I Have A Lg Wm2487hwm Lg Washer Which Is 6 Years Old The Cold Warer Valve Is Leaking How Do I Get The Top Off And What Is Your Part # For The Cold Water Valve.thanks Warren wbird99@aol.com
Hello, Unscrew two screws on the back of the plate. Pull the top plate backward and upward. - The water inlet valve Part number: 5220FR2006H
