Discuss
bravo lid lock error...replace lock and ecu
 in
Washer Repair
Have a bravo x. Replaced the lid lock because of the blinking lid lock light. Then ohmed it out and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » bravo lid lock error...replace lock and ecu
  #1 (permalink)
Old 03-12-2013, 05:02 PM
Junior Member
turbofreek is on a distinguished road
Default bravo lid lock error...replace lock and ecu
Model Number: mvwx500xw1   Brand: Maytag   Age: 1 - 5 years
Have a bravo x. Replaced the lid lock because of the blinking lid lock light. Then ohmed it out and ts good. Replaced main board on top of that as tech sheet says to. Wont calibrate and lid light still blinks. Im at a loss here. Why is ths not reparing this as he tech sheet says it would?
Model mvwx500xw1 this is the new crap style drive system.
It will randomly spin or fill or wash but not often enough. So replaced bith ecu and lid lock and no changes. Ohmed out the lock it is within range. Please wth could be wrong?
Related Models
Maytag MVWX550XW0 AUTOMATIC WASHER
Maytag MVWX600XW0 AUTOMATIC WASHER
Maytag MVWX700XL0 AUTOMATIC WASHER
Maytag MVWX700XW0 AUTOMATIC WASHER
Whirlpool MW1000XP0 Microwaves*
Whirlpool MW1000XP1 Microwaves*
Whirlpool MW1000XS0 MICROWAVE
Whirlpool MW1000XS1 Microwaves*
Whirlpool MW1000XW0 Microwaves*
 MW1030BA MWAVE- CNTRTP / STAND ALONE
 MW1030SB MWAVE- CNTRTP / STAND ALONE
 MW1030SB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1030WA MWAVE- CNTRTP / STAND ALONE
 MW1040BC MWAVE- CNTRTP / STAND ALONE
 MW1040BC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1040WC MWAVE- CNTRTP / STAND ALONE
 MW1040WC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1080STA MWAVE- CNTRTP / STAND ALONE
 MW1135WB MWAVE- CNTRTP / STAND ALONE
 MW1135WB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1150WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1200XP0 Microwaves*
Whirlpool MW1200XP1 Microwaves*
Whirlpool MW1200XS0 Microwaves*
Whirlpool MW1200XS1 MICROWAVE
Whirlpool MW1200XW0 Microwaves*
Whirlpool MW120EXP0 Microwaves*
 MW1245BB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1500XP0 Microwaves*
Whirlpool MW1500XP1 Microwaves*
Whirlpool MW1500XS0 Microwaves*
Whirlpool MW1500XS1 Microwaves*
Whirlpool MW1500XW0 Microwaves*
Whirlpool MW1501XS1 Microwaves*
Whirlpool MW1501XW0 Microwaves*
Roper MW157 Microwave
Maytag MW29000TB0 LAUNDRY WORKSURFACE
Maytag MW29000TU0 LAUNDRY WORKSURFACE
Maytag MW29000TW0 LAUNDRY WORKSURFACE
Whirlpool MW3000XM0 Microwaves*
Whirlpool MW3000XM1 Microwaves*
Whirlpool MW3000XP0 Microwaves*
Whirlpool MW3000XP1 Microwaves*
Whirlpool MW3000XP2 Microwaves*
Whirlpool MW3200XM0 Microwave
Whirlpool MW3200XM1 Microwave
Whirlpool MW3200XP0 Microwave
Whirlpool MW3200XP1 Microwave
Whirlpool MW3200XP2 Microwave
Whirlpool MW3200XS0 Microwave
Whirlpool MW3200XW0 Microwave
Whirlpool MW3500XM0 Microwaves*
Whirlpool MW3500XM1 Microwaves*
Whirlpool MW3500XP1 Microwaves*
Whirlpool MW3500XP2 Microwaves*
Whirlpool MW3500XP3 Microwaves*
Whirlpool MW3500XS0 Microwaves*
Whirlpool MW3500XW0 Microwaves*
Whirlpool MW3520XP1 Microwaves*
Whirlpool MW3520XP2 Microwaves*
Whirlpool MW3520XP3 Microwaves*
Whirlpool MW352EXP1 Microwaves*
Whirlpool MW3600XS0 Microwaves*
Whirlpool MW3600XW0 Microwaves*
Whirlpool MW3600XW1 Microwaves*
Whirlpool MW3601XS0 Microwaves*
Whirlpool MW3601XW0 Microwaves*
Whirlpool MW3601XW1 Microwaves*
Amana MW41 MWAVE- CNTRTP / STAND ALONE
Amana MW42 MWAVE- CNTRTP / STAND ALONE
Amana MW43 MWAVE- CNTRTP / STAND ALONE
Amana MW500.000 COMMERCIAL MICROWAVES
 MW5380W MWAVE- CNTRTP / STAND ALONE
Roper MW557 Microwave
Roper MW5571 Microwaves
 MW5592W MWAVE- CNTRTP / STAND ALONE
 MW5592W/XAA MWAVE- CNTRTP / STAND ALONE
Amana MW56 MWAVE- CNTRTP / STAND ALONE
Amana MW57 MWAVE- CNTRTP / STAND ALONE
Amana MW58 MWAVE- CNTRTP / STAND ALONE
Amana MW600.000 COMMERCIAL MICROWAVES
 MW640BA MWAVE- CNTRTP / STAND ALONE
 MW640WA MWAVE- CNTRTP / STAND ALONE
Amana MW700.000 COMMERCIAL MICROWAVES
Amana MW72 MWAVE- CNTRTP / STAND ALONE
 MW730BB MWAVE- CNTRTP / STAND ALONE
 MW735WB MWAVE- CNTRTP / STAND ALONE
 MW735WB/XAA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW7400XW0 Microwaves*
Whirlpool MW7500XW0 Microwaves*
 MW7695GS MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8100XL0 MICROWAVE
Whirlpool MW8100XL1 MICROWAVE
Whirlpool MW8100XL2 MICROWAVE
Whirlpool MW8100XP0 MICROWAVE
Whirlpool MW8100XR0 MICROWAVE
Whirlpool MW8200XL0 Microwaves*
Whirlpool MW8200XL1 Microwaves*
Whirlpool MW8200XL2 Microwaves*
Whirlpool MW8200XP0 Microwaves*
Whirlpool MW8200XR0 Microwaves*
Whirlpool MW8300XL0 Microwaves*
Whirlpool MW8300XL2 Microwaves*
Whirlpool MW8300XP0 Microwaves*
 MW830BA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW830EXP0 Microwaves*
 MW830WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8400XL0 Microwaves*
Whirlpool MW8400XL2 Microwaves*
Whirlpool MW8400XR0 Microwaves*
Whirlpool MW8400XS0 Microwaves*
Whirlpool MW8400XS1 Microwaves*
Whirlpool MW8400XS2 Microwaves*
Whirlpool MW8400XW0 Microwaves*
  #2 (permalink)
Old 03-12-2013, 05:28 PM
Junior Member
Default
If I put in a spin drain. I does the lock unlock lock. The motor begins to move the tub and she quits and stsrts blinking. I dont think it makes a full rotation however.
  #3 (permalink)
Old 03-12-2013, 05:35 PM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Probably a bad shift actuator. What you are experiencing are symptoms of a bad shifter. It is a very high failure item on this washer design. This washer design has been very problematic. Many many breakdowns on a washer design only 3 years old. It also turns out that the shift actuator can pass all tests and still be defective. Something to do with the rpm sensor which is an integral part of the shifter.
Also check the nut that holds the main drive pulley on. You will have to remove the belt guard to gain access. Loosening of this nut is a known problem. You are advised to apply loctite to the threads.
Eric
  #4 (permalink)
Old 03-12-2013, 05:36 PM
Junior Member
Default
Is this shifter seperate from the trans gear case?
  #5 (permalink)
Old 03-12-2013, 05:39 PM
Junior Member
Default
Also I can go into manual mode ad it will agitate yet not shift. Still a shifter? It just screws to the bottom right?
It starts to spin also so the shifter goes into its correct possition for work. Ah ou said tachometer is in that piece?
  #6 (permalink)
Old 03-12-2013, 05:44 PM
Expert
APP Volunteer
Default
Yes, the shifter is separate from the transmission. It has an optical sensor that fits up into an opening in the transmission housing. The lever arm of the shifter fits into the cam ring of the splutch (splined clutch). The lever moves one way or the other which raises/lowers the basket drive gear.
Eric
  #7 (permalink)
Old 03-12-2013, 05:45 PM
Junior Member
Default
Easy to change?
  #8 (permalink)
Old 03-12-2013, 05:52 PM
Expert
APP Volunteer
Default
Yes
Shift Actuator Replacement (part #W10006355) - Whirlpool Top-Load Washer Repair - YouTube
  #9 (permalink)
Old 03-12-2013, 06:39 PM
Junior Member
Default
Ill give it a try. Thanks
  #10 (permalink)
Old 03-22-2013, 04:29 PM
Junior Member
Default
The shifter thing worked. Forgot to say thank you. Now my dryer craed out on me.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lid Lock Error DaveJarrell Washer Repair 1 01-10-2012 07:44 PM
Lid Lock light error alvin5609 Washer Repair 0 09-28-2011 08:31 PM
oven door lock loose/ "lock' Flashing Tiaya Oven Repair (including Ranges and Cooktops) 0 04-02-2011 11:46 PM
Showing Door Lock is Failing to Lock Ruby123 Washer Repair 1 01-06-2011 08:13 PM
door lock error sorghum Oven Repair (including Ranges and Cooktops) 0 12-11-2009 04:39 PM
