Discuss
Kenmore stackable washer/dryer won't drain or spin
 in
Washer Repair
I have a Kenmore stackable washer/dryer 417.94702300 that will not spin or drain. Called Sears Tech and he took off
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore stackable washer/dryer won't drain or spin
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-20-2013, 07:26 AM
Junior Member
penelope therese is on a distinguished road
Default Kenmore stackable washer/dryer won't drain or spin
Brand: Kenmore   Age: 1 - 5 years
I have a Kenmore stackable washer/dryer 417.94702300 that will not spin or drain. Called Sears Tech and he took off front and side of unit didn't look at anything like the motor. After 10 minutes of of looking inside the compartment with the motor in it recommended me to call electrician to replace the plug and the outlet in the wall. Did and washer ran for about 3 weeks and started doing the same thing. Tub fills, washes but will not drain or spin. Makes a buzzing/humming sound. No burning smells present. Why would it run for 3 weeks with the new plug and wall outlet, then stop? Could it be the lid safety switch? Any responses would be appreciated.
  #2 (permalink)
Old 03-20-2013, 08:56 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
First of all if the machine was operating except for the spin drain there was no problem with the electrical service, and had there been a simple 10 second test could have told the service tech there was a problem.
Quite frankly I don't know why the machine operated correct after you had the plug replaced, but one possibility is that there was/is a problem with the lid lock mechanism and that moving it around temporarily fixed it. Another possibility is the timer. A third is something jammed in the system.
My recommendation is that you call Sears, tell them you paid for a repair visit that did not fix the problem and gave a bad diagnosis and that they need to get out to your house and fix the problem with no additional service cost. My thinking is that the service tech had no idea about the problem and just gave the diagnosis of the electrical outlet to get out of there.
I don't know how Sears will respond, but you did not get the service you paid for and I would pressure Sears to the maximum extent possible to get it right.
__________________
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer/Dryer combo won't drain or spin uttdawg Washer Repair 5 12-30-2014 09:01 AM
Stackable washer does not spin or drain North Dakota Washer Repair 1 01-24-2013 11:26 AM
Kenmore Stackable Washer & Dryer kmrober Dryer Repair 0 07-02-2012 10:56 AM
Kenmore stackable washer/dryer jasonhart1 Washer Repair 1 04-18-2011 04:31 PM
Stackable Kenmore/Frigidaire washer won't spin sidevinder Washer Repair 3 05-04-2009 04:42 PM
