| » Maytag spins too slow |
Model Number: Hav2460aww Brand: Maytag Age: 5 - 10 years
Maytag washer has just started spinning too slowly. Always seems out of balance too, even on a small light load.
Re-running the spin does not assist in getting extra water out. Where should I start in addressing issue? Ads By Google Related Models |
Remove front panel and check that all the suspension springs are in place. The motor should freely pivot back and forth. The plate and pivot points can get dirty and gummed up preventing proper pivoting of the motor which causes improper belt tension. Look for white powder around bottom center. Snubber ring may be wearing and need replacement. A worn thrust bearing and/or cams on the pulley assembly can cause improper brake release reducing spin speed.
Eric |
| Display Modes | |
| spins slow | Mi duckdown | Washer Repair | 0 | 05-18-2011 10:03 PM |
| Maytag Washer Spins Slow - Motor Overheats | tdk2828 | Washer Repair | 0 | 01-30-2011 07:16 PM |
| washer spins to slow | captainda | Washer Repair | 1 | 12-06-2009 07:22 AM |
| washer spins slow | Jamie2009 | Washer Repair | 1 | 08-18-2009 06:36 PM |
| washer spins too slow | soggyclothes | Washer Repair | 1 | 02-10-2009 01:17 PM |
