Discuss
Are the spring rods worn out or is it something more?
 in
Washer Repair
This GE Washer I am trying to fix for a friend has the tube hanging so low drive wheel scrapping
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Are the spring rods worn out or is it something more?
  #1 (permalink)
Old 03-24-2013, 07:28 AM
Junior Member
kozmou is on a distinguished road
Default Are the spring rods worn out or is it something more?
Model Number: WHRE5550K2WW   Brand: GE   Age: 1 - 5 years
This GE Washer I am trying to fix for a friend has the tube hanging so low drive wheel scrapping bottom pan and it only does it at the fill and wash cycle. After that it seems to pull its tube up and operate normally. The top of the tube is a good 3 inches below the top cover. Would this be bad/worn out Rod & Spring Assembly or is there something I am not seeing?
Any help would be appreciated!
Age of washer is unknown as it was bought used.
Related Models
General Electric WHRE5550K2WW WASHER
General Electric WHRE5550K3WW WASHER
General Electric WHSB8000B0CC Washer
General Electric WHSB8000B0WW Washer
General Electric WHSB8000B1CC Washer
General Electric WHSB8000B1WW Washer
General Electric WHSB9000B0CC Washer
General Electric WHSB9000B0WC Washer
General Electric WHSB9000B0WW Washer
General Electric WHSE3100A0WB Washer
General Electric WHSE3100A2WB Washer
General Electric WHSE5240D0CC Washer
General Electric WHSE5240D0WW Washer
General Electric WHSE5240D1CC Washer
General Electric WHSE5240D1WW Washer
General Electric WHSE5240DCCC Washer
General Electric WHSE5240DCWW Washer
General Electric WHSR2070V2WB Washer
General Electric WHSR2070V3WB Washer
General Electric WICB103CV1WC Washer
Frigidaire WIDH3 Frg(v18) / Top Loading Washer
Frigidaire WIDH4 Frg(v3) / Top Load Washer
Frigidaire WIDL3 Frg(v19) / Top Loading Washer
Frigidaire WIDL4 Frg(v2) / Top Load Washer
Frigidaire WIDW3 Frg(v20) / Top Loading Washer
Frigidaire WIDW4 Frg(v1) / Top Load Washer
Frigidaire WILH1 Frg(v2) / 27 " Washer
Frigidaire WILL0 Frg(v2) / 27 " Washer
Frigidaire WILL1 Frg(v3) / 27 " Washer
Frigidaire WILW0 Frg(v1) / 27 " Washer
Frigidaire WILW1 Frg(v1) / 27 " Washer
Frigidaire WIMA1 Frg(v16) / Washer
Frigidaire WIMA2 Frg(v17) / Washer
Frigidaire WIMA3 Frg(v15) / Washer
Frigidaire WIMF1 Frg(v18) / Washer
Frigidaire WIMF2 Frg(v19) / Washer
Frigidaire WIMF3 Frg(v16) / Washer
Frigidaire WIMH1 Frg(v20) / Washer
Frigidaire WIMH2 Frg(v21) / Washer
Frigidaire WIMH3 Frg(v17) / Washer
Frigidaire WIML1 Frg(v22) / Washer
Frigidaire WIML2 Frg(v23) / Washer
Frigidaire WIML3 Frg(v18) / Washer
Frigidaire WIMW1 Frg(v24) / Washer
Frigidaire WIMW2 Frg(v25) / Washer
Frigidaire WIMW3 Frg(v19) / Washer
Frigidaire WISCL2 Frg(v3) / Washer
Frigidaire WISCL3 Frg(v3) / Washer
Frigidaire WISCL5 Frg(v3) / Top Loading Washer
Frigidaire WISCL6 Frg(v4) / Top Load Washer
Frigidaire WISCLL0 Frg(v4) / 27 " Washer
Frigidaire WISCLL1 Frg(v6) / 27 " Washer
Frigidaire WISCLL2 Frg(v2) / 27 " Washer
Frigidaire WISCLW0 Frg(v3) / 27 " Washer
Frigidaire WISCLW1 Frg(v4) / 27 " Washer
Frigidaire WISCLW2 Frg(v1) / 27 " Washer
Frigidaire WISCW2 Frg(v4) / Washer
Frigidaire WISCW3 Frg(v4) / Washer
Frigidaire WISCW5 Frg(v4) / Top Loading Washer
Frigidaire WISCW6 Frg(v3) / Top Load Washer
Frigidaire WISDL2 Frg(v21) / Top Loading Washer
Frigidaire WISDL3 Frg(v5) / Top Load Washer
Frigidaire WISDLL0 Frg(v6) / 27 " Washer
Frigidaire WISDLL1 Frg(v9) / 27 " Washer
Frigidaire WISDLW0 Frg(v5) / 27 " Washer
Frigidaire WISDLW1 Frg(v7) / 27 " Washer
Frigidaire WISDW2 Frg(v22) / Top Loading Washer
Frigidaire WISDW3 Frg(v4) / Top Load Washer
General Electric WISQ416AT5WW Washer
General Electric WISQ416AT6WW Washer
General Electric WISQ416AT7WW Washer
General Electric WISQ416AT8WW Washer
General Electric WISQ416ATAWW Washer
General Electric WISQ416BT5WW Washer
General Electric WISQ416BT6WW Washer
General Electric WISQ416BT7WW Washer
General Electric WISQ416BT8WW Washer
General Electric WISQ416BTAWW Washer
General Electric WISQ416CT5WW Washer
General Electric WISQ416CT6WW Washer
General Electric WISQ416CT7WW Washer
General Electric WISQ416CT8WW Washer
General Electric WISQ416CTAWW Washer
General Electric WISQ416DT5WW Washer
General Electric WISQ416DT6WW Washer
General Electric WISQ416DT7WW Washer
General Electric WISQ416DT8WW Washer
General Electric WISQ416DTAWW Washer
General Electric WISQ416FT8WW WASHER
General Electric WISQ416FTAWW Washer
General Electric WISQ416JT5AA Washer
General Electric WISQ416JT6AA Washer
General Electric WISQ416JT7AA Washer
General Electric WISQ416JT8AA Washer
General Electric WISQ416JTAAA Washer
General Electric WISR106CT5WW Washer
General Electric WISR106DGBWW Washer
General Electric WISR106DGCWW WASHER
General Electric WISR106DGDWW WASHER
General Electric WISR106DT5WW Washer
General Electric WISR106DT8WW Washer
General Electric WISR106DTAWW Washer
General Electric WISR106DTBWW Washer
General Electric WISR106HT8WW Washer
General Electric WISR106HTAWW Washer
General Electric WISR208JT5AA Washer
General Electric WISR208JT6AA Washer
General Electric WISR208JT8AA Washer
General Electric WISR208JTAAA Washer
General Electric WISR309CT5WW Washer
General Electric WISR309CT6WW Washer
General Electric WISR309CT8WW Washer
General Electric WISR309CTAWW Washer
General Electric WISR309DGBWW Washer
General Electric WISR309DGCWW WASHER
General Electric WISR309DGDWW WASHER
General Electric WISR309DT5WW Washer
General Electric WISR309DT6WW Washer
General Electric WISR309DT8WW Washer
General Electric WISR309DTAWW Washer
  #2 (permalink)
Old 03-25-2013, 07:42 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Could be the suspension rods or a sagging apron. The apron is basically the cabinet minus the top and front panels. Check to make sure all the suspension rods are in place. The top of the rods sit in plastic cups in the front and rear apron brackets. Check to see if any are broken or badly worn. Your model is supposed to have the extra clips on the front apron bracket that the top cover locks into. Previous models did not have this and a sagging apron was a frequent problem.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
suspension rods and springs SweetSpud Washer Repair 1 03-23-2012 09:50 AM
Disassembly to check the color of the suspension rods GIXXERGUY6 Washer Repair 1 08-18-2011 08:46 PM
Oven Top Support Rods came out :( MedicRN Oven Repair (including Ranges and Cooktops) 8 12-06-2009 04:27 PM
unspringy spring latched soap dispenser lid spring KimMahal Dishwasher Repair 0 02-07-2009 06:20 PM
top loading washer suspension rods and tub madisonrose05 Washer Repair 0 01-26-2008 03:51 PM
