Discuss
whirlpool washer will not turn on.
 in
Washer Repair
I have a washer that will not turn on. Nothing happens when I push the power buttton. It has never
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool washer will not turn on.
  #1 (permalink)
Old 03-04-2013, 06:20 PM
Junior Member
dc75 is on a distinguished road
Default whirlpool washer will not turn on.
Model Number: wfw8400twoo   Brand: Whirlpool   Age: 1 - 5 years
I have a washer that will not turn on. Nothing happens when I push the power buttton. It has never given a falult code. When I unplug and re plug in the ccu unit will click and the lights will quick flash only 1 time.
Ads By Google
Related Models
Whirlpool WFW8410SW0 Automatic Washer
Whirlpool WFW8410SW01 Automatic Washer
Whirlpool WFW8500SR0 Automatic Washer
Whirlpool WFW8500SR01 Automatic Washer
Whirlpool WFW8500SR02 Automatic Washer
Whirlpool WFW9200SQ00 Automatic Washer
Whirlpool WFW9200SQ01 Automatic Washer
Whirlpool WFW9200SQ02 Automatic Washer
Whirlpool WFW9200SQ10 Automatic Washer
Whirlpool WFW9200SQA10 Automatic Washer
Whirlpool WFW9200SQA11 Automatic Washer
Whirlpool WFW9400SB00 Automatic Washer
Whirlpool WFW9400SB01 Automatic Washer
Whirlpool WFW9400SBA10 Automatic Washer
Whirlpool WFW9400ST00 Automatic Washer
Whirlpool WFW9400ST01 Automatic Washer
Whirlpool WFW9400STA10 Automatic Washer
Whirlpool WFW9400SU00 Automatic Washer
Whirlpool WFW9400SU01 Automatic Washer
Whirlpool WFW9400SW00 Automatic Washer
Whirlpool WFW9400SW01 Automatic Washer
Whirlpool WFW9400SWA10 Automatic Washer
Whirlpool WFW9400SZ00 Automatic Washer
Whirlpool WFW9400SZ01 Automatic Washer
Whirlpool WFW9400SZA10 Automatic Washer
Whirlpool WFW9600TA00 Automatic Washer
Whirlpool WFW9600TB00 Automatic Washer
Whirlpool WFW9600TC00 Automatic Washer
Whirlpool WFW9600TU00 Automatic Washer
Whirlpool WFW9600TW00 Automatic Washer
Whirlpool WFW9600TZ00 Automatic Washer
Amana WG1010.000 Commercial Microwaves
Amana WG1010.010 Commercial Microwaves
Amana WG1010.200 Commercial Microwaves
Amana WG1021.000 Commercial Microwaves
Amana WG1021.200 Commercial Microwaves
Amana WG1065.000 Commercial Microwaves
Amana WG1120.500 Commercial Microwaves
Amana WG1120.600 Commercial Microwaves
Amana WG1121.000 Commercial Microwaves
Amana WG1165.000 Commercial Microwaves
Amana WG1165.700 Commercial Microwaves
Amana WG1166.500 Commercial Microwaves
Jenn-Air WG200 Walloven - Cont Clean Gas
Jenn-Air WG206 Walloven - Cont Clean Gas
Jenn-Air WG24000B Walloven - Std Gas
Jenn-Air WG24000W Walloven - Std Gas
Jenn-Air WG30100B Walloven - S/c Gas
Jenn-Air WG30100W Walloven - S/c Gas
Amana WG445.1 Commercial Microwaves
Amana WG445.2 Commercial Microwaves
Whirlpool WGD5100SQ0 29" Gas Dryer
Whirlpool WGD5200TQ0 29" Gas Dryer
Whirlpool WGD5300SQ0 29"gas Dryer
Whirlpool WGD5300ST0 29"gas Dryer
Whirlpool WGD5310SQ0 29"gas Dryer
Whirlpool WGD5320SQ0 29"gas Dryer
Whirlpool WGD5321SQ0 29"gas Dryer
Whirlpool WGD5500SQ0 29"gas Dryer
Whirlpool WGD5500ST0 29"gas Dryer
Whirlpool WGD5520SQ0 29" Gas Dryer
Whirlpool WGD5521SQ0 29"gas Dryer
Whirlpool WGD5530SQ0 29"gas Dryer
Whirlpool WGD5540SQ0 29"gas Dryer
Whirlpool WGD5540ST0 29"gas Dryer
Whirlpool WGD5550SQ0 29" Gas Dryer
Whirlpool WGD5550ST0 29" Gas Dryer
Whirlpool WGD5560SQ0 29" Gas Dryer
Whirlpool WGD5600SQ0 29" Gas Dryer
Whirlpool WGD5600ST0 29" Gas Dryer
Whirlpool WGD5700SW0 29" Gas Dryer
Whirlpool WGD5790SQ0 29" Gas Dryer
Whirlpool WGD5790ST0 29" Gas Dryer
Whirlpool WGD5800SG0 29"gas Dryer
Whirlpool WGD5800SW0 29"gas Dryer
Whirlpool WGD5810SW0 29"gas Dryer
Whirlpool WGD5820SW0 29"gas Dryer
Whirlpool WGD5821SW0 29"gas Dryer
Whirlpool WGD5830SW0 29"gas Dryer
Whirlpool WGD5840SG0 29"gas Dryer
Whirlpool WGD5840SW0 29"gas Dryer
Whirlpool WGD5850SG0 29"gas Dryer
Whirlpool WGD5850SW0 29"gas Dryer
Whirlpool WGD5856SG0 29"gas Dryer
Whirlpool WGD5860SW0 29"gas Dryer
Whirlpool WGD5900SB0 29" Gas Dryer
Whirlpool WGD5900SW0 29" Gas Dryer
Whirlpool WGD6200SW0 29"gas Dryer
Whirlpool WGD6200SW1 29" Gas Dryer
Whirlpool WGD6400SB0 29"gas Dryer
Whirlpool WGD6400SB1 29"gas Dryer
Whirlpool WGD6400SG0 29"gas Dryer
Whirlpool WGD6400SG1 29"gas Dryer
Whirlpool WGD6400SW0 29"gas Dryer
Whirlpool WGD6400SW1 29"gas Dryer
Whirlpool WGD8300SB0 27" Gas Dryer
Whirlpool WGD8300SB1 27" Gas Dryer
Whirlpool WGD8300SW0 27" Gas Dryer
Whirlpool WGD8300SW1 27" Gas Dryer
Whirlpool WGD8410SW0 27"gas Dryer
Whirlpool WGD8410SW1 27" Gas Dryer
Whirlpool WGD8500SR0 27"gas Dryer
Whirlpool WGD8500SR1 27" Gas Dryer
Whirlpool WGD9200SQ0 Gas Dryer
Whirlpool WGD9400SB0 Gas Dryer
Whirlpool WGD9400ST0 Gas Dryer
Whirlpool WGD9400SU0 Gas Dryer
Whirlpool WGD9400SW0 Gas Dryer
Whirlpool WGD9400SZ0 Gas Dryer
Whirlpool WGD9500TC0 Gas Dryer
Whirlpool WGD9500TU0 Gas Dryer
Whirlpool WGD9500TW0 Gas Dryer
Whirlpool WGD9600SU0 Gas Dryer
Whirlpool WGD9600TA0 27" Gas Dryer
Whirlpool WGD9600TB0 27" Gas Dryer
Whirlpool WGD9600TU0 27" Gas Dryer
Whirlpool WGD9600TW0 27" Gas Dryer
Whirlpool WGD9600TZ0 27" Gas Dryer
Whirlpool WGE30302 30" Electric Range Coil Cooktop
Whirlpool WGE32301 30"electric Range Coil Cooktop E - Z Clean Oven
  #2 (permalink)
Old 03-05-2013, 02:43 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the touch-pad/LED assembly by selecting different cycles and changing the modifiers and options available. If the touch-pad/LED is not responding, replace it. There is a small chance for the CCU to be bad as well. You may want to order the touch-pad/LED assembly first. If you would order it from APP and it would not fix the problem then you can return it and order the CCU.
- The touch-pad/LED assembly Part number: 8574920
- The CCU Part number: W10205841
Here are the breakdown diagrams and Parts for Whirlpool WFW8400TW00 Washer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 03-05-2013, 03:19 PM
Junior Member
Default
Is it possible to test the ft screen?
  #4 (permalink)
Old 03-05-2013, 03:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Unfortunately these are the only troubleshooting instructions provided by Whirlpool. Definitely not good but we have what we have.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore (Whirlpool) Calypso Washer Will Not Turn On texasmug Washer Repair 3 08-17-2011 12:33 AM
Whirlpool Washer won't turn on (no lights) arshopping Washer Repair 3 06-06-2011 06:15 PM
Whirlpool Duet Washer won't turn on tommyhal Dishwasher Repair 9 08-04-2010 05:04 PM
Whirlpool Duet Washer won't turn on tommyhal Washer Repair 6 07-14-2010 04:33 AM
Whirlpool Cabrio Washer wont turn on! pjandjeannie Washer Repair 1 11-26-2008 04:12 PM
