elaraujo
#1 Posted : Thursday, March 21, 2013 1:44:15 PM(UTC)
elaraujo
Washer fills and drains water but drum (motor) does not rotate. I ran the diagnostic test and it does every indicator cycle (steam, fill, drain) except: C:05, C:08, and C:09 (drum rotations) where the actuators are the “Motor” and the “Motor Control (MCU)”. At the end of the test, there’s no failure display codes (F##). A tech friend suggested I changed the latch (part# W10253483). I ordered and switched the latch and ran the diagnostic test with same results. Any help is appreciated. Thanks.
elaraujo
#2 Posted : Thursday, March 21, 2013 2:42:25 PM(UTC)
elaraujo
Door locks without any problem. When I run the short "Clean Washer" cycle, drum does not rotate (wash or spin) and at the end it displays a failure code which I can not make out the digital #'s but looks like (F)26 or 28
