Discuss
motor doesn´t start
 in
Washer Repair
I don't have any info on the thermal switch but I would certainly be interested in your findings and photo's
Appliance Repair Forum > Appliance Repair Help > Washer Repair » motor doesn´t start
  #11 (permalink)
Old 04-05-2013, 04:22 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
I don't have any info on the thermal switch but I would certainly be interested in your findings and photo's would be great. I'm sure others like myself are always seeking to learn more through these forums so please keep us posted. I don't know why but this motor is readily available here in the U.S.
Eric
  #12 (permalink)
Old 04-22-2013, 01:13 PM
Junior Member
awdtalon is on a distinguished road
Default
Quote:
Originally Posted by laverap View Post
Thanks Eric , I could see perfectly well the OL switch over the coil it´s tight strongly with a tiny rope all around the coil, as you -with very professional judgement- recomend, I can´t eliminate the OL switch and give it to the customer , it wouldn´t be safe , so , I´ll will take the other route , I will change the OL without dissasembling the motor (remember it is welded), it will be a difficult task -I suppose- but perhaps I have more persistance than skills and I will do it . Do you have any idea of the model number or any information about the OL (temperature) the voltaje is for 220 V. Do you think that it would it be interesting for the forum some photos of the procedure ? .
Best regards
Hugo
i will say this i ran into a problem with a washer they would do everything but motor would not turn. it was a 110v. the belt broke so i thought hey replace the belt all good. NOPE. when i was doing some research i seen a thing on another site saying about open and closing the door switch so many times. My model didnt look like the model that they was showing the test being done on but figued after all the testing i did what the heck. you unplug unit and open and close door switch so many times i think its 5 and volla motor started to work. i was ready to junk unit but the door switch fixed issue. Just thought i would throw that out there
  #13 (permalink)
Old 04-22-2013, 02:03 PM
Expert
APP Volunteer
Default
That reset procedure is for GE models with the motor/inverter. It resets the error codes and microprocessor on the inverter board. That does not apply to this model in question.
Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
start button doesn' always work brian raisch Washer Repair 0 06-24-2011 03:27 PM
Start Button Doesn"t work rroewest Dishwasher Repair 1 11-23-2010 12:49 PM
Wash motor won't start, bad pump motor capacitor? 65skyturbo Dishwasher Repair 0 07-17-2010 11:58 AM
Water dispenser doesn’t. LastRanger Refrigerator & Freezer Repair 0 04-11-2010 01:39 PM
Dryer Doesn DALE R Dryer Repair 3 10-26-2009 05:53 PM
