Discuss
Maytag Epic Z won't start cycle, shuts off
 in
Washer Repair
Having a problem with a Maytag Epic Z front load washer. It powers on and lets you choose a cycle,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Epic Z won't start cycle, shuts off
  #1 (permalink)
Old 03-23-2013, 07:10 PM
Junior Member
jonnybravo_14 is on a distinguished road
Default Maytag Epic Z won't start cycle, shuts off
Model Number: MHWZ400TQ02   Brand: Maytag   Age: 1 - 5 years
Having a problem with a Maytag Epic Z front load washer. It powers on and lets you choose a cycle, then when you press start, it locks the door, spins the drum once, turns on the Wash LED, displays an Estimated Time Remaining value and starts counting down. No water comes in, and after a minute or so it powers off. Sometimes if it doesn't die within the first minute or so, it unlocks and locks the door a few times, then pauses and finally shuts off. No error codes, and when I run the manual diagnostic, it has no cached older codes. This started in the middle of a cycle and it simply shut off mid way through a Whites cycle (first time I ever used the whites cycle). It let me spin the clothes dry and it drains normally.
I checked the lines, and the inlet valve solenoids tested as expected, as per the service manual. I then checked the pressure switch. The manual indicates that it should show no resistance between four sets of pins when the diaphragm is activated by blowing into the hose inlet, but infinite resistance when it isn't. Three of the four pairs tested this way, but the fourth pair gave the opposite result -- switch is open when diaphragm isn't activated and closed when it is. This was between pins 4 and 6 on the pressure switch, for the Empty water level setting. Does this mean I have a bad pressure switch?
Related Models
Maytag MHWZ400TQ02 AUTOMATIC WASHER
Maytag MHWZ400TQ03 AUTOMATIC WASHER
Maytag MHWZ600TB00 AUTOMATIC WASHER
Maytag MHWZ600TB01 AUTOMATIC WASHER
Maytag MHWZ600TB02 AUTOMATIC WASHER
Maytag MHWZ600TE00 AUTOMATIC WASHER
Maytag MHWZ600TE01 AUTOMATIC WASHER
Maytag MHWZ600TK00 AUTOMATIC WASHER
Maytag MHWZ600TK01 AUTOMATIC WASHER
Maytag MHWZ600TK02 AUTOMATIC WASHER
Maytag MHWZ600TW00 AUTOMATIC WASHER
Maytag MHWZ600TW01 AUTOMATIC WASHER
Maytag MHWZ600TW02 AUTOMATIC WASHER
Maytag MHWZ600WR00 AUTOMATIC WASHER
Maytag MHWZ600WR01 AUTOMATIC WASHER
General Electric MIG23MIMHFBB Refrigerator
General Electric MIG23MISAFBB Refrigerator
General Electric MIG23MISBFBB Refrigerator
Maytag MIM1554VRB0 ICE CUBE MAKER
Maytag MIM1554VRS0 ICE CUBE MAKER
Maytag MIM1554VRW0 ICE CUBE MAKER
Maytag MIM1554WRS0 ICE CUBE MAKER
Maytag MIM1554WRS1 ICE CUBE MAKER
Maytag MIP85S MISC / ACCESSORY
Maytag MIP85T-2 MISC / ACCESSORY
General Electric MK KIT 1 ICEMAKER
Whirlpool MK100
Whirlpool MK110
Jenn-Air MK241W MISC / ACCESSORY
Jenn-Air MK24B MISC / ACCESSORY
Jenn-Air MK271B MISC / ACCESSORY
Jenn-Air MK271W MISC / ACCESSORY
Jenn-Air MK272B MISC / ACCESSORY
Jenn-Air MK272W MISC / ACCESSORY
Jenn-Air MK27B MISC / ACCESSORY
Jenn-Air MK27W MISC / ACCESSORY
Jenn-Air MK301B MISC / ACCESSORY
Jenn-Air MK301W MISC / ACCESSORY
Jenn-Air MK302B MISC / ACCESSORY
Jenn-Air MK302W MISC / ACCESSORY
Jenn-Air MK30B MISC / ACCESSORY
Jenn-Air MK30W MISC / ACCESSORY
Amana ML-1 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-10 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-2 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-3 MWAVE - FAMILY SIZE (60 HZ)
KitchenAid ML-42082 DISHWASHER
KitchenAid ML-42117 DISHWASHER
KitchenAid ML-42131 HEAVY DUTY DISPOSER
KitchenAid ML-42132 HEAVY DUTY DISPOSER
KitchenAid ML-42135 HEAVY DUTY DISPOSER
KitchenAid ML-42136 HEAVY DUTY DISPOSER
Whirlpool ML02CCXHW REFRIGERATOR
Whirlpool ML02CCXHW1 REFRIGERATOR
Whirlpool ML03CCXHW REFRIGERATOR
Whirlpool ML03CCXHW1 REFRIGERATOR
Whirlpool ML05CCXHW REFRIGERATOR
Whirlpool ML05CCXHW1 REFRIGERATOR
Amana ML10 MWAVE- CNTRTP / STAND ALONE
Amana ML40 AMANA MWAVE- COUNTERTOP / STAN (MICROWAVE)
Amana ML441T MWAVE- CNTRTP / STAND ALONE
Amana ML446P AMANA MWAVE- COUNTERTOP / STAN (MICROWAVE)
Amana ML451T MWAVE- CNTRTP / STAND ALONE
Frigidaire MLCE52RCS0 Tap(v1) / Laundry Center
Frigidaire MLCE52RCS1 Frg(v1) / Laundry Center
Frigidaire MLCE52RCT0 Tap(v2) / Laundry Center
Frigidaire MLCE52RCT1 Frg(v2) / Laundry Center
Amana MLD510 COMMERCIAL MICROWAVES
Amana MLD510D COMMERCIAL MICROWAVES
Maytag MLE15MNAGW MANUAL, PARTS (DRYER GAS)
Maytag MLE15MNAYW MANUAL, PARTS (DRYER ELE)
Maytag MLE15MNAZW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAUW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAYA MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAYQ MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAYW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAZW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDBGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE15PDCZW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PRAYW MANUAL, PARTS (DRYER GAS)
Maytag MLE15PRAZW MANUAL, PARTS (DRYER GAS)
Maytag MLE19PDAGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PDAYW MANUAL, PARTS (DRYER ELE)
Maytag MLE19PDAZW MANUAL, PARTS (DRYER ELE)
Maytag MLE19PDCZQ MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PDCZW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PDDGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PDDYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PNAUW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PNAYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PNDYW COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MLE19PRAYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PRAZW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE19PRDYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE2000AYW STACKED LAUNDRY- ELE
Maytag MLE2000AZW STACKED LAUNDRY- ELE
Maytag MLE23MNAUW MANUAL, PARTS (DRYER ELE)
Maytag MLE23MNAYW MANUAL, PARTS (DRYER ELE)
Maytag MLE23MNFYW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE23PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLE23PDAUW MAYTAG LAUNDRY MANUAL (DRYER ELE)
Maytag MLE23PDAYQ MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDAYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDFGW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE23PDFUW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDFYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDFZW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDHGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDHYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDHZW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PRAYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PRFYW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE23PRFZW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE24PDAGW0 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PDAYW1 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PDAZW0 COMMERCIAL ELECTRIC DRYER
  #2 (permalink)
Old 03-23-2013, 08:36 PM
Junior Member
Default
Looks like it's working again. Problem seemed to be the dispensing motor. It was humming away without moving at the same time that the inlet valve solenoids were buzzing (no water though), so I nudged the actuator arm attached to it and it started moving on its own and water started to fill. Had the filler pipe to the dispenser disconnected to test for a blockage there, so a bit of a mess, but at least it is working! There didn't seem to be any reason why the dispenser motor wasn't able to move the actuator -- any ideas? Just wondering if it'll work tomorrow
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Matag Epic Z shuts off after pressing start button tspiers Washer Repair 21 11-04-2013 06:23 AM
Maytag Epic Z problems...nothing new lol __BRYAN__ Washer Repair 2 02-23-2013 05:21 AM
maytag epic z continuously beeps when you hit start Tony123 Dryer Repair 0 10-26-2012 05:21 PM
maytag lsg7806aae shuts off on timed cycle but not custom dry cycle? pullinin Dryer Repair 1 07-14-2011 04:34 PM
