Discuss
cold water
 in
Washer Repair
Timer would not enter 'spin' cycle. Replaced timer. Old timer made an odd noise. New timer in filled with hot
Appliance Repair Forum > Appliance Repair Help > Washer Repair » cold water
  #1 (permalink)
Old 03-07-2013, 11:10 AM
Junior Member
ekgjr is on a distinguished road
Default cold water
Model Number: lsr8133hqo   Brand: Whirlpool   Age: More than 10 years
Timer would not enter 'spin' cycle. Replaced timer. Old timer made an odd noise. New timer in filled with hot water. Only option for rinse is cold. Timer would not advance to cold. Went to water temp select valve..Hot worked OK. No response to cold water setting. Cold water valve is on. New timer making same type of noise. Is the hot/cold switch bad or is the valve bad? I get response to wash within each type of wash as I turn the timer, so I think the circut board is OK.
Related Models
Whirlpool LSR8133HZ0 AUTOMATIC WASHER
Whirlpool LSR8200EQ0 AUTOMATIC WASHER
Whirlpool LSR8200EZ0 AUTOMATIC WASHER
Whirlpool LSR8233EQ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EQ1 AUTOMATIC WASHER
Whirlpool LSR8233EZ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EZ1 AUTOMATIC WASHER
Whirlpool LSR8233JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JQ1 WASHER
Whirlpool LSR8233JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JT1 WASHER
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0 WASHER
Whirlpool LSR8433KQ1 AUTOMATIC WASHER
Whirlpool LSR8433KQ2 AUTOMATIC WASHER
Whirlpool LSR8433KT0 WASHER
Whirlpool LSR8433KT1 AUTOMATIC WASHER
Whirlpool LSR8433KT2 AUTOMATIC WASHER
Whirlpool LSR8444LQ0 WASHER
Whirlpool LSR8444LQ1 AUTOMATIC WASHER
Whirlpool LSR8444LT0 WASHER
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 AUTOMATIC WASHER
Whirlpool LSR9434PQ1 AUTOMATIC WASHER
Whirlpool LSR9434PQ3 AUTOMATIC WASHER
Whirlpool LSR9434PQ4 AUTOMATIC WASHER
Whirlpool LSR9434PT0 AUTOMATIC WASHER
Whirlpool LSR9434PT1 AUTOMATIC WASHER
Whirlpool LSR9434PT3 AUTOMATIC WASHER
Whirlpool LSR9434PT4 AUTOMATIC WASHER
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
General Electric LSS25XSWASS REFRIGERATOR W SERIES
General Electric LSS25XSWCSS REFRIGERATOR W SERIES
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0 WASHER
Whirlpool LSS9244EZ0 WASHER
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
Whirlpool LST9245AN0
Whirlpool LST9245AW0
Whirlpool LST9245BN1
Whirlpool LST9245BQ0
Whirlpool LST9245BQ2
Whirlpool LST9245BW1
Whirlpool LST9245BZ0
Whirlpool LST9245BZ2
Whirlpool LST9355AN0
Whirlpool LST9355AW0
Whirlpool LST9355BN0
Whirlpool LST9355BQ0
Whirlpool LST9355BQ1
Whirlpool LST9355BW0
Whirlpool LST9355BZ0
Whirlpool LST9355BZ1
Whirlpool LST9355DQ0
Whirlpool LST9355DZ0
 LSU090HE Air Conditioner
 LSU092CE Air Conditioner
 LSU092HE Air Conditioner
 LSU120HE Air Conditioner
  #2 (permalink)
Old 03-07-2013, 11:34 AM
Expert
APP Volunteer
fairbank56 is a jewel in the rough
Default
Sounds like the water valve is bad. Swap the electrical connectors between valves and try rinse cycle. If you get hot water, cold water valve is bad. Check inlet screen for blockage before replacing.
Eric
  #3 (permalink)
Old 03-08-2013, 03:47 PM
Junior Member
Default cold water disruption
Hello All. Symptoms: wash cycle OK. Stopped at rinse. Wash cycle kicked in with the timer being turned, but no cold water. Timer was making a strange noise.Conclusion: timer bad..replace timer.Timer replaced. Same symptoms. Took a look at the cold water screen/filter. Absolutely clogged. Cleaned both hot and cold filters and reinserted. Noted sludge on hot water filter but not as much as on cold. Decided to drain a few quarts off of the Hot water heater with result of mildly rust colored water. Also replaced house sediment filter. Decided to check water supply. With the cold water hose disconnected, I turned the cold water valve on: NOWATER. Remembered the plumber installed an expansion valve to my water heater; he forgot to turn on the feed line to the washer. Turned on feed line. Washer works fine. I had also concluded the heat switch was bad and bought a new one. Will not intstall it. I am remined of the words of my father, "Always try the simplest fix first.", next, "Don't jump to conclusions." I'm proud of my new timer I didn't need! Well, I got out of buying a switch! {;-]
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No cold water for wash cycle, but there is cold water on the rinse cycle Cois Tine Washer Repair 5 11-29-2012 05:21 PM
Wash cycle-no cold water; Rinse cycle gets cold water Cois Tine Washer Repair 1 11-20-2012 09:32 PM
no cold water on cold/cold cycle rpbmd Washer Repair 1 08-28-2009 10:04 AM
washer won"t run on cold cold water setting jwh4969 Washer Repair 1 12-23-2008 06:41 AM
no cold water alone coming in .do get hot or warm. so cold must be comin through valv misterfixall Washer Repair 1 11-16-2007 12:51 PM
