Discuss
Washer stutters on Hot setting
 in
Washer Repair
Within the last 2 weeks, my washer stutters when I use the hot water setting. It will turn itself off
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer stutters on Hot setting
  #1 (permalink)
Old 03-05-2013, 07:17 AM
Junior Member
COLDFRONT is on a distinguished road
Default Washer stutters on Hot setting
Model Number: WLW2500BBLWH   Brand: Hotpoint   Age: More than 10 years
Within the last 2 weeks, my washer stutters when I use the hot water setting. It will turn itself off from the stuttering and shaking. If I use the warm setting the stuttering will stop on its own and, it does not happen on the cold setting. We have replaced the water supply hose and the water intake valve. The hot water pipe for the washer is on the same pipe to the wash tub. When I use the hot water faucet, there is no stuttering or shaking.
Please help....thank you.
Ads By Google
Related Models
General Electric WLW2500BCL Washer
General Electric WLW2500BNL Washer
General Electric WLW2500RBL Washer
Frigidaire WLW3 Frg(v1) / 27 " Washer
General Electric WLW3000BAL Washer
General Electric WLW3000BBL Washer
General Electric WLW3000BCL Washer
General Electric WLW3000BNL Washer
General Electric WLW3000RBL Washer
General Electric WLW3000SALWH Washer
General Electric WLW3200SALWH Washer
General Electric WLW3200SBLWH Washer
General Electric WLW3300BBL Washer
General Electric WLW3300BCL Washer
General Electric WLW3300BNL Washer
General Electric WLW3300RBL Washer
General Electric WLW3310BBL Washer
General Electric WLW3310BCL Washer
General Electric WLW3310BNL Washer
General Electric WLW3310RBL Washer
General Electric WLW3400SALAD Washer
General Electric WLW3400SALWH Washer
General Electric WLW3400SBLAD Washer
General Electric WLW3400SBLWH Washer
General Electric WLW3440SALAD Washer
General Electric WLW3440SALWH Washer
General Electric WLW3440SBLAD Washer
General Electric WLW3440SBLWH Washer
General Electric WLW3500BAL Washer
General Electric WLW3500BBL Washer
General Electric WLW3500BCL Washer
General Electric WLW3500BNL Washer
General Electric WLW3500RBL Washer
General Electric WLW3505BAL Washer
General Electric WLW3505BBL Washer
General Electric WLW3600BBL Washer
General Electric WLW3600BCL Washer
General Electric WLW3600BNL Washer
General Electric WLW3600SALAD Washer
General Electric WLW3600SALWH Washer
General Electric WLW3600SBLAD Washer
General Electric WLW3600SBLWH Washer
General Electric WLW3610SALWW Washer
General Electric WLW3610SBLWW Washer
General Electric WLW3700BAL Washer
General Electric WLW3700BBL Washer
General Electric WLW3700BCL Washer
General Electric WLW3700BNL Washer
General Electric WLW3700BPL Washer
General Electric WLW3700RBL
General Electric WLW3700RBLWW Washer
General Electric WLW3750BAL Washer
General Electric WLW3750BBL Washer
General Electric WLW3750BNL Washer
General Electric WLW3750RBL Washer
General Electric WLW3760RBLWW Washer
General Electric WLW3800SALAD Washer
General Electric WLW3800SALWH Washer
General Electric WLW3800SBLAD Washer
General Electric WLW3800SBLWH Washer
General Electric WLW3810SALWW Washer
General Electric WLW3810SBLWW Washer
General Electric WLW4700BAL Washer
General Electric WLW4700BBL Washer
General Electric WLW4700BCL Washer
General Electric WLW4700BNL Washer
General Electric WLW5700BAL Washer
General Electric WLW5700BBL Washer
General Electric WLW5700BCL Washer
General Electric WLW5700BNL Washer
General Electric WLW5700RBL Washer
General Electric WLW5900MAL Washer
General Electric WLW5900MNL Washer
Frigidaire WLXG42RED0 Wwh(v1) / Laundry Center
White Westinghouse WLXG42RED1 Laundry Center - W.westinghouse
Frigidaire WLXG42RED3
Frigidaire WLXG42REW0 Wwh(v2) / Laundry Center
White Westinghouse WLXG42REW1 Laundry Center - W.westinghouse
White Westinghouse WLXG42REW2 Laundry Center - West/famsa
White Westinghouse WLXG42REW3 White Westinghouse/laundry Center
White Westinghouse WLXG42REW4 White Westinghouse/laundry Center
White Westinghouse WLXG42REW5 White Westinghouse/laundry Center
General Electric WLXR1020T2WB Washer
General Electric WLXR1020T3WB Washer
General Electric WLXR1020T4WB Washer
General Electric WLXR1020T5WB Washer
General Electric WLXR1020T8WB Washer
General Electric WLXR1020TAWB Washer
Jenn-Air WM227B Walloven - S/c Mwave Ele
Jenn-Air WM227W Walloven - S/c Mwave Ele
Jenn-Air WM236B Walloven - S/c Mwave Ele
Jenn-Air WM236W Walloven - S/c Mwave Ele
Jenn-Air WM27160B Walloven - S/c Mwave Ele
Jenn-Air WM27160W Walloven - S/c Mwave Ele
Jenn-Air WM2720B Walloven - S/c Mwave Ele
Jenn-Air WM2720W Walloven - S/c Mwave Ele
Jenn-Air WM27260B Walloven - S/c Mwave Ele
Jenn-Air WM27260W Walloven - S/c Mwave Ele
Jenn-Air WM27460B Walloven - S/c Mwave Ele
Jenn-Air WM27460W Walloven - S/c Mwave Ele
Jenn-Air WM2750B Walloven - S/c Mwave Ele
Jenn-Air WM2750W Walloven - S/c Mwave Ele
Jenn-Air WM277B Walloven - S/c Mwave Ele
Jenn-Air WM277W Walloven - S/c Mwave Ele
Jenn-Air WM2780 Walloven - S/c Mwave Ele
Jenn-Air WM2780B Walloven - S/c Mwave Ele
Jenn-Air WM2780W Walloven - S/c Mwave Ele
Jenn-Air WM30460B Walloven - S/c Mwave Ele
Jenn-Air WM30460W Walloven - S/c Mwave Ele
Amana WM612 Mwave - Cntrtp / Stand Alone
Amana WM614 Mwave - Cntrtp / Stand Alone
Amana WM615 Mwave - Cntrtp / Stand Alone
Amana WM712 Mwave - Cntrtp / Stand Alone
Amana WM714 Mwave - Cntrtp / Stand Alone
  #2 (permalink)
Old 03-07-2013, 05:08 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
I would have thought replacing the valve assembly would have fixed this, but since it did not the wiring to the valve assembly, the water temp selection switch or the timer itself all could be the problem.
Given the age of this machine, it is far more than 10 years old I think you should consider replacement. These were good models, but it is time.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fill solenoid stutters during fill cycle kspark Washer Repair 3 04-03-2013 06:13 AM
frontload washer will not work on any setting candygaylor Washer Repair 1 05-01-2011 08:14 AM
no display.washer works on one setting j.r.whitley@juno.com Dishwasher Repair 0 12-02-2009 10:04 AM
washer only fills tank on hot setting maximillon Washer Repair 1 06-12-2009 08:26 PM
washer beeps like some is setting it and we are not! ppatinka Washer Repair 5 04-22-2009 05:31 PM
