Discuss
Frigidair Front Load Washer Spin Basket is seized
 in
Washer Repair
I have a Frigidaire 2004 or 2005 Gallery series front load washer (was installed new when house was built. The
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidair Front Load Washer Spin Basket is seized
  #1 (permalink)
Old 03-23-2013, 04:43 PM
Junior Member
Mariawf is on a distinguished road
Default Frigidair Front Load Washer Spin Basket is seized
Brand: Frigidaire   Age: 5 - 10 years
I have a Frigidaire 2004 or 2005 Gallery series front load washer (was installed new when house was built. The tub has seized. It will not move at all (by hand or in any cycle). The washer will run through all cycles and it will drain. You can stop at any time and the door will unlock, so I am sure it is not the door latch issue. Please help. This is the 3rd Frigidaire Gallery appliance I have had go in a six week period and the only one whose repair may make the machine salvageable and less expensive then replacing. Thank you in advance for the help!
  #2 (permalink)
Old 03-23-2013, 05:54 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Take off the back and have a look. I am thinking that the bearing has seized and the belt has broken, else it wouldn't go through the cycles. If that is the case then you are looking at replacement.
Sorry, wish I had better news.
__________________
  #3 (permalink)
Old 03-24-2013, 02:35 PM
Junior Member
Default
Thank you. I checked. It was not the belt. I took readings on the motor per the manual and it appears the drive motor is not working, but I am almost positive it has thrown a bearing as well. I think it is just time for a new machine.
  #4 (permalink)
Old 03-24-2013, 03:39 PM
Senior Expert
APP Volunteer
Default
I have to agree with you, sorry, but good luck.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Front Load Washer Clothes Basket (Drum) just Floats around Freely wyocwboy Dryer Repair 0 09-15-2012 10:57 AM
Roper top-load washer basket/tub won't spin curth Washer Repair 3 08-01-2012 05:18 PM
Front load washer won't spin water out of clothes on last spin cycle Tracey Finley Washer Repair 1 06-28-2011 05:10 PM
Top load frigidair washer.How to separate transmission from tub?Trunnion screws were JOE7411 Washer Repair 3 03-13-2011 04:45 PM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
