| » Maytag Washer Brake Repair Question |
Model Number: MAV7700AWW Brand: Maytag Age: 5 - 10 years
Brake makes a grinding noise when the spin cycle finishes and it engages to stop the drum.
What parts will be needed to repair this problem. I ordered all parts that seemed to be brake related, but 2 parts where back ordered. I want to make sure I do this right. Any help would be greatly appreciated. Thank you, Rich Related Models |
Not Brake making noise, Tub "Spinner Top Assy." making the noise.
It keeps spinning on top of the drum when the drum stops, making a really bad grinding sound resonating through the drum making it louder. I'm guessing it should not spin freely on top of the tub. If I am right, should I replace this part (Maytag # 22004241) Any insight would be helpful. RichL |
Pull the tub top off, remove agitator(there may be a 1/4 inch screw near the bottom), then lift out spin basket, you will probably find a busted hub. Go to web site www.applianceaid.com for replacement info.
__________________
| Display Modes | |
| Replacing direct drive washer brake shoes | richappy | Washer Repair | 12 | 09-15-2009 02:43 AM |
| washer question | rick3635 | Washer Repair | 0 | 01-05-2008 12:56 PM |
| Microwave/microoven repair question? | ncpitman | Microwave Repair | 0 | 12-07-2007 10:12 AM |
| roper washer question | whitehanes34 | Washer Repair | 2 | 12-02-2007 01:03 PM |
| Question for dryer repair | svaughan | Dryer Repair | 1 | 09-19-2007 08:14 PM |
