADING
Maytag LAT4914AAL WASHER-TOP LOADING
Maytag LAT4914AAM WASHER-TOP LOADING
Maytag LAT4915AAE WASHER-TOP LOADING
Maytag LAT4915AAM WASHER-TOP LOADING
Maytag LAT4916AAE WASHER-TOP LOADING
Maytag LAT4916AAM WASHER-TOP LOADING
Maytag LAT4916ABE WASHER-TOP LOADING
Maytag LAT5000AAL WASHER-TOP LOADING
Maytag LAT5000AAW WASHER-TOP LOADING
Maytag LAT5000ABL WASHER-TOP LOADING
Maytag LAT5000ABW WASHER-TOP LOADING
Maytag LAT5004AAW WASHER-TOP LOADING
Admiral LAT5004AGW WASHER-TOP LOADING
Admiral LAT5004BGW WASHER-TOP LOADING
Maytag LAT5005AAE WASHER-TOP LOADING
Maytag LAT5005AAW WASHER-TOP LOADING
Maytag LAT5005ABW WASHER-TOP LOADING
Maytag LAT5006AAE WASHER-TOP LOADING
Admiral LAT5006AGE WASHER-TOP LOADING
Admiral LAT5006GGE WASHER-TOP LOADING
Maytag LAT5910AAL WASHER-TOP LOADING
Maytag LAT5910AAW WASHER-TOP LOADING
Maytag LAT5910BAL WASHER-TOP LOADING
Maytag LAT5910BAW WASHER-TOP LOADING
Maytag LAT5914AAE WASHER-TOP LOADING
Maytag LAT5914AAL WASHER-TOP LOADING
Maytag LAT5914AAM WASHER-TOP LOADING
Maytag LAT5916AAE WASHER-TOP LOADING
Maytag LAT5916AAM WASHER-TOP LOADING
Maytag LAT5916ABE WASHER-TOP LOADING
Maytag LAT6910AAL WASHER-TOP LOADING
Maytag LAT6910AAW WASHER-TOP LOADING
Maytag LAT6914AAE WASHER-TOP LOADING
Maytag LAT6914AAL WASHER-TOP LOADING
Maytag LAT6914AAM WASHER-TOP LOADING
Maytag LAT7300AAL WASHER-TOP LOADING
Maytag LAT7300AAW WASHER-TOP LOADING
Maytag LAT7300ABL WASHER-TOP LOADING
Maytag LAT7300ABW WASHER-TOP LOADING
Maytag LAT7300ABX WASHER-TOP LOADING
Maytag LAT7300AGL WASHER-TOP LOADING
Maytag LAT7300AGW WASHER-TOP LOADING
Maytag LAT7300AGX WASHER-TOP LOADING
Maytag LAT7304AAE WASHER-TOP LOADING
Maytag LAT7304AAL WASHER-TOP LOADING
Maytag LAT7304AAM WASHER-TOP LOADING
Maytag LAT7304ABE WASHER-TOP LOADING
Maytag LAT7304ABL WASHER-TOP LOADING
Maytag LAT7304ABM WASHER-TOP LOADING
Admiral LAT7304AGE WASHER-TOP LOADING
Maytag LAT7304DAL WASHER-TOP LOADING
Maytag LAT7304EGE WASHER-TOP LOADING
Admiral LAT7304GGE WASHER-TOP LOADING
Maytag LAT7306AAE WASHER-TOP LOADING
Maytag LAT7314AAE WASHER-TOP LOADING
Maytag LAT7314AAL WASHER-TOP LOADING
Maytag LAT7314AAM WASHER-TOP LOADING
Maytag LAT7334AAE WASHER-TOP LOADING
Maytag LAT7334AAL WASHER-TOP LOADING
Maytag LAT7334AAM WASHER-TOP LOADING
Maytag LAT7334ABE WASHER-TOP LOADING
Maytag LAT7400AAL WASHER-TOP LOADING
Maytag LAT7400AAW WASHER-TOP LOADING
Maytag LAT7400ABL WASHER-TOP LOADING
Maytag LAT7400ABW WASHER-TOP LOADING
Maytag LAT7400ABX WASHER-TOP LOADING
Maytag LAT7480AAL WASHER-TOP LOADING
Maytag LAT7480AAW WASHER-TOP LOADING
Maytag LAT7480ABL WASHER-TOP LOADING
Maytag LAT7480ABW WASHER-TOP LOADING
Maytag LAT7500AAL WASHER-TOP LOADING
Maytag LAT7500AAW WASHER-TOP LOADING
Maytag LAT7500ABL WASHER-TOP LOADING
Maytag LAT7500ABW WASHER-TOP LOADING
Maytag LAT7500ABX WASHER-TOP LOADING
Maytag LAT7500AGL WASHER-TOP LOADING
Maytag LAT7500AGW WASHER-TOP LOADING
Maytag LAT7500AIL WASHER-TOP LOADING
Maytag LAT7500AIW WASHER-TOP LOADING
Maytag LAT7793AAL WASHER-TOP LOADING
Maytag LAT7793AAW WASHER-TOP LOADING
Maytag LAT7793ABL WASHER-TOP LOADING
Maytag LAT7793ABW WASHER-TOP LOADING
Maytag LAT7800AAL WASHER-TOP LOADING
Maytag LAT7800AAW WASHER-TOP LOADING
Maytag LAT7800ABL WASHER-TOP LOADING
Maytag LAT7800ABW WASHER-TOP LOADING
Maytag LAT7800ABX WASHER-TOP LOADING
Maytag LAT8004AAE WASHER-TOP LOADING
Maytag LAT8004AAL WASHER-TOP LOADING
Maytag LAT8004AAM WASHER-TOP LOADING
Maytag LAT8004ABE WASHER-TOP LOADING
Maytag LAT8005AAE WASHER-TOP LOADING
Maytag LAT8005AAM WASHER-TOP LOADING
Maytag LAT8006AAE WASHER-TOP LOADING
  #2 (permalink)
Old 03-25-2013, 09:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Don,
You have to adjust belts tension after you replaced them by adjusting the pump belt. Did you do it? If not then follow the instructions attached to the post.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Washer will agitate but not spin/spin slowly sainthooligan Washer Repair 11 07-24-2010 10:34 AM
washer will not spin or agitate negron Washer Repair 1 01-11-2010 04:44 AM
washer won't agitate or spin icarus01 Washer Repair 2 09-21-2009 09:52 AM
washer won't agitate or spin out misssue Washer Repair 1 06-15-2009 10:34 AM
