Discuss
Frigidaire laundry center washer motor just hums for 5 seconds and shuts off
 in
Washer Repair
After starting the cycle, the washer fills up with water, but when it comes time for the motor to turn
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire laundry center washer motor just hums for 5 seconds and shuts off
  #1 (permalink)
Old 03-08-2013, 04:07 PM
Junior Member
rtlind83 is on a distinguished road
Unhappy Frigidaire laundry center washer motor just hums for 5 seconds and shuts off
Model Number: LCE752L-W-0   Brand: Frigidaire   Age: 5 - 10 years
After starting the cycle, the washer fills up with water, but when it comes time for the motor to turn the agitator, it just hums for 5 seconds and shuts off. It will continue to attempt to start every 2 min. It will just hum and then shut off. I've checked the belt, and taken the belt off the motor and the motor turns freely by hand. As well as the agitator assembly also turns freely by hand. However, even with the belt off, the motor still just hums and shuts off after 5 seconds. It will not drain or anything now except for hum every 2 min, trying to start the agitator, and then shut off. Please advise if there are any ideas.
Related Models
Frigidaire LCE752LL0 Frg(v2) / 27 " Laundry Center
Frigidaire LCE752LL1 Frg(v2) / 27 " Laundry Center
Frigidaire LCE752LL2 Frg(v2) / 27 " Laundry Center
Frigidaire LCE752LW0 Frg(v1) / 27 " Laundry Center
Frigidaire LCE752LW1 Frg(v1) / 27 " Laundry Center
Frigidaire LCE752LW2 Frg(v1) / 27 " Laundry Center
Frigidaire LCE772LL0 Frg(v2) / 27 " Laundry Center
Frigidaire LCE772LL1 Frg(v2) / 27 " Laundry Center
Frigidaire LCE772LL2 Frg(v2) / 27 " Laundry Center
Frigidaire LCE772LW0 Frg(v1) / 27 " Laundry Center
Frigidaire LCE772LW1 Frg(v1) / 27 " Laundry Center
Frigidaire LCE772LW2 Frg(v1) / 27 " Laundry Center
Frigidaire LCE852LL0 Frg(v2) / 27 " Laundry Center
Frigidaire LCE852LL1 Frg(v2) / 27 " Laundry Center
Frigidaire LCE852LW0 Frg(v1) / 27 " Laundry Center
Frigidaire LCE852LW1 Frg(v1) / 27 " Laundry Center
Frigidaire LCE902ADD1 Frg(v2) / 27 " Laundry Center
Frigidaire LCE902AWW1 Frg(v1) / 27 " Laundry Center
Frigidaire LCEQ2152FE1 DRYER
Whirlpool LCG6646AN2 GAS DRYER
Frigidaire LCG701ADD1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG701ADD2 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG701AWW1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG701AWW2 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG731LL0 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG731LL1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG731LW0 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG731LW1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG751LL1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG751LL2 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG751LW1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG751LW2 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG751LW3 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG771LL1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG771LL2 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG771LL3 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG771LW1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG771LW2 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG771LW3 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG851LL0 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG851LL1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG851LW0 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG851LW1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCG901ADD1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire LCG901AWW1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire LCGQ2152FE0 DRYER
Amana LCI-522 RANGE- S/C S/I DDRAFT GAS
Maytag LCLE700 RANGE- STD MWAVE ELE
Maytag LCLE750 RANGE- STD MWAVE ELE
Maytag LCLG600 RANGE- STD MWAVE GAS
Maytag LCLG601 RANGE- STD MWAVE GAS
Maytag LCME901 MWAVE- MOUNTED UNDER CABINET
 LCN240CP Air Conditioner
 LCN340CP Air Conditioner
Maytag LCNE200 RANGE- F/S STD ELE
Maytag LCNG200 RANGE- F/S STD GAS
Maytag LCNG201 RANGE- F/S STD GAS
Maytag LCNP200 RANGE- F/S STD GAS
Maytag LCNP201 RANGE- F/S STD GAS
Whirlpool LCR5232DQ0 DIRECT-DRIVE
Whirlpool LCR5232DQ1 AUTOMATIC WASHER
Whirlpool LCR5232DQ2 AUTOMATIC WASHER
Whirlpool LCR5232DQ3 COMPACT AUTOMATIC WASHER
Whirlpool LCR5232DQ4 AUTOMATIC WASHER
Whirlpool LCR5232DQ5 AUTOMATIC WASHER
Whirlpool LCR5232DZ0 DIRECT-DRIVE
Whirlpool LCR5232DZ1 AUTOMATIC WASHER
Whirlpool LCR5232DZ2 AUTOMATIC WASHER
Whirlpool LCR5232DZ3 WASHER
Whirlpool LCR5232DZ4 AUTOMATIC WASHER
Whirlpool LCR5232DZ5 AUTOMATIC WASHER
Whirlpool LCR5232HQ0 COMPACT AUTOMATIC WASHER
Whirlpool LCR5232HQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LCR5232HQ2 COMPACT AUTOMATIC WASHER
Whirlpool LCR5244AN0
Whirlpool LCR5244AN1
Whirlpool LCR5244AW0 Washers*
Whirlpool LCR5244AW1 Washers*
Whirlpool LCR7244DQ0 DIRECT-DRIVE WASHER
Whirlpool LCR7244DQ1 AUTOMATIC WASHER
Whirlpool LCR7244DQ2 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244DQ3 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244DQ4 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244DQ5 AUTOMATIC WASHER
Whirlpool LCR7244DZ0 DIRECT-DRIVE WASHER
Whirlpool LCR7244DZ1 AUTOMATIC WASHER
Whirlpool LCR7244DZ2 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244DZ3 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244DZ4 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244DZ5 AUTOMATIC WASHER
Whirlpool LCR7244HQ0 COMPACT AUTOMATIC WASHER
Whirlpool LCR7244HQ1 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LCR7244HQ2 COMPACT AUTOMATIC WASHER
Maytag LCRE200 RANGE- F/S STD ELE
Maytag LCRE300 RANGE- F/S STD ELE
Maytag LCRE350 RANGE- F/S STD ELE
Maytag LCRE400 RANGE- F/S STD ELE
Maytag LCRE600 RANGE- F/S STD ELE
Maytag LCRE650 RANGE- F/S STD ELE
Maytag LCRE655 RANGE- S/C F/S ELE
Maytag LCRE682 RANGE- S/C F/S ELE
Maytag LCRE683 RANGE- S/C F/S ELE
Maytag LCRE700 RANGE- S/C F/S ELE
Maytag LCRE750 RANGE- S/C F/S ELE
Maytag LCRE800 RANGE- S/C F/S ELE
Maytag LCRE805 RANGE- S/C F/S ELE
Maytag LCRE883 RANGE- S/C F/S ELE
Maytag LCRG200 RANGE- F/S STD GAS
Maytag LCRG300 RANGE- F/S STD GAS
Maytag LCRG305 RANGE- F/S STD GAS
Maytag LCRG350 RANGE- F/S STD GAS
Maytag LCRG355 RANGE- F/S STD GAS
Maytag LCRG382 RANGE- F/S STD GAS
Maytag LCRG383 RANGE- F/S STD GAS
Maytag LCRG400 RANGE- F/S STD GAS
Maytag LCRG405 RANGE-F/S CONT CLEAN GAS
Maytag LCRG500 RANGE- F/S STD GAS
Maytag LCRG501 RANGE- F/S STD GAS
Maytag LCRG502 RANGE- F/S STD GAS
Maytag LCRG505 RANGE- F/S STD GAS
  #2 (permalink)
Old 03-09-2013, 08:52 AM
Junior Member
RKF22 is on a distinguished road
Default
Sounds like a bad motor or something is caught in the blower
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire laundry center washer DougR2Rpr Washer Repair 0 04-10-2012 09:04 AM
Frigidaire laundry center need to replace motor of dryer suziguzzi Dryer Repair 1 12-23-2011 04:15 AM
washer fills with water, but wont aggitate. it hums for about 5 seconds & shuts off liquidarrows Washer Repair 1 07-29-2011 07:47 PM
Frigidaire Laundry Center MisterR Washer Repair 2 06-17-2011 06:13 AM
frigidaire laundry center washer will not fast spin keithb505 Washer Repair 1 11-14-2010 12:12 PM
