Discuss
Duet washer
 in
Washer Repair
Duet whirlpool washer is leaking water from under the soap dispenser, as soon as the washer starts filling . Need
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Duet washer
  #1 (permalink)
Old 03-16-2013, 10:11 PM
Junior Member
Pm76 is on a distinguished road
Default Duet washer
Brand: Whirlpool   Age: 5 - 10 years
Duet whirlpool washer is leaking water from under the soap dispenser, as soon as the washer starts filling . Need help, is it something that can be fixed easily, or do I need to call for repair. Please help.
  #2 (permalink)
Old 03-19-2013, 06:00 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
This could be a cracked soap dispenser basin, but more likely a cracked water line. When the machine fills the water is diverted through the soap dispenser to the basket.
This is some you can fix, start back taking off the top and see if you can determine the problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
duet washer akwasilik Washer Repair 1 07-30-2012 09:57 PM
duet washer fmamone Washer Repair 1 04-20-2012 02:46 AM
duet washer ccu 211008659 Washer Repair 0 11-23-2010 02:04 PM
Duet Washer dameese Washer Repair 3 05-24-2009 04:48 PM
Duet Washer hdebby Washer Repair 1 10-20-2008 01:25 PM
