Discuss
Washer not cycling properly
 in
Washer Repair
No matter what cycle I use the washer fills, agitates, drains, but then does not spin. Not sure what it's
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer not cycling properly
  #1 (permalink)
Old 03-05-2013, 02:13 PM
Junior Member
Helplease is on a distinguished road
Default Washer not cycling properly
Model Number: WTW4800XQ0   Brand: Whirlpool   Age: 1 - 5 years
No matter what cycle I use the washer fills, agitates, drains, but then does not spin. Not sure what it's doing after that. I think it rinses (but has not Always dumped the softener even though I set it to) and drains but it never spins at the end. If I set it to rinse and spin it might or might not work and if I sent it to drain and spin then it seems to spin at the end (so it Can spin). Also various lights showing what it's doing do not always seem to work correctly (not that I care about it - just might indicate more what's wrong?) like the lock light sometimes "blinking" or being off when it should be on, etc. Wondering what part I need to fix it. Thanks
Ads By Google
Related Models
Whirlpool WTW5100SQ0 Automatic Washer
Whirlpool WTW5200SQ0 Automatic Washer
Whirlpool WTW5300SQ0 Automatic Washer
Whirlpool WTW5310SQ0 Automatic Washer
Whirlpool WTW5320SQ0 Automatic Washer
Whirlpool WTW5321SQ0 Automatic Washer
Whirlpool WTW5400TQ0 Automatic Washer
Whirlpool WTW5500SQ0 Automatic Washer
Whirlpool WTW5500SQ2 Automatic Washer
Whirlpool WTW5500ST0 Automatic Washer
Whirlpool WTW5500ST2 Automatic Washer
Whirlpool WTW5505SQ0 Automatic Washer
Whirlpool WTW5505SQ1 Automatic Washer
Whirlpool WTW5520SQ0 Automatic Washer
Whirlpool WTW5521SQ0 Automatic Washer
Whirlpool WTW5540SQ0 Automatic Washer
Whirlpool WTW5540ST0 Automatic Washer
Whirlpool WTW5550SQ0 Automatic Washer
Whirlpool WTW5550ST0 Automatic Washer
Whirlpool WTW5560SQ0 Automatic Washer
Whirlpool WTW5590SQ0 Automatic Washer
Whirlpool WTW5590SQ2 Automatic Washer
Whirlpool WTW5590ST0 Automatic Washer
Whirlpool WTW5590ST2 Automatic Washer
Whirlpool WTW5600SQ0 Automatic Washer
Whirlpool WTW5700SW0 Automatic Washer
Whirlpool WTW5790SQ0 Automatic Washer
Whirlpool WTW5790ST0 Automatic Washer
Whirlpool WTW5800SG0 Automatic Washer
Whirlpool WTW5800SW0 Automatic Washer
Whirlpool WTW5810SW0 Automatic Washer
Whirlpool WTW5820SW0 Automatic Washer
Whirlpool WTW5821SW0 Automatic Washer
Whirlpool WTW5830SW0 Automatic Washer
Whirlpool WTW5840SG0 Automatic Washer
Whirlpool WTW5840SW0 Automatic Washer
Whirlpool WTW5850SG0 Automatic Washer
Whirlpool WTW5850SW0 Automatic Washer
Whirlpool WTW5860SG0 Automatic Washer
Whirlpool WTW5860SW0 Automatic Washer
Whirlpool WTW5900SB0 Automatic Washer
Whirlpool WTW5900SW0 Automatic Washer
Whirlpool WTW5900TB0 Automatic Washer
Whirlpool WTW5900TW0 Automatic Washer
Whirlpool WTW6200SW0 Automatic Washer
Whirlpool WTW6200SW1 Automatic Washer
Whirlpool WTW6200SW2 Automatic Washer
Whirlpool WTW6200SW3 Automatic Washer
Whirlpool WTW6300SB0 Automatic Washer
Whirlpool WTW6300SB1 Automatic Washer
Whirlpool WTW6300SB2 Automatic Washer
Whirlpool WTW6300SG0 Automatic Washer
Whirlpool WTW6300SG1 Automatic Washer
Whirlpool WTW6300SG2 Automatic Washer
Whirlpool WTW6300SW0 Automatic Washer
Whirlpool WTW6300SW1 Automatic Washer
Whirlpool WTW6300SW2 Automatic Washer
Whirlpool WTW6400SW0 Automatic Washer
Whirlpool WTW6400SW1 Automatic Washer
Whirlpool WTW6400SW2 Automatic Washer
Whirlpool WTW6400SW3 Automatic Washer
Whirlpool WTW6600SB0 Automatic Washer
Whirlpool WTW6600SB1 Automatic Washer
Whirlpool WTW6600SB2 Automatic Washer
Whirlpool WTW6600SB3 Automatic Washer
Whirlpool WTW6600SG0 Automatic Washer
Whirlpool WTW6600SG1 Automatic Washer
Whirlpool WTW6600SG2 Automatic Washer
Whirlpool WTW6600SG3 Automatic Washer
Whirlpool WTW6600SW0 Automatic Washer
Whirlpool WTW6600SW1 Automatic Washer
Whirlpool WTW6600SW2 Automatic Washer
Whirlpool WTW6600SW3 Automatic Washer
Whirlpool WTW6700TW0 Automatic Washer
Bosch WTZ1170
Bosch WTZ1210
Whirlpool WU0800B
Whirlpool WU0800XX0
Whirlpool WU0800XX1
Maytag WU100 Dishwasher - Undercounter
Maytag WU1000 Dishwasher - Undercounter
Whirlpool WU1000X0
Whirlpool WU1000X1
Whirlpool WU1000X4
Whirlpool WU1000X5
Whirlpool WU1000X6
Whirlpool WU1000X7
Whirlpool WU1000X8
Whirlpool WU1000Y0
Whirlpool WU1000Y1
Maytag WU1004 Dishwasher - Undercounter
Maytag WU1005 Dishwasher - Undercounter
Maytag WU101 Dishwasher - Undercounter
Maytag WU103 Dishwasher - Undercounter
Maytag WU104 Dishwasher - Undercounter
Maytag WU180 Dishwasher - Undercounter
Whirlpool WU1800XX0
Frigidaire WU180T1BLACK Wwh(v5) / 18 " Dishwasher
Frigidaire WU180TF1 Wwh(v3) / 18 " Dishwasher
Frigidaire WU180TH1 Wwh(v2) / 18 " Dishwasher
Frigidaire WU180TR1 Wwh(v1) / 18 " Dishwasher
Frigidaire WU180TV1 Wwh(v4) / 18 " Dishwasher
Frigidaire WU180TW1 Wwh(v6) / 18 " Dishwasher
Maytag WU181 Dishwasher - Undercounter
Maytag WU200 Dishwasher - Undercounter
Maytag WU201 Dishwasher - Undercounter
Maytag WU202 Dishwasher - Undercounter
Maytag WU203 Dishwasher - Undercounter
Maytag WU204 Dishwasher - Undercounter
Maytag WU282 Dishwasher - Undercounter
Maytag WU284 Dishwasher - Undercounter
Maytag WU285 Dishwasher - Undercounter
Maytag WU300 Dishwasher - Undercounter
Whirlpool WU3000V0
Whirlpool WU3000V1
Whirlpool WU3000V2
Whirlpool WU3000V3
Whirlpool WU3000X0
Whirlpool WU3000X1
Whirlpool WU3000X2
  #2 (permalink)
Old 03-05-2013, 03:00 PM
Expert
APP Volunteer
fairbank56 will become famous soon enough
Default
This washer design which came out in 2010, has been very problematic. The first thing I would check is the nut that holds the drive pulley. These have been coming loose which causes the pulley to drop which causes problems with the splutch engaging for spin mode. You have to tilt the machine to access underneath to get to most components. If the nut is loose, apply loctite blue 242 threadlocker before retightening. The shift actuator which shifts between agitate and spin mode is a high failure item as well as the lid lock. Check that all connections are fully plugged in. This includes at the motor, shift actuator, pump, capacitor and control unit behind the control panel. There have been many reports of broken wires and faulty connections. Due to the many problems with this design, a website was set up with detailed information including service manual. The same manual should be inside the front of the washer cabinet.
Eric
  #3 (permalink)
Old 03-06-2013, 06:54 AM
Junior Member
Default
Great, got a lemon, surprise, surprise. Thanks for the ideas. Nut seemed tight. Could not find any loose connections or broken wires. Any suggestions for what next?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Pro. Comp - Ram not cycling properly Bjonesvt91 Trash Compactor Repair 1 11-09-2012 07:53 AM
Washer not cycling jwilcken Washer Repair 3 05-02-2011 06:17 AM
Washer not spin cycling rsegovia362003 Washer Repair 2 03-22-2010 07:44 AM
washer not cycling teddy Washer Repair 1 06-09-2009 08:04 AM
Washer not cycling sam_rosales Washer Repair 0 01-25-2008 12:50 PM
