Discuss
Not working after power surge
 in
Washer Repair
I recently had a power surge when I started my washer. Turns out the power supply from the power company
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Not working after power surge
  #1 (permalink)
Old 03-12-2013, 12:44 PM
Junior Member
TP26 is on a distinguished road
Default Not working after power surge
Model Number: S4200B0WW   Brand: GE   Age: 5 - 10 years
I recently had a power surge when I started my washer. Turns out the power supply from the power company had come loose. Now the washer doesn't work. I jumped the lid switch but the washer still did't work. I've been looking for a fuse or in-line fuse link but can't find one. According to your parts department, there is no fuse for my model and that I need to replace the control panel. I'm hesitant of buying one if because I'm not sure it will fix the problem. Is this my only option? Thanks.
Related Models
General Electric S4200B0WW Washer
General Electric S4200B1WW Washer
General Electric S4200B2WW Washer
General Electric S4200B3WW Washer
Roper S4257*0 SLIDE-IN GAS RANGE
Roper S4257W0 SLIDE-IN GAS RANGE
Roper S5007W0 Ranges, Electric*
Hoover S5083
General Electric S5100D0WW Washer
General Electric S5100D1WW Washer
Magic Chef S51FK-2KLX-64 RANGE- D/I CONT CLEAN GAS
Magic Chef S51FK-2KLX-ON RANGE- D/I CONT CLEAN GAS
General Electric S5200E1WW Washer
General Electric S5200E6WW Washer
Hoover S5501---
Hoover S5503---
Hoover S5507---
Hoover S5509---
Hoover S5509021
Hoover S5511---
Hoover S5513---
Hoover S5533---
Hoover S5535---
Hoover S5537---
Hoover S5539---
Hoover S5549
Hoover S5567011
Hoover S5569011
Hoover S5573--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5573011
Hoover S5573022
Hoover S5573033
Hoover S5575---
Hoover S5575001
Hoover S5577--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5579---
Hoover S5581---
Hoover S5583---
Hoover S5585---
Hoover S5587---
Hoover S5589---
Hoover S5593---
Hoover S5601--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5602070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5604070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5604080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5605 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5607---
Hoover S5609--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5610--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5610070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5610080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5613--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5615--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5619--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5620--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5620070 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5625--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5626--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5627 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5627080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5630--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5635--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5636--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5639---
Hoover S5640--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5643--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5645---
Hoover S5645001
Hoover S5647---
Hoover S5649---
Hoover S5651---
Hoover S5655--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5668--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5669--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5671--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5672--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5673--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5673080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5674--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5675--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5675080 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5676--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5677--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5678--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5680--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5682--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5684--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5684035 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5686--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5688--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5690--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5692--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5697--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5701--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5701035 CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5703--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5709--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5711--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5713--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5715--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Hoover S5716--- CVS-ACCESS KIT,INSTAL KIT,POWER UNIT
Magic Chef S58H-2CXW COOKING
Admiral S60STRP REF - SXS/I&W
Magic Chef S61HA-3KLX RANGE- S/I CONT CLEAN GAS
Admiral S61STRP REF - SXS/I&W
Magic Chef S64F-3CKX RANGE- S/C S/I GAS
Magic Chef S64F-3CKXW RANGE- S/C S/I GAS
Magic Chef S64F-3CKXW-NL RANGE- S/C S/I GAS
Magic Chef S64FA-3CKW RANGE- S/C S/I GAS
Magic Chef S64FN-3CKW RANGE- S/C S/I GAS
Magic Chef S64FN-3CKX RANGE- S/C S/I GAS
Magic Chef S64FN-3CKXW RANGE- S/C S/I GAS
Magic Chef S64FN-3CKXW-NL RANGE- S/C S/I GAS
Magic Chef S64H-4TKXW RANGE- S/C S/I GAS
Magic Chef S64HA-4TKXW RANGE- S/C S/I GAS
Roper S6507*0 SLIDE-IN RANGE
Roper S6507X0 SLIDE-IN RANGE
Hoover S6529--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S6530--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
  #2 (permalink)
Old 03-12-2013, 03:27 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
To check the control board :
Get an access to the board. Locate the two plugs - 6 and 11 pins.
With washer plugged in use the multimeter to check for 120VAC between the RED pin1 of the 6 pin plug and WHITE pin 4 of the 11 pin plug.
If there is no correct voltage - replace the control board
Part number: AP3183283
Here are the breakdown diagrams and Controls & Backsplash parts for GE S4200B0WW - AppliancePartsPros.com
P.S. You can return any unused parts back to APP even if you installed them.
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 03-14-2013, 10:34 AM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Post the results.
Simon.
Thank you for the helpful reply Simon. I don't have a multimeter to check the voltage nor do I know how to use one even if I did have one. All I have is a circuit tester with the alligator clip on one end and the "pen" with a light on the other. Is there any kind of testing I can do with that? Also, are there any other parks (hopefuly cheaper ) that could be bad? And if so, how do I test them? At this point, I'll probably just buy a new control board because if the machine still doesn't work, I can return it for a refund. >
  #4 (permalink)
Old 03-15-2013, 10:15 AM
Expert
Default
Hi.
Go ahead and replace the control board.
Post the results.
Simon.
__________________
  #5 (permalink)
Old 03-15-2013, 07:08 PM
Junior Member
Thumbs up Results ....
Replaced the control board and the washer worked! I was simple install except trying to disengage two of the retaining clips to remove the harness (ended up breaking the old retaining clips -- thankfully the new board has the locking clip). On another note, I ordered the part Thursday afternoon using standard delivery (was told I would receive it Monday) and I was pleasantly surprised to receive it Friday -- just one day!
I wish there would have been a cheaper fix, but thanks for the help!
  #6 (permalink)
Old 03-15-2013, 08:47 PM
Expert
Default
Hi.
Welcome to the DIY family. Congratulations on the good job.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no power after power surge to control board Harold Rehfeldt Oven Repair (including Ranges and Cooktops) 1 11-03-2012 05:38 AM
power surge damaged power pack,replaced,compressor and condenser fan still not runnin shillion Refrigerator & Freezer Repair 0 11-16-2010 01:38 AM
Amana refrigerator not working after power surge mellamanjefe Refrigerator & Freezer Repair 0 07-28-2010 07:12 AM
Power surge stopher Oven Repair (including Ranges and Cooktops) 2 03-18-2009 06:49 AM
Power Surge targetbill Dryer Repair 2 12-07-2008 12:21 PM
