Discuss
Maytag won't spin
 in
Washer Repair
Here's my story: The washer runs normal except the drum doesn't spin. The pump removes all the water, but while
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag won't spin
  #1 (permalink)
Old 03-20-2013, 06:51 PM
Junior Member
ygppat is on a distinguished road
Question Maytag won't spin
Model Number: MAV208DAWW   Brand: Maytag   Age: 5 - 10 years
Here's my story: The washer runs normal except the drum doesn't spin. The pump removes all the water, but while it is supposed to be spinning the agitator runs only. I replaced the pulley, thrust bearing and it seems to be adjusted correctly. That is when turned by hand in one direction the cams lock about halfway and in the other direction the cams release. While the belt was off, I spun the pump by hand, and it is free and functional. The motor runs and the belt is tight. I did notice that if I turn the pulley by hand, in either direction, only the agitator moves. I suspect the transmission, but I really want to be sure before spending that much money. I really can't tell, but I assume that the motor is supposed to go in one direction for agitate and the other for spin?? I am not sure the motor ever reverses, but as I said if I turn the pulley by hand in either direction, all it does is agitate.
Any help would be most appreciated.
Related Models
Maytag MAV208DAWW WASHER-TOP LOADING
Admiral MAV2200AJW WASHER-TOP LOADING
Maytag MAV2755AJW WASHER-TOP LOADING
Maytag MAV2755AWW WASHER-TOP LOADING
Maytag MAV2757AWW WASHER-TOP LOADING
Maytag MAV275SAWW WASHER-TOP LOADING
Maytag MAV308DAWW WASHER-TOP LOADING
Admiral MAV3350AGW WASHER-TOP LOADING
Maytag MAV3757AWW WASHER-TOP LOADING
Maytag MAV3758AWW WASHER-TOP LOADING
Maytag MAV3855AGW WASHER-TOP LOADING
Maytag MAV3855AKW WASHER-TOP LOADING
Maytag MAV3855AWW WASHER-TOP LOADING
Maytag MAV385SAWW WASHER-TOP LOADING
Maytag MAV3905AWW WASHER-TOP LOADING
Maytag MAV3955EWW WASHER-TOP LOADING
Maytag MAV4057AWQ WASHER, ATLANTIS
Maytag MAV4057AWW WASHER, ATLANTIS
Maytag MAV408DAWK WASHER-TOP LOADING
Maytag MAV408DAWW WASHER-TOP LOADING
Maytag MAV4500AWW WASHER, ATLANTIS
Maytag MAV4755AWW WASHER-TOP LOADING
Maytag MAV4757AWW WASHER-TOP LOADING
Maytag MAV4758AWW WASHER-TOP LOADING
Maytag MAV5000AWQ WASHER, ATLANTIS
Maytag MAV5000AWW WASHER, ATLANTIS
Maytag MAV5057AWQ WASHER, ATLANTIS
Maytag MAV5057AWW WASHER, ATLANTIS
Maytag MAV551EEWW WASHER-TOP LOADING
Maytag MAV5758EWW WASHER-TOP LOADING
Maytag MAV5920AGW WASHER-TOP LOADING
Maytag MAV5920EWK WASHER-TOP LOADING
Maytag MAV5920EWW WASHER-TOP LOADING
Maytag MAV5960AWW WASHER, ATLANTIS
Maytag MAV6000AWQ WASHER, ATLANTIS
Maytag MAV6000AWW WASHER, ATLANTIS
Maytag MAV6057AWQ WASHER, ATLANTIS
Maytag MAV6057AWW WASHER, ATLANTIS
Maytag MAV6200AWQ WASHER, ATLANTIS
Maytag MAV6200AWW WASHER, ATLANTIS
Maytag MAV6250AWQ WASHER, ATLANTIS
Maytag MAV6250AWW WASHER, ATLANTIS
Maytag MAV6257AWQ WASHER, ATLANTIS
Maytag MAV6257AWW WASHER, ATLANTIS
Maytag MAV6260AWW WASHER, ATLANTIS
Admiral MAV6300AGW WASHER-TOP LOADING
Maytag MAV6300AWQ WASHER, ATLANTIS
Maytag MAV6300AWW WASHER, ATLANTIS
Admiral MAV6300BGW WASHER-TOP LOADING
Admiral MAV6300CGW WASHER-TOP LOADING
Maytag MAV6357AWW WASHER, ATLANTIS
Maytag MAV6358AWW WASHER, ATLANTIS
Maytag MAV6451AGW WASHER, ATLANTIS
Maytag MAV6451AWQ WASHER, ATLANTIS
Maytag MAV6451AWW WASHER, ATLANTIS
Maytag MAV6457AWW WASHER, ATLANTIS
Maytag MAV6458AWW WASHER, ATLANTIS
Maytag MAV6548AWQ WASHER, ATLANTIS
Maytag MAV6548AWW WASHER, ATLANTIS
Maytag MAV6601AWQ WASHER, ATLANTIS
Maytag MAV6601AWW WASHER, ATLANTIS
Maytag MAV6650AWW WASHER, ATLANTIS
Maytag MAV7000AWQ WASHER, ATLANTIS
Maytag MAV7000AWW WASHER, ATLANTIS
Maytag MAV7057AWQ WASHER, ATLANTIS
Maytag MAV7057AWW WASHER, ATLANTIS
Maytag MAV7200AWQ WASHER, ATLANTIS
Maytag MAV7200AWW WASHER, ATLANTIS
Maytag MAV7257AWQ WASHER, ATLANTIS
Maytag MAV7257AWW WASHER, ATLANTIS
Maytag MAV7258AWQ WASHER, ATLANTIS
Maytag MAV7258AWW WASHER, ATLANTIS
Maytag MAV7260AWW WASHER, ATLANTIS
Maytag MAV7260BWW WASHER, ATLANTIS
Maytag MAV7357AWQ WASHER, ATLANTIS
Maytag MAV7357AWW WASHER, ATLANTIS
Maytag MAV7358AWQ WASHER, ATLANTIS
Maytag MAV7358AWW WASHER, ATLANTIS
Maytag MAV7450AWQ WASHER, ATLANTIS
Maytag MAV7450AWW WASHER, ATLANTIS
Maytag MAV7501EWW WASHER, ATLANTIS
Maytag MAV7504EWW WASHER, ATLANTIS
Maytag MAV7550AWQ WASHER, ATLANTIS
Maytag MAV7550AWW WASHER, ATLANTIS
Maytag MAV7551AWQ WASHER, ATLANTIS
Maytag MAV7551AWW WASHER, ATLANTIS
Maytag MAV7557EWQ WASHER, ATLANTIS
Maytag MAV7557EWW WASHER, ATLANTIS
Maytag MAV7580EWQ WASHER, ATLANTIS
Maytag MAV7580EWW WASHER, ATLANTIS
Admiral MAV7600ACQ WASHER-TOP LOADING
Admiral MAV7600AGW WASHER-TOP LOADING
Maytag MAV7600AWQ WASHER, ATLANTIS
Maytag MAV7600AWW WASHER, ATLANTIS
Admiral MAV7600BGW WASHER-TOP LOADING
Admiral MAV7600CGW WASHER-TOP LOADING
Maytag MAV7650AWQ WASHER, ATLANTIS
Maytag MAV7650AWW WASHER, ATLANTIS
Maytag MAV7657EWQ WASHER, ATLANTIS
Maytag MAV7657EWW WASHER, ATLANTIS
Maytag MAV7700AWQ WASHER, ATLANTIS
Maytag MAV7700AWW WASHER, ATLANTIS
Admiral MAV7750AGW WASHER-TOP LOADING
Admiral MAV7750BGW WASHER-TOP LOADING
Admiral MAV7750CGW WASHER-TOP LOADING
Maytag MAV7757AWQ WASHER, ATLANTIS
Maytag MAV7757AWW WASHER, ATLANTIS
Maytag MAV8000AWQ WASHER, ATLANTIS
Maytag MAV8000AWW WASHER, ATLANTIS
Maytag MAV8057AWQ WASHER, ATLANTIS
Maytag MAV8057AWW WASHER, ATLANTIS
Maytag MAV8260AWQ WASHER, ATLANTIS
Maytag MAV8260AWW WASHER, ATLANTIS
Maytag MAV8500AWQ WASHER, ATLANTIS
Maytag MAV8500AWW WASHER, ATLANTIS
Maytag MAV8551AWQ WASHER, ATLANTIS
Maytag MAV8551AWW WASHER, ATLANTIS
Maytag MAV8557AWQ WASHER, ATLANTIS
Maytag MAV8557AWW WASHER, ATLANTIS
Maytag MAV8600AWQ WASHER, ATLANTIS
  #2 (permalink)
Old 03-20-2013, 08:41 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Bad transmission. The input pinion gear has an integral anti-backup device that should prevent operation in the spin direction. If the pump works, then the motor is reversing for the drain/spin cycle.
Eric
  #3 (permalink)
Old 03-21-2013, 10:03 AM
Junior Member
maurapmccarthy is on a distinguished road
Default Maytag A5000 won't spin
I replaced my belts and the little one spins but the bigger heavier one doesn't spin... I have tightened the belts according to the examples. Does the big middle unit spin normally?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LOW-SPIN DURING SPIN CYCLE of MayTag Neptune Dryer/Washer stack mrdhoffman Washer Repair 1 08-30-2011 06:45 PM
Maytag A612S won't spin during spin cycles WQ2121 Washer Repair 3 07-18-2011 07:53 AM
Maytag Washer no spin at final spin and 3E keeps coming up chanchar Washer Repair 1 06-27-2011 06:02 PM
Maytag Neptune Super Stack will not spin while in spin cycle. Vohn Washer Repair 2 11-04-2010 08:30 AM
Maytag washer won't spin on spin cycle steve2zastrow Washer Repair 0 11-27-2009 09:04 AM
