I've got some issues with this washer. I noticed the problems when it didn't complete a full cycle. It's been broken for over a month now. I was able to retrieve the following codes. F01, F24, F28, F33 and F34. I've looked up the meanings of each code and can't really determine the root cause. The display and lights on the washer dims in and out. I've checked the connection points to see if anything came loose and they all appear to be connected properly. I'm not really sure which is the CCU and which is the MCU. One is located on the top of the front side and the other is on the bottom of the back side. Please help!
Groups: APP Team
HI. Based on the information you provided the CCU board should be replaced. That's the one infront. It's #6 on the diagram Part number: AP4450730
