Discuss
Won't agetate or spin
 in
Washer Repair
The washer will go through a complete cycle. Fills, won't agitate, won't spin, will drain... The motor/inverter has a 1second
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Won't agetate or spin
  #1 (permalink)
Old 03-15-2013, 03:14 PM
Junior Member
jtbgonesailing is on a distinguished road
Default Won't agetate or spin
Model Number: WLSR3000G3WW   Brand: GE   Age: 1 - 5 years
The washer will go through a complete cycle. Fills, won't agitate, won't spin, will drain... The motor/inverter has a 1second on 1second off flash. Have jumped lid magnet sensor, which is good, and still no agitation, spinning. The fuseable link in the white/red line is good. Can't figure it out. Help please...
Thanks in advance,
John
Related Models
General Electric WLSR3000G3WW WASHER
General Electric WLSR3000G4WW WASHER
General Electric WLSR3000G5WW WASHER
General Electric WLSR3000G6WW WASHER
Frigidaire WLW0 Frg(v1) / 27 " Washer
Frigidaire WLW1 Frg(v1) / 27 " Washer
General Electric WLW1500BAL Washer
General Electric WLW1500BBL Washer
General Electric WLW1500BCL Washer
General Electric WLW1500BNL Washer
General Electric WLW1500RBL Washer
General Electric WLW2330BAL Washer
General Electric WLW2500BAL Washer
General Electric WLW2500BBL Washer
General Electric WLW2500BCL Washer
General Electric WLW2500BNL Washer
General Electric WLW2500RBL Washer
Frigidaire WLW3 Frg(v1) / 27 " Washer
General Electric WLW3000BAL Washer
General Electric WLW3000BBL Washer
General Electric WLW3000BCL Washer
General Electric WLW3000BNL Washer
General Electric WLW3000RBL Washer
General Electric WLW3000SALWH Washer
General Electric WLW3200SALWH Washer
General Electric WLW3200SBLWH Washer
General Electric WLW3300BBL Washer
General Electric WLW3300BCL Washer
General Electric WLW3300BNL Washer
General Electric WLW3300RBL Washer
General Electric WLW3310BBL Washer
General Electric WLW3310BCL Washer
General Electric WLW3310BNL Washer
General Electric WLW3310RBL Washer
General Electric WLW3400SALAD Washer
General Electric WLW3400SALWH Washer
General Electric WLW3400SBLAD Washer
General Electric WLW3400SBLWH Washer
General Electric WLW3440SALAD Washer
General Electric WLW3440SALWH Washer
General Electric WLW3440SBLAD Washer
General Electric WLW3440SBLWH Washer
General Electric WLW3500BAL Washer
General Electric WLW3500BBL Washer
General Electric WLW3500BCL Washer
General Electric WLW3500BNL Washer
General Electric WLW3500RBL Washer
General Electric WLW3505BAL Washer
General Electric WLW3505BBL Washer
General Electric WLW3600BBL Washer
General Electric WLW3600BCL Washer
General Electric WLW3600BNL Washer
General Electric WLW3600SALAD Washer
General Electric WLW3600SALWH Washer
General Electric WLW3600SBLAD Washer
General Electric WLW3600SBLWH Washer
General Electric WLW3610SALWW Washer
General Electric WLW3610SBLWW Washer
General Electric WLW3700BAL Washer
General Electric WLW3700BBL Washer
General Electric WLW3700BCL Washer
General Electric WLW3700BNL Washer
General Electric WLW3700BPL Washer
General Electric WLW3700RBL
General Electric WLW3700RBLWW Washer
General Electric WLW3750BAL Washer
General Electric WLW3750BBL Washer
General Electric WLW3750BNL Washer
General Electric WLW3750RBL Washer
General Electric WLW3760RBLWW Washer
General Electric WLW3800SALAD Washer
General Electric WLW3800SALWH Washer
General Electric WLW3800SBLAD Washer
General Electric WLW3800SBLWH Washer
General Electric WLW3810SALWW Washer
General Electric WLW3810SBLWW Washer
General Electric WLW4700BAL Washer
General Electric WLW4700BBL Washer
General Electric WLW4700BCL Washer
General Electric WLW4700BNL Washer
General Electric WLW5700BAL Washer
General Electric WLW5700BBL Washer
General Electric WLW5700BCL Washer
General Electric WLW5700BNL Washer
General Electric WLW5700RBL Washer
General Electric WLW5900MAL Washer
General Electric WLW5900MNL Washer
Frigidaire WLXG42RED0 Wwh(v1) / Laundry Center
White Westinghouse WLXG42RED1 Laundry Center - W.westinghouse
Frigidaire WLXG42RED3
Frigidaire WLXG42REW0 Wwh(v2) / Laundry Center
White Westinghouse WLXG42REW1 Laundry Center - W.westinghouse
White Westinghouse WLXG42REW2 Laundry Center - West/famsa
White Westinghouse WLXG42REW3 White Westinghouse/laundry Center
White Westinghouse WLXG42REW4 White Westinghouse/laundry Center
White Westinghouse WLXG42REW5 White Westinghouse/laundry Center
General Electric WLXR1020T2WB Washer
General Electric WLXR1020T3WB Washer
General Electric WLXR1020T4WB Washer
General Electric WLXR1020T5WB Washer
General Electric WLXR1020T8WB Washer
General Electric WLXR1020TAWB Washer
 WM0001HTMA Washer
 WM0532HW Washer
 WM0642HW Washer
 WM0742HGA Washer
 WM0742HWA Washer
 WM1333HW Washer
 WM1812CW Washer
 WM1814CW Washer
 WM1815CS Washer
 WM1832CW Washer
 WM2010CW Washer
 WM2016CW Washer
 WM2032HS Washer
 WM2032HW Washer
 WM2042CW Washer
 WM2075CW Washer
 WM2077CW Washer
 WM2101HW Washer
  #2 (permalink)
Old 03-15-2013, 04:24 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
You will have to take some line voltage readings at the motor/inverter to determine the problem. Do you have a multimeter and experience using it?
Eric
  #3 (permalink)
Old 03-15-2013, 05:16 PM
Junior Member
Default
Eric, thanks for quick reply... Yes i have a multimeter and know how to use it... My only problem is the washing machine is in my youngest sons house 35 min away. But by all means give me all you have and over the weekend i be able to get through it.
  #4 (permalink)
Old 03-15-2013, 06:18 PM
Expert
APP Volunteer
Default
Assume you have checked the belt and that you can freely rotate the basket by hand?
All readings are with one probe of the meter on neutral which is the wht/red wire of the leftmost connector. Check for 120vac with the other probe on the red/blk wire and orn wire (lid closed or switch bypassed) of the leftmost connector. The rightmost connector is from the timer and two wires will have 120vac on them depending on mode and speed. (one probe still on neutral).
High speed agitate is 120vac on the blue and violet/white wires
Low speed agitate, white and violet/white
High speed spin, red and blue
Low speed spin, red and white
If these check out ok, then you have a faulty motor/inverter.
Eric
  #5 (permalink)
Old 03-19-2013, 12:19 PM
Junior Member
Default
Eric,
Sorry for slow response, was only able to get back over to sons place today...
At any rate, yes belt is intact, drum and agitator turns freely with no roughness or stiff points.
AC voltage readings with washer turned off and inverter/ motor green led blinking on one second, off one second.
Red with black trace. 122.7 vac
Orange. 122.6 vac
High speed agitate
Blue to Violet w/ white trace. 3.59 vac
Low speed agitate
White to Violet w/ white trace. 3.59 vac
High speed spin
Red to Blue. 2.59 vac
Low speed spin
Red to White. 0.32 vac
If I take vac neutral ( White with red trace ) to Blue, Violet with white trace, White and Red, all readings are 0.000 vac.
All voltage readings are AC.
On a strange note. I had left the unit unpluged from last week. I pluged it in and started a cotton wash cycle,with low water setting, and the washer filled and started agitating. This did not last. Only agitated for mayby 5 min and would not spin. Back to not agitating or spinning as the cycles progressed. Discharge pump worked through the cycles as it should.
Where to now?
Thanks in advance Eric,
John
  #6 (permalink)
Old 03-19-2013, 02:27 PM
Expert
APP Volunteer
Default
You need to take the readings with the washer on and set for the specific mode of operation..i.e. agitate high, spin high...etc. These voltages are from the timer and simply tell the inverter what to do. For example, if set to spin high, washer on, there should be 120vac on the red and blue wires. The inverter interprets this as "go to high speed spin". The inverter has a microprocessor and firmware to operate the machine.
Eric
  #7 (permalink)
Old 03-19-2013, 02:40 PM
Junior Member
Default
Eric,
Got you.. Should have known better, old dog... To obtain high spin or high agetate use heavy duty cycle and low speeds delicate cycle?
Will head back over there tomorrow...
Thanks,
John
  #8 (permalink)
Old 03-20-2013, 09:17 AM
Junior Member
Default
Eric,
Ok, all terminals for low/high speed agitate and spin are line voltage, 121.8-122.1 vac... Bad motor/inverter dispite LED flashing no code??? Replacement motor/inverter in order???
Thanks,
John
  #9 (permalink)
Old 03-20-2013, 10:37 AM
Expert
APP Volunteer
Default
What do you mean by all terminals have line voltage???? When set to high speed spin you should only have line voltage on the red and blue wires. That's with one probe on neutral, not across the red and blue wires.
Eric
  #10 (permalink)
Old 03-20-2013, 11:14 AM
Junior Member
Default
Low speeds
Agitate
White. 121.8 vac
Violet/white trace. 121.8 vac
Spin
Red. 121.8 vac
White. 122.7 vac
High speeds
Agitate
Blue. 121.7 vac
Violet/white trace 121.9 vac
Spin
Red. 122.1 vac
Blue 122.1 vac
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Imperial washer doesnt not agetate/spin or completely drain water roket77 Washer Repair 4 09-17-2016 10:14 AM
Front load washer won't spin water out of clothes on last spin cycle Tracey Finley Washer Repair 1 06-28-2011 06:10 PM
Replaced clutch (fixed wet clothes after spin) makes a noise when it starts spin??? mikeal21 Washer Repair 1 03-01-2010 07:21 PM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 07:29 PM
WASHER - tub won't agetate or spin eddieandthewasher Washer Repair 2 04-18-2009 06:19 AM
