Discuss
Maytag Washer Won't Agitate
 in
Washer Repair
My Maytag Washer won't agitate. It goes through it's normal cycles: The water fills, timer advances through the wash and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Washer Won't Agitate
  #1 (permalink)
Old 02-05-2008, 10:14 AM
Junior Member
shoeheel is on a distinguished road
Default Maytag Washer Won't Agitate
Model Number: LAT8624AAE   Brand: Maytag   Age: More than 10 years
My Maytag Washer won't agitate. It goes through it's normal cycles: The water fills, timer advances through the wash and rinse cycles, water spins out and stops. Everything seems to work, BUT NO AGITATION. (It does "agitate" for a few seconds during the pre-soak soak. I assume this is normal to mix the soap, water & close up. True?)
I have a wiring diagram. What relays should be closed during agitation? Where should I check for voltage when it should be agitating. (I'm thinking there is a problem with the timer contacts, but I don't want to spend $100 on it, if it's not the timer.)
THANKS!
Ads By Google
Related Models
Maytag LAT8624AAE Washer - Top Loading
Maytag LAT8624AAL Washer - Top Loading
Maytag LAT8624AAM Washer - Top Loading
Maytag LAT8624ABE Washer - Top Loading
Maytag LAT8624ABL Washer - Top Loading
Maytag LAT8624ABM Washer - Top Loading
Maytag LAT8626AAE Washer - Top Loading
Maytag LAT8626AAM Washer - Top Loading
Maytag LAT8626ABE Washer - Top Loading
Maytag LAT8640AAL Washer - Top Loading
Maytag LAT8640AAW Washer - Top Loading
Maytag LAT8640ABL Washer - Top Loading
Maytag LAT8640ABW Washer - Top Loading
Maytag LAT8640BAL Washer - Top Loading
Maytag LAT8640BAW Washer - Top Loading
Maytag LAT8640BBL Washer - Top Loading
Maytag LAT8640BBW Washer - Top Loading
Maytag LAT8650AAL Washer - Top Loading
Maytag LAT8650AAW Washer - Top Loading
Maytag LAT8650ABL Washer - Top Loading
Maytag LAT8650ABW Washer - Top Loading
Maytag LAT8650BAL Washer - Top Loading
Maytag LAT8650BAW Washer - Top Loading
Maytag LAT8650BBL Washer - Top Loading
Maytag LAT8650BBW Washer - Top Loading
Maytag LAT8700AAL Washer - Top Loading
Maytag LAT8700AAW Washer - Top Loading
Maytag LAT8700ABL Washer - Top Loading
Maytag LAT8700ABW Washer - Top Loading
Maytag LAT8704AAE Washer - Top Loading
Maytag LAT8704AAL Washer - Top Loading
Maytag LAT8704AAM Washer - Top Loading
Maytag LAT8705AAE Washer - Top Loading
Maytag LAT8705AAM Washer - Top Loading
Maytag LAT8706AAE Washer - Top Loading
Maytag LAT8706AAM Washer - Top Loading
Maytag LAT8714AAE Washer - Top Loading
Maytag LAT8714AAL Washer - Top Loading
Maytag LAT8714AAM Washer - Top Loading
Maytag LAT8740AAL Washer - Top Loading
Maytag LAT8740AAW Washer - Top Loading
Maytag LAT8800AAL Washer - Top Loading
Maytag LAT8800AAW Washer - Top Loading
Maytag LAT8800ABL Washer - Top Loading
Maytag LAT8800ABW Washer - Top Loading
Maytag LAT8804AAE Washer - Top Loading
Maytag LAT8804AAL Washer - Top Loading
Maytag LAT8804AAM Washer - Top Loading
Maytag LAT8804ABE Washer - Top Loading
Maytag LAT8816AAE Washer - Top Loading
Maytag LAT8816AAM Washer - Top Loading
Maytag LAT8820AAL Washer - Top Loading
Maytag LAT8820AAW Washer - Top Loading
Maytag LAT8820ABL Washer - Top Loading
Maytag LAT8820ABW Washer - Top Loading
Maytag LAT8820BAL Washer - Top Loading
Maytag LAT8820BAW Washer - Top Loading
Maytag LAT8820BBL Washer - Top Loading
Maytag LAT8820BBW Washer - Top Loading
Maytag LAT8824AAE Washer - Top Loading
Maytag LAT8824AAL Washer - Top Loading
Maytag LAT8824AAM Washer - Top Loading
Maytag LAT8824ABE Washer - Top Loading
Maytag LAT8826AAE Washer - Top Loading
Maytag LAT8826AAM Washer - Top Loading
Maytag LAT8840AAL Washer - Top Loading
Maytag LAT8840AAW Washer - Top Loading
Maytag LAT8840ABL Washer - Top Loading
Maytag LAT8840ABW Washer - Top Loading
Maytag LAT8840BAL Washer - Top Loading
Maytag LAT8840BAW Washer - Top Loading
Maytag LAT8840BBL Washer - Top Loading
Maytag LAT8840BBW Washer - Top Loading
Maytag LAT8904AAE Washer - Top Loading
Maytag LAT8904AAL Washer - Top Loading
Maytag LAT8904AAM Washer - Top Loading
Maytag LAT9200AAE Washer - Top Loading
Maytag LAT9200AAG Washer - Top Loading
Maytag LAT9200AAL Washer - Top Loading
Maytag LAT9200AAM Washer - Top Loading
Maytag LAT9200AAW Washer - Top Loading
Maytag LAT9200ABE Washer - Top Loading
Maytag LAT9200ABL Washer - Top Loading
Maytag LAT9200ABM Washer - Top Loading
Maytag LAT9200ABW Washer - Top Loading
Maytag LAT9200BAE Washer - Top Loading
Maytag LAT9200BAL Washer - Top Loading
Maytag LAT9200BAM Washer - Top Loading
Maytag LAT9200BAW Washer - Top Loading
Maytag LAT9200BBE Washer - Top Loading
Maytag LAT9200BBL Washer - Top Loading
Maytag LAT9200BBM Washer - Top Loading
Maytag LAT9200BBW Washer - Top Loading
Maytag LAT9200DAG Washer - Top Loading
Maytag LAT9200DAL Washer - Top Loading
Maytag LAT9200DAW Washer - Top Loading
Maytag LAT9200DAX Washer - Top Loading
Maytag LAT9205AAE Washer - Top Loading
Maytag LAT9205AAM Washer - Top Loading
International LAT9205GGE Washer - Top Loading
Maytag LAT9206AAE Washer - Top Loading
Maytag LAT9206AAM Washer - Top Loading
Maytag LAT9206ABE Washer - Top Loading
Maytag LAT9206ABM Washer - Top Loading
Maytag LAT9206BAE Washer - Top Loading
Maytag LAT9206BAM Washer - Top Loading
Maytag LAT9206BAQ Washer - Top Loading
Maytag LAT9206BBE Washer - Top Loading
Maytag LAT9206BBM Washer - Top Loading
Maytag LAT9235AAE Washer - Top Loading
Maytag LAT9235AAM Washer - Top Loading
Maytag LAT9280AAL Washer - Top Loading
Maytag LAT9280AAW Washer - Top Loading
Maytag LAT9280ABL Washer - Top Loading
Maytag LAT9280ABW Washer - Top Loading
Maytag LAT9300AAL Washer - Top Loading
Maytag LAT9300AAW Washer - Top Loading
Maytag LAT9300ABL Washer - Top Loading
Maytag LAT9300ABW Washer - Top Loading
Maytag LAT9304AAE Washer - Top Loading
  #2 (permalink)
Old 02-05-2008, 05:50 PM
Junior Member
Default
Never mind. I bit the bullet and bought a new timer. PROBLEM SOLVED. It was a bad (worn out) timer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Washer does not agitate or spin myvelasquez Washer Repair 5 01-10-2010 07:28 PM
Maytag commercial washer wont agitate techman20 Washer Repair 2 10-27-2009 10:22 AM
Maytag washer clunking on agitate cycle Jodil73104 Washer Repair 2 10-22-2009 09:08 AM
Maytag LA283 washer does not agitate bluesnails Washer Repair 1 08-09-2009 04:46 PM
Maytag washer fills but doesn't agitate Relztrah Washer Repair 1 06-25-2009 07:04 AM
