Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   help (http://forum.appliancepartspros.com/washer-repair/51987-help.html)
ritaky2000@yahoo.com 10-03-2009 12:28 PM
help
:confused: a bolt has broken off of the machine somewhere and we are trying to take the tub and motor apart to get to the 5 bolts under the agiatator, husband almost has it. we need just a little help taking it apart
sidfink43 10-04-2009 06:25 PM
If you take the cap off of hte agitator you will see a screw that holds it to the shaft. Take the screw out with a socket wrench and the agitator will lift out.
To get to the motor remove the two screws at the bottom of the front panel and it will come off by tilting up and releasing clips at the top.
