Discuss
Kenmore washer won't drain or spin
 in
Washer Repair
My Kenmore stopped at the end of the wash cycle and wouldn't drain. I moved the timer to check other
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore washer won't drain or spin
  #1 (permalink)
Old 03-18-2013, 01:01 PM
Junior Member
Karen.Smith is on a distinguished road
Question Kenmore washer won't drain or spin
Model Number: 110.23922200   Brand: Kenmore   Age: 5 - 10 years
My Kenmore stopped at the end of the wash cycle and wouldn't drain. I moved the timer to check other wash and rinse cycles, and it made no difference. All the wash and rinse agitations work.
I tested the lid switch with the jumper wire, and the washer drained and spun. So I bought a new lid switch ($45), installed it, tested it before putting it all back together (it worked), ran a load of clothes, and same thing. It stopped at the end of the wash cycle and wouldn't drain.
Removed the clothes, used the jump wire again and the washer drained and spun.
There is absolutely no noise once it stops agitating or any abnormal noise while it is agitating.
The timer has been suggested by both a friend and the appliance parts store, but from reading other posts, I'm doubtful. It's $110 part, that can't be tested or returned.
I don't understand why it works with the jump wire and not without. With the jump wire both times, I allowed the washer to drain and spin. After I put the lid switch in, there was no water to drain out, but it did spin, so I put the case back on.
And now I'm back to where I started. Washer won't drain or spin. If I buy a timer and it doesn't work, I'll have wasted $155 that I could have spent on a used washer. I appreciate any help or advice. I saw in some other posts about schematics and there is one folded up inside the console that I could scan and post, if that would help. Thank you!
Ads By Google
Related Models
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42836201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42922200  WASHER
Kenmore 110.42924200  WASHER
Kenmore 110.42926200  WASHER
Kenmore 110.42932200  WASHER
Kenmore 110.42934200  WASHER
Kenmore 110.42936200  WASHER
Kenmore 110.4319351  BURNER ASSEMBLY
Kenmore 110.4319410  GAS DRYER BURNER
Kenmore 110.44832200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44834200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44836200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44932200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44934200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.44936200  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.4760294  WASHER
Kenmore 110.4766195  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.4766295  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.48182790  AUTOMATIC WASHER
Kenmore 110.48182791  AUTOMATIC WASHER
Kenmore 110.48184790  AUTOMATIC WASHER
Kenmore 110.48184791  AUTOMATIC WASHER
Kenmore 110.48722790  COMPACT AUTOMATIC WASHER
Kenmore 110.48722791  COMPACT AUTOMATIC WASHER
Kenmore 110.48724790  COMPACT AUTOMATIC WASHER
Kenmore 110.48724791  COMPACT AUTOMATIC WASHER
Kenmore 110.49182990  AUTOMATIC WASHER
Kenmore 110.49182991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.49740  STACK STAND KIT
Kenmore 110.508802  KENMORE ELECTRIC DRYER
Kenmore 110.5807100  KENMORE GAS DRYER
Kenmore 110.5807300  KENMORE GAS DRYER
Kenmore 110.5807410  KENMORE GAS DRYER
Kenmore 110.5807500  KENMORE GAS DRYER
Kenmore 110.5807501  KENMORE GAS DRYER
Kenmore 110.5807700  KENMORE GAS DRYER
Kenmore 110.5807701  KENMORE GAS DRYER
Kenmore 110.5807800  KENMORE GAS DRYER
Kenmore 110.5807801  GAS DRYER
Kenmore 110.5807810  KENMORE GAS DRYER
Kenmore 110.5807811  KENMORE GAS DRYER
Kenmore 110.5807850  KENMORE GAS DRYER
Kenmore 110.5807851  GAS DRYER
Kenmore 110.5807860  KENMORE GAS DRYER
Kenmore 110.5807861  KENMORE GAS DRYER
Kenmore 110.5807950  KENMORE GAS DRYER
Kenmore 110.5807951  GAS DRYER
Kenmore 110.5807960  KENMORE GAS DRYER
  #2 (permalink)
Old 03-18-2013, 01:33 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
Don't change the timer yet. It seems that the lid switch circuit is the problem. Make sure when you plug the wire harness connector into the lid switch connector on the cabinet that none of the pins are being pushed out of the connector. Check the actuator on the lid. Can you hear the lid switch "click" when closing the lid? Cut the plug off the old lid switch leaving a couple inches of wire. Strip the two black wires about 1/2" and twist the wire strands together, install a wire nut and tape it up with electrical tape. Use that to temporarily jump it out to do laundry until you figure out the problem. Keep your kids away from the washer if you do this!
Eric
  #3 (permalink)
Old 03-18-2013, 04:14 PM
Junior Member
Default
Thank you for your reply. Yes I can hear the click when closing the lid. And I never imagined I would need the old switch and left it with the shop to recycle. I can call them and ask if they still have it since today is the first business day since I bought it. However, is there a difference between using the jump wire or twisting the 2 wires from the old switch? There are no kids to worry about
Update: I just called the shop and they have my old switch. Does the fact that I can hear the click mean something? Just wondering how to figure out the problem, or how long can I leave those wires nutted together?
  #4 (permalink)
Old 03-18-2013, 04:50 PM
Expert
APP Volunteer
Default
Well, the click generally indicates that the switch is engaging. The problem with the jumper wire is that it is not likely making as good a connection as using the connector with the proper fitting pins in it. Full motor current goes through this switch in drain/spin cycle and if it's not a good solid connection, it can get hot and create it's own problems. I can't advocate leaving the switch jumped out because it's a safety issue so that's your call on what you want to do. If you leave it in for a few loads and the problem doesn't re-occur, at least you know that it is the problem and not just a coincidental intermittent problem with something else such as the timer.
Eric
  #5 (permalink)
Old 03-18-2013, 04:59 PM
Junior Member
Default
I will pick up the old switch tomorrow and do as you suggested in your first reply to be able to use it temporarily. I won't use the jumper wire. I'm not clear on what you think could be the problem. A faulty new intermittent switch, or the timer?
  #6 (permalink)
Old 03-18-2013, 06:09 PM
Expert
APP Volunteer
Default
The only real way to tell is to troubleshoot with a multimeter doing some tests on live line voltage which you have no experience at so best to just run it with the switch jumped out for a few loads. If it runs without any problem, reconnect the lid switch and try it. If it fails again, either the switch is bad or there is some misalignment with the switch and the actuator on the lid.
Eric
  #7 (permalink)
Old 03-18-2013, 07:28 PM
Junior Member
Default
Got it, thanks! I removed the plug and looked at the pins. Nothing looked out of ordinary. Plugged it back in, and now it's working. Looking like intermittent switch issue? It's a reputable local appliance parts shop. I'll report back if I get any other symptoms to report. I'm going to monitor this wash load right now.
Thank you again very much!
Karen
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer does not drain or spin theturtlefactory Washer Repair 5 04-04-2011 05:27 AM
Kenmore Washer No Spin No drain cmarshall3 Washer Repair 4 01-17-2011 06:24 AM
Kenmore washer won't drain or spin ApplianceBear Washer Repair 0 11-13-2010 10:11 AM
Kenmore washer won't drain or spin bhatiahn Washer Repair 4 04-26-2009 08:00 PM
Kenmore washer won't drain or spin stacistephenson Washer Repair 1 08-15-2008 11:28 AM
