Discuss
Washer not washing
 in
Washer Repair
my washer fills up water but starts making loud funny noises once it begins the washing cycle.,I noticed also that
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer not washing
  #1 (permalink)
Old 03-14-2013, 10:12 PM
Junior Member
ayusinko is on a distinguished road
Default Washer not washing
Brand: Maytag   Age: 5 - 10 years
my washer fills up water but starts making loud funny noises once it begins the washing cycle.,I noticed also that the there is no center movement inside that it usually does while washing. please help me..
  #2 (permalink)
Old 03-15-2013, 07:29 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What is the complete model number of the washer?
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-15-2013, 10:09 PM
Junior Member
Default
maytag - model number:MAV6458AWW
  #4 (permalink)
Old 03-15-2013, 10:13 PM
Junior Member
Default
Maytag - model number: MAV6458AWW
  #5 (permalink)
Old 03-18-2013, 04:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Tilt the washer back and remove the belt. Check how freely the pump pulley is moving in both directions. Replace the pump if it does not do it. Check the belt.
- The drain pump Part number: 35-6780
- The drive belt Part number: 22003483
Here are the breakdown diagrams and Parts for Maytag MAV6458AWW Washer - AppliancePartsPros.com
__________________
  #6 (permalink)
Old 03-31-2013, 01:11 PM
Junior Member
Default washer not washing
I tilted back the washer and did a check on the parts mentioned(pulley and belt).,both parts seemed to be in good order and intact. The pulley is moving freely in both direction and the belt is still attached and doesn't show any sign of tear..please help
  #7 (permalink)
Old 04-02-2013, 01:09 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does the motor run?
Push down the agitator while the washer is on the wash cycle. Did you feel any oscillating?
Remove the agitator and check the splines inside the agitator and on the top of the transmission shaft. Make sure they are not stripped.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer not washing jmoreaegis Dryer Repair 0 01-04-2013 09:25 AM
washer squeals when washing jonellbrandi Washer Repair 1 10-19-2012 06:15 PM
Washer Leaks While Washing kissdude Washer Repair 6 05-01-2011 06:53 PM
GE Washer not washing or spinning sdklink Washer Repair 2 09-09-2009 05:08 AM
