Discuss
Whirlpool washer won't fill with cold water
 in
Washer Repair
Whirlpool washer won't fill with cold water. It does fill with hot but not cold. Took off hose and cold
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer won't fill with cold water
  #1 (permalink)
Old 03-17-2013, 01:43 PM
Junior Member
tjwinters is on a distinguished road
Default Whirlpool washer won't fill with cold water
Brand: Whirlpool   Age: 5 - 10 years
Took off hose and cold water flows through the hose Ok. Any Help? Thanks.
  #2 (permalink)
Old 03-17-2013, 06:10 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
What is the model number of the washer?
Swap the electrical connections at the hot/cold solenoid valves and set it for hot water. If you don't get cold water, the valve assembly is bad. Check the inlet screen of the valve to make sure it isn't clogged up.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Front Load Washer No Cold Water Fill RaB1 Washer Repair 1 02-13-2013 04:34 PM
Maytag washer will not agitate/cold water fill won't shut off denise2855 Washer Repair 12 03-09-2012 06:44 PM
Maytag front load washer will not fill with cold water gclosius Washer Repair 1 11-29-2009 12:27 PM
Washer does not start rinse, will not fill with cold water Gene51 Washer Repair 10 06-27-2009 04:09 PM
washer leaking on cold water fill slgreene Washer Repair 0 12-27-2008 07:09 AM
