Discuss
samsung washer not draining no power to
 in
Washer Repair
my washer does not drain,i have no power to drain pump.at pump, nutruel wireis recieving power [blue wire .shared by
Appliance Repair Forum > Appliance Repair Help > Washer Repair » samsung washer not draining no power to
  #1 (permalink)
Old 03-07-2013, 09:59 AM
Junior Member
pabboy is on a distinguished road
Default samsung washer not draining no power to
Model Number: wf448aap/xaa   Brand: Samsung   Age: 1 - 5 years
my washer does not drain,i have no power to drain pump.at pump, nutruel wireis recieving power [blue wire .shared by circulation and drain pump circulationpump works]ive varified the wiring to the pump and from the pump to the mainPWB which consist of:The violet wire from the pump to the board (which werefine) I have also varified that the pump is in good working order. For myvoltage check i put the washer in diognastic mode to "active test"the pump, only circulation pump come on. I have even ran it through the pumpcycle.I performed voltage pin check at (PWD board conector) I do not believe ihave a wiring problem to or from the pump. I have gone and order the main PWBpart number (DC92/00133A) I intalled it, did not fix it. The problem is theboard they sent me has 5-intergrated rellays attached to it, the one originallyremoved has 9. I have also tried part #(DC92/00133V)
I have also cheked the power to the board at black 3-pin connector #2 pin 1and connector #1 pin 1 and connector 5C (steamer connector) all recievingpower. My guess is that there has been a production change in the circuitboards. Thank you for your time and effort, it is greatly appreciated.
Serial #W03954AQ801484X
Production Date (08/2008)
Related Models
White Westinghouse WFC0510DW1 White Westinghouse/freezer
White Westinghouse WFC05K0DW0 White Westinghouse/freezer
Frigidaire WFC05M2AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC07M2AW0 Wwh(v1) / Chest Freezer
White Westinghouse WFC07M2AW1 White Westinghouse/freezer
White Westinghouse WFC07M2AW2 White Westinghouse/freezer
White Westinghouse WFC07M2AW3 White Westinghouse/freezer
White Westinghouse WFC07M2AW4 White Westinghouse/freezer
White Westinghouse WFC07M2AW5 White Westinghouse/freezer
White Westinghouse WFC07M2AW6 White Westinghouse/freezer
White Westinghouse WFC07M2AW7 White Westinghouse/freezer
White Westinghouse WFC07M2AW8 White Westinghouse/freezer
White Westinghouse WFC07M2AW9 FREEZER
Frigidaire WFC07M3HW0 Whi(v0) / Freezer
White Westinghouse WFC07M3HW1 White Westinghouse/freezer
White Westinghouse WFC09K0DW0 White Westinghouse/freezer
Frigidaire WFC09M2AW0 Wwh(v1)
White Westinghouse WFC09M3BW0 White Westinghouse/freezer
White Westinghouse WFC09M3BW1 Whitewestinghouse/freezer
White Westinghouse WFC09M3BW2 White Westinghouse/freezer
White Westinghouse WFC09M3BW3 White Westinghouse/freezer
White Westinghouse WFC09M3BW4 FREEZER
White Westinghouse WFC09M3BW5 FREEZER
White Westinghouse WFC09M3BW6 FREEZER
Frigidaire WFC09M3HW0 Wwh(v0) / Freezer
White Westinghouse WFC09M3HW1 White Westinghouse/freezer
White Westinghouse WFC1310EW0 White Westinghouse/freezer
White Westinghouse WFC15K2BW0 White Westinghouse/freezer
White Westinghouse WFC15K2BW1 White Westinghouse/freezer
White Westinghouse WFC15K2BW2 White Westinghouse/freezer
White Westinghouse WFC15K2BW3 White Westinghouse/freezer
Frigidaire WFC15M3AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC15M3AW1 Wwh(v1) / Chest Freezer
White Westinghouse WFC15M4BW0 White Westinghouse/freezer
White Westinghouse WFC15M4BW1 White Westinghouse/freezer
White Westinghouse WFC15M4BW2 White Westinghouse/freezer
White Westinghouse WFC15M4BW3 White Westinghouse/freezer
White Westinghouse WFC15M4BW4 FREEZER
White Westinghouse WFC15M4BW5 FREEZER
Frigidaire WFC15M4HW0 Whi(v0) / Refrigerator
White Westinghouse WFC15M4HW1 White Westinghouse/freezer
Frigidaire WFC18M4AW0 Wwh(v1) / Chest Freezer
White Westinghouse WFC20M3AW0 White Westinghouse/freezer
Frigidaire WFC20M4AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC20M4AW1 Wwh(v1) / Chest Freezer
White Westinghouse WFC20M4BW0 White Westinghouse/freezer
White Westinghouse WFC20M4BW1 White Westinghouse/freezer
White Westinghouse WFC20M4BW2 White Westinghouse/freezer
White Westinghouse WFC20M4BW3 White Westinghouse/freezer
White Westinghouse WFC20M4BW4 White Westinghouse/freezer
White Westinghouse WFC20M4BW5 White Westinghouse/freezer
White Westinghouse WFC20M4BW6 FREEZER
Frigidaire WFC20M4HW0 Whi(v1) / Freezer
White Westinghouse WFC20M4HW1 White Westinghouse/freezer
White Westinghouse WFC25M3AW0 White Westinghouse/freezer
White Westinghouse WFC25M4BW0 White Westinghouse/freezer
White Westinghouse WFC25M4BW1 White Westinghouse/freezer
White Westinghouse WFC25M4BW2 White Westinghouse/freezer
White Westinghouse WFC25M4BW3 White Westinghouse/freezer
White Westinghouse WFC25M4BW4 White Westinghouse/freezer
White Westinghouse WFC25M4BW5 FREEZER
White Westinghouse WFC25M4BW6 FREEZER
White Westinghouse WFC25M4BW7 FREEZER
Frigidaire WFC25M4HW0 Whi(v2) / Freezer
White Westinghouse WFC25M4HW1 White Westinghouse/freezer
White Westinghouse WFC25M4HW2 White Westinghouse/freezer
Frigidaire WFC25M7AW0 Wwh(v1) / Chest Freezer
Frigidaire WFC25M7AW1 Wwh(v1) / Chest Freezer
Whirlpool WFC7500VW0 COMPACT AUTOMATIC WASHER
Whirlpool WFC7500VW1 WASHER
Whirlpool WFE114LWS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE115LXB0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE115LXQ0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE260LXS0 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE301LVB0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE301LVQ0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE301LVS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Whirlpool WFE321LWB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE321LWQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE321LWS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWB1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE324LWQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWQ1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE324LWS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE324LWS1 30" ELECTRIC FREESTANDING RANGE
Whirlpool WFE361LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVB1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVD0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVD1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVQ1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVS1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE361LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE361LVT1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE364LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVD0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE364LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Whirlpool WFE366LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE366LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE371LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Whirlpool WFE374LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE374LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE374LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE374LVT0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVB1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE381LVQ0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVQ1 30" ELECTRIC CERAN FREESTANDING RANGE
Whirlpool WFE381LVS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN OVEN
Whirlpool WFE381LVS1 30" ELECTRIC CERAN FREESTANDING RANGE
White Westinghouse WFF334GCA ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Samsung dryer -Power problem Perdue11 Dryer Repair 0 06-27-2012 08:50 AM
Change a power cord in a Samsung Refrigerator rickim757 Refrigerator & Freezer Repair 2 01-12-2012 04:09 PM
Samsung WF316BAC/XAA no power ecocars Washer Repair 1 12-24-2011 08:20 AM
samsung ref is dead no power at all bobmorrison Refrigerator & Freezer Repair 0 03-23-2010 03:04 PM
Dish washer not draining after a power surge/black out gregl Dishwasher Repair 1 01-01-2009 03:56 AM
