Discuss
Can't Spin Washer Tub by Hand
 in
Washer Repair
Motor coupler went - fixed and worked for 2 months. Motor coupler went, stripped in middle, agitated but wouldn't spin
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Can't Spin Washer Tub by Hand
  #1 (permalink)
Old 03-17-2013, 02:47 PM
SGF SGF is offline
Junior Member
SGF is on a distinguished road
Default Can't Spin Washer Tub by Hand
Model Number: 11092588210   Brand: Kenmore   Age: 1 - 5 years
Motor coupler went, stripped in middle, agitated but wouldn't spin turned out motor coupler partially stripped so would had stopped agitating too - found that out after pulling everything apart, cleaned tubs of mud, checked drive block was good, made sure transmission worked, could not turn the clutch by finger force and it was dry - so everything appeared good outside of the failed coupler. Put it all back together w new coupler and worked for a week and a half.
Now won't spin but as always everything else works, just won't spin.
One thing I have noticed is that every repair person asks 'if spin cycle is on can you spin the tub by hand?' - Everyone says yes but that is not the case for me. I bypass lid switch but cannot spin the tub by hand, not at all- what problem does that indicate? Brake lock? - and/or what is the fix if that problem is obvious.
Thanks!
Related Models
Kenmore 11092588210 WASHER
Kenmore 11092588400 WASHER
Kenmore 11092588410 WASHER
Kenmore 11092590100 AUTOMATIC WASHER
Kenmore 11092590110 WASHER
Kenmore 11092590120 WASHER
Kenmore 11092590800 AUTOMATIC WASHER
Kenmore 11092590810 WASHER
Kenmore 11092590820 WASHER
Kenmore 11092591200 WASHER
Kenmore 11092591210 WASHER
Kenmore 11092591220 WASHER
Kenmore 11092591230 WASHER
Kenmore 11092591400 WASHER
Kenmore 11092591410 WASHER
Kenmore 11092591420 WASHER
Kenmore 11092591430 WASHER
Kenmore 11092592200 WASHER
Kenmore 11092592400 WASHER
Kenmore 11092593200 WASHER
Kenmore 11092593210 WASHER
Kenmore 11092593220 Residential Washers
Kenmore 11092593400 WASHER
Kenmore 11092593410 WASHER
Kenmore 11092593420 Residential Washers
Kenmore 11092595200 Residential Washers
Kenmore 11092595210 Residential Washers
Kenmore 11092595400 WASHER
Kenmore 11092595410 Residential Washers
Kenmore 11092595500 Residential Washers
Kenmore 11092595510 Residential Washers
Kenmore 11092596100 WASHER
Kenmore 11092597200 AUTOMATIC WASHER
Kenmore 11092597210 AUTOMATIC WASHER
Kenmore 11092597400 AUTOMATIC WASHER
Kenmore 11092597410 AUTOMATIC WASHER
Kenmore 11092598200 Residential Washers
Kenmore 11092598400 Residential Washers
Kenmore 11092599200 Residential Washers
Kenmore 11092599400 Residential Washers
Kenmore 11092599500 Residential Washers
Kenmore 11092822100 GAS DRYER
Kenmore 11092822101 GAS DRYER
Kenmore 11092822102 GAS DRYER
Kenmore 11092822103 RESIDENTIAL DRYER
Kenmore 11092824100 GAS DRYER
Kenmore 11092824101 GAS DRYER
Kenmore 11092824102 GAS DRYER
Kenmore 11092824103 RESIDENTIAL DRYER
Kenmore 11092826100 GAS DRYER
Kenmore 11092826101 GAS DRYER
Kenmore 11092826102 GAS DRYER
Kenmore 11092826103 RESIDENTIAL DRYER
Kenmore 11092832100 DRYER
Kenmore 11092834100 DRYER
Kenmore 11092836100 DRYER
Kenmore 11092962100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092962101 LAUNDRY SYSTEM
Kenmore 11092962102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092964100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092964101 LAUNDRY SYSTEM
Kenmore 11092964102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092966100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092966101 LAUNDRY SYSTEM
Kenmore 11092966102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092972100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092972101 LAUNDRY SYSTEM
Kenmore 11092972102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092974100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092974101 LAUNDRY SYSTEM
Kenmore 11092974102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092976100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092976101 LAUNDRY SYSTEM
Kenmore 11092976102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094518200 COMPACT AUTOMATIC WASHER
Kenmore 11094518201 AUTOMATIC WASHER
Kenmore 11094518400 COMPACT AUTOMATIC WASHER
Kenmore 11094518401 AUTOMATIC WASHER
Kenmore 11094519100 WASHER
Kenmore 11094519800 WASHER
Kenmore 11094570100 COMPACT WASHER
Kenmore 11094570800 COMPACT WASHER
Kenmore 11094572200 COMPACT WASHER
Kenmore 11094572201 AUTOMATIC WASHER
Kenmore 11094572400 COMPACT WASHER
Kenmore 11094572401 AUTOMATIC WASHER
Kenmore 11094762300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094818200 AUTOMATIC WASHER
Kenmore 11094818400 AUTOMATIC WASHER
Kenmore 11094821300 GAS DRYER
Kenmore 11094821301 RESIDENTIAL DRYER
Kenmore 11094831300 GAS DRYER
Kenmore 11094831301 RESIDENTIAL DRYER
Kenmore 11094832200 GAS DRYER
Kenmore 11094832201 GAS DRYER
Kenmore 11094834200 GAS DRYER
Kenmore 11094834201 GAS DRYER
Kenmore 11094836200 GAS DRYER
Kenmore 11094836201 GAS DRYER
Kenmore 11094872200 COMPACT AUTOMATIC WASHER
Kenmore 11094872400 COMPACT AUTOMATIC WASHER
Kenmore 11094962300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094964300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094966300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094972300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094974300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094976300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11095081400 RESIDENTIAL DRYER
Kenmore 11095081401 DRYER
Kenmore 11095081402 RESIDENTIAL DRYER
Kenmore 11095087400 DRYER
Kenmore 11095087401 DRYER GAS
Kenmore 11095087402 RESIDENTIAL DRYER
Kenmore 11095088400 DRYER
Kenmore 11095088401 DRYER GAS
Kenmore 11095088402 RESIDENTIAL DRYER
Kenmore 11095089400 DRYER
Kenmore 11095089401 DRYER
Kenmore 11095089402 RESIDENTIAL DRYER
Kenmore 11095091400 RESIDENTIAL DRYER
  #2 (permalink)
Old 03-17-2013, 05:31 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Need to run it in spin mode with the cabinet off and lid switch bypassed. Observe the clutch hub. If the motor is running and the clutch hub is not spinning, there is a gearcase issue. If the hub is spinning then either the clutch is slipping, the brake cam driver is defective or there is a problem with the basket drive. If the clutch hub spins ok, I would remove the agitator and the gearcase. Grab the brake cam driver and rotate it CCW by hand. This should release the brakes and allow the basket to rotate fairly easily. You can see if the brakes release ok. If they release and it is difficult to rotate the basket, there may be clothing caught between the tubs.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't agitate or spin, can turn motor by hand englaisfitz Washer Repair 23 11-14-2014 07:41 AM
GE washer won't spin unless i give it a hand. nannerz11 Washer Repair 1 12-16-2011 05:50 PM
Have to spin dryer by hand neonmike Dryer Repair 1 10-08-2009 02:04 PM
